  #1
Old 11-08-2011, 09:02 PM
beenDmax beenDmax is offline
FNG
Default LB7 lift kit
hey, i'm new to this forum. I've got an 03 LB7 and I am going to get a lift. i'd like to see some pics of the 03 with a 4" lift and some with a 6" so i could see which i like more. Also, any suggestions on brands or anything else like that feel free to voice your opinion. thanks!
  #2
Old 11-09-2011, 06:02 AM
zacwht20's Avatar
zacwht20 zacwht20 is offline
Default
Quote:
Here is a couple of mine (what used to be of it anyways) 6in lift with 35's on 18's
__________________
2003 LB7 White EC/SB
EFI by Rob w/DSP 5 / Danville Stage 2 68mm/ BigDipper trans with ML converter(built by Todd=Stroke 250) / Raptor 150 / Big Dipper 45% over injectors / Wicked Stage 3 Stroker pump / 4in MBRP dp back to a 6" black Mitre cut stack / 8000K HID Hi/Low / Recon smoked LED tails, cabs, and 3rd brake / Rancho 9000's / DHD Steering brace
  #3
Old 11-09-2011, 06:58 AM
Linden's Avatar
Linden Linden is offline
Sparkplugs FTL
Default
all the gmt 800 work for all years i have a 6" lift cranked up to 8" with a cognito UCA. if i were to do it all over again i would do everything cognito
__________________
  #4
Old 11-09-2011, 08:23 PM
FNG
Default
well after looking, i see that with a 4" lift you can't even tell it's lifted. So, as far as brands go for a 6" lift, what would be the best for the money? I also saw some that dropped the torsion bars and some that didn't. which is best in your opinions?
  #5
Old 11-09-2011, 08:37 PM
FNG
Default
sorry Linden, i didnt see the note above your truck till just now. i'll look up some stuff about cognitos. but i have heard that brand thrown around in my research
  #6
Old 11-09-2011, 08:48 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
I am a big tuff country fan. I have one on my own truck and have installed them on several truck. I think they are a great lift for the money.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #7
Old 11-09-2011, 09:04 PM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
If I was you I'd get a lift 2 inches higher than what you want and just lower your t-bars all the way down, that way all your angles will be flat and you will have the look you want. I have an 8" fabtech and have no complaints
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #8
Old 11-09-2011, 10:34 PM
jonathancasey19's Avatar
jonathancasey19 jonathancasey19 is offline
yepppp
Default
Quote:
Bingo
__________________
2002 LB7 ECSB Summit White
S366/74 .91 billet 6-blade race cover 360 thrust bearing, S&S 65% injectors w/BMS SAC nozzles, Exergy 10mm cp3, Cognito NTBD 4-6", EFI Live dsp5, Airdog 150, RDL's uppipes, SC IV w/1056, 6" stacks, Wherli Fab S366 intake, all custom led lighting & quad morimoto HID's, x2 12" subs, pillar gauges, debadged, Cognito brace kit & HD tie rods, Bilstein 5100's, 35x12.50 m/t atz's w/ 20" chrome rockstars
12.67 @ 105 w/ stock fuel system
  #9
Old 11-09-2011, 10:35 PM
zacwht20's Avatar
Default
With superlifts u don't have to cut the ears off the differential bracket... in case u ever wanna lower it back down u wont have to buy the 165 dollar piece from cognito
__________________
  #10
Old 11-09-2011, 11:07 PM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
Default
x3.... Especially with the fabtech's, their tierod angles angles can get stupid when cranked up.
Joe.... glad to see your change to "horniest"
  #11
Old 11-09-2011, 11:19 PM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
Hahaha.
I have a 6 inch rcd and haven't had any problems. Have run a 35 inch tire and also a 33 inch with the lift cranked down. I will find some pics in a few.
__________________
02' GMC CCSB
  #12
Old 11-10-2011, 07:26 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Lol Just so you guys know, there is such thing as lowering it too low. you will wind up blowing through the LCA bumpstop and hitting metal on metal. it dont feel good. It depends on how "saggy" your torsion bars are
there is no "best kit". Lifting a truck inheritly comes with flaws, its how some of these kits address them that makes them better than others. IMOP, Cognito, tuff country, or other spindle lift type kits are the best way to go. The first two i mentioned seem to have the best rating out of most kits. I like my fabtech but i had to do some work and put some time into it to make it ride better than stock, hold up to my abuse, and make it last a long time. If i were to do it over, id buy a cognito 4-6" kit and im actually really debating on buying one. I think the kit lowered to 4" with my 37s would look awesome . not to metion it would fit in my garage then
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #13
Old 11-10-2011, 07:34 AM
Default
hmmm.... never thought about that lower bumpstop,good point sir james.
__________________
Joe
13.20@106mph
'06 Jetta TDI
  #14
Old 11-10-2011, 08:15 AM
Chevy1925's Avatar
Default
Lol ive noticed that a 60% up travel and 40% down travel works well for those who like to play off road and a even 50/50 works well as an all around
__________________
James
  #15
Old 11-10-2011, 09:11 AM
jraymer's Avatar
<--Tree Hugger
Default
First with 33"s and t bars turned down, second with 35"s sitting normal.
__________________
02' GMC CCSB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
