  #1
Old 11-05-2011, 07:51 PM
JoshH's Avatar
JoshH JoshH is offline
Default Blocking your intake resonator?
I've personally never really seen a reason to block it, but I know a lot of guys do it. If you do and you use one of those expansion/test plugs that has a cairrage bolt with a wing nut or something similar, make sure the nut stays tight. Also, it would probably be a good idea to use one that has metal ends instead of plastic. I just saw this a couple of days ago.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #2
Old 11-05-2011, 07:53 PM
RENODMAX's Avatar
RENODMAX RENODMAX is offline
Dead Wrong
Default
Ouch! I took my resonator off when I put a bigger turbo on..
__________________
2014 Silvy 1500 CCSB- mostly stock fishing rig
2004 LB7 CCSB
Built trans, tuning, fabbed stuff by me- SOLD
  #3
Old 11-05-2011, 09:03 PM
jlawles2 jlawles2 is offline
Default
The plug I found had a metal washer that was too big for the resonator to fit back on the truck. I ground the washer down but it still will not fit down the hole. And it is a tight fit.
As for the bolt, It is drilled and has a safety pin in it so it cannot drop into the intake.
Also when I blocked the PCV, did the same thing, drilled and installed safety pin.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #4
Old 11-05-2011, 09:10 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
Wow i have a buddy that did this i better let him know,Thx Josh
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #5
Old 11-05-2011, 10:03 PM
JoshH's Avatar
Default
That's a good idea on the safety pin. I'm not sure if anyone else sells them, but Alligator sells a billet plug with an O-ring seal for both the resonator and PCV.
__________________
  #6
Old 11-05-2011, 10:58 PM
Kspen90's Avatar
Kspen90 Kspen90 is offline
<<<got turbos?
Default
Sadly my compressor wheel looks just like that but it happened before i had the truck oh well ill put a batmo in one of these days.
__________________
The Climax:
2002 2500HD lb7/zf6 in '85 K10 chassis
40% injectors
ATP tune
Dual disc clutch
Remote mount NP205
Axletech 4000 9 ton planetary axles
14.9-24 BKT 171 tractor tires
Scarlett:
2009 LMM
Bone stock
  #7
Old 11-05-2011, 11:15 PM
MadMaxx61's Avatar
MadMaxx61 MadMaxx61 is offline
Devilmaxx
Default
here is mine Red Loctite and cross drilled and wire.
__________________
Steve
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
1984 GMC Jimmy 2-Door
1998 Buick Century Limited
Sold It will be missed. 1985 Mercedes 300SD - Running still need work.
Sold It will be missed. 1995 C/K 3500 4X4 Dually 6.5L
Mods: K&N air intake, 80Hp chip, 97 cooling, twin fans, #9 Resistor, FSD Heat-Sync, Full Pillar 3 Gauge (EGT, Boost, Transmission),
  #8
Old 11-05-2011, 11:20 PM
coker6303's Avatar
coker6303 coker6303 is offline
Keep Calm and Chive On!!
Default
Why not use a 2" rubber cap? No way for anything to fall in and it fits perfect.
I removed mine for access, I don't think there is any performance gain at all.
Sent from my ADR6400L using Tapatalk
__________________
Russ
2017 Ford F250 (I know I know...)
  #9
Old 11-05-2011, 11:36 PM
arneson's Avatar
arneson arneson is offline
Default
X2 on the rubber cap. Worked great for me also. Did a few friends that way to. No issues. Took mine off now cause of the mpi twins I'm installing this week. but would use the cap again for sure.
__________________
2009 chevy crew cab ltz lmm 71k miles
many things to come.
2015.5 gmc denali lml deleted (sold)
2007 chevy classic ccsb 4x4 ltz twins ect (sold)
  #10
Old 11-05-2011, 11:42 PM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
I still have mine, resonators are cool.
__________________
02' GMC CCSB
  #11
Old 11-05-2011, 11:53 PM
Mike_S's Avatar
Mike_S Mike_S is offline
OOPS!
Default
Quote:
Untill they crack and let your sweet engine eat dirt. Ive heard of too many cracking along the seam and alowing unfiltered air into the intake.
__________________
Nancy:
2004 CC SB, LB7, 2500 HD, Borg Warner spinny thingy, Carillo tough stuff, Transgo/suncoast tranny stuff, DMP squirt guns, and a couple custom parts.
The General:
1994 EXT Cab, SB, 1500 HD, 350 SBC, Whole Buncha $hit And Its Still Not Fast.
(I do all my own work...and thats not always good)
Good, Fast, Cheap...You Can Only Have Two!
You only need 2 tools: duct tape and WD-40. Duct tape for when it moves and isnt supposed to, and WD-40 for when it don't move and should!
  #12
Old 11-06-2011, 12:21 AM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
What is wrong with a $3 rubber cap and hose clamp? sticking something in the hole is asking for it.
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #13
Old 11-06-2011, 07:15 AM
Combine Pilot's Avatar
Combine Pilot Combine Pilot is offline
They Call Me Mike
Default
Quote:
What are you referring to?
__________________
2015 GMC Denali HD
Stock for now
  #14
Old 11-06-2011, 09:49 AM
JoshH's Avatar
Default
Quote:
I have never seen one crack. Not saying it can't happen, but I can't believe it's all that common.
__________________
  #15
Old 11-06-2011, 09:58 AM
Mike_S's Avatar
OOPS!
Default
Think its more of a first generation engine issue, plus there might be something in the air here...LOL! There are 2 i know of here locally in my dinky town, and a few ive read about online. I think its prety cheap insurance, provided you do it right.
__________________
Nancy:
The General:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
