  #1
Old 11-27-2011, 05:32 PM
bwoods001 bwoods001 is offline
FNG
Question Air Leak????
I got a surge at idle i think a may have an air leak due to the fact that i can press the primer on top of the filter assembly with ease after running the truck for 10 to 15 min then letting it idle Is this normal????? THANKS
  #2
Old 11-27-2011, 05:34 PM
FNG
Default Air Leak
I have already replaced the primer screw and the whole (water check?) fitting on the bottom of the filter
  #3
Old 11-27-2011, 05:40 PM
JoshH's Avatar
JoshH JoshH is offline
Default
If you don't have a lift pump, you should be able to easily push the primer pump on top of the filter head. It is under vacuum. Surge at idle is usually a FPR going bad or sticking. Try running some fuel additive or 2 stroke oil and see if it gets better.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #4
Old 11-27-2011, 06:37 PM
FNG
Default
Thanks i just wasn't sure. I am not throwing any codes is that normal???
  #5
Old 11-27-2011, 06:40 PM
FNG
Default
the truck is a 2005 3500 4x4 if that makes any difference
  #6
Old 11-27-2011, 06:48 PM
Tony Burkhard's Avatar
Tony Burkhard Tony Burkhard is offline
Allseason Diesel Per.
Default
The FPR normally will not throw a code until it is really bad. Does your truck try to push through the brakes at a stop light?
__________________
D-MAX ENGINE & ALLISON TRANS BUILDER
http://dirtyhookerdiesel.com
Spools & 38-Spline Pulling/Drag Racing Axle Shafts
Billet Engine Plates, Sled Pulling Performance Upgrades,
Allison Trans Blankets, PCV Reroute Kits,
High Flow Intake Manifolds 2001-2010 Duramax Diesel
Up to 150% more airflow and over 40 HP gain
Six time TTPA points champ 2006 to 2011
Member of the 1200 HP club if there was one.
Home to all the "Dirty Hookers"
DH 1.0, DH 2.0, and the new DH 3.0(XXX)
  #7
Old 11-27-2011, 06:54 PM
FNG
Default
no not really just a slight surge no pushing though. It does it the worst in park idling
  #8
Old 11-27-2011, 07:02 PM
Default
Need to hook up to a scanner to see what the FRP is doing or like stated above, try some good oil in the fuel to see if it helps.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
