  #1
Old 10-17-2011, 04:44 AM
Hardknock1 Hardknock1 is offline
FNG
Default Fuel in oil and oil leak
Noticed big oil leak front of engine. Checked oil level.....way too much. Drove truck like this on trip over 1000 miles before i discovered problem. I think it is the CP3. Engine is running good at highway speeds, a little rough at idle. Did I do damage to bearings or internal parts with all that fuel in the oil?
  #2
Old 10-17-2011, 05:07 AM
JustinD's Avatar
JustinD JustinD is offline
Plow Truck
Default
Injectors? What year is it?
__________________
2001
II S366
12.65 @ 105 stock turbo
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
Jeremy and the guys @ WDP
  #3
Old 10-17-2011, 05:09 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
What year is your truck? Sounds like a LB7, they have the most problems with fuel in oil. If it is a LB7 more likey it's injectors. I have never heard of the cp3 putting fuel in the engine oil but it could happen...
  #4
Old 10-17-2011, 05:28 AM
FNG
Default
It is a 2003 with 118000 miles. Had a leaky injector line replaced and the system check at dealer about 20000 miles ago. no leaks and pressures were good at that time.
  #5
Old 10-17-2011, 06:38 AM
JustinD's Avatar
Plow Truck
Default
Sounds like one or more went bad, Have to check balance rates to see for sure, but usually a base pan full of fuel indicates a bad injector or a leaky injector line under the covers?
__________________
2001
II S366
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
  #6
Old 10-17-2011, 08:26 AM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
Yea sounds like a bad injector is filling the motor with fuel and it's coming out the crank case vent spilling onto the ground.
__________________
02' GMC CCSB
  #7
Kspen90's Avatar
Kspen90 Kspen90 is offline
<<<got turbos?
Default
Right year and mileage for injectors to be bad. I would stop driving it IMMEDIATELY and check balance rates.
__________________
The Climax:
2002 2500HD lb7/zf6 in '85 K10 chassis
40% injectors
ATP tune
Dual disc clutch
Remote mount NP205
Axletech 4000 9 ton planetary axles
14.9-24 BKT 171 tractor tires
Scarlett:
2009 LMM
Bone stock
  #8
Old 10-17-2011, 08:28 AM
jraymer's Avatar
<--Tree Hugger
Default
I'm going to bet your oil pressure is reading damn near zero at idle too.
__________________
02' GMC CCSB
  #9
Old 10-17-2011, 10:06 AM
Kspen90's Avatar
<<<got turbos?
Default
Quote:
When mine went it still read normal at idle but it wouldnt go past 50 when driving
__________________
The Climax:
40% injectors
ATP tune
Dual disc clutch
Remote mount NP205
Scarlett:
2009 LMM
Bone stock
  #10
Old 10-17-2011, 10:32 AM
02greysixer's Avatar
02greysixer 02greysixer is offline
Default
Not to hijack this thread but what is a normal oil pressure? While driving mines usually between 40 and 60 psi hot and drops down to 25 or so at idle.
Sint frum tha orijinul smert fone
__________________
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
  #11
Old 10-17-2011, 10:47 AM
jonathancasey19's Avatar
jonathancasey19 jonathancasey19 is offline
yepppp
Default
My balance rates were perfectly fine while the crank case was full of fuel & leaked all over the floor. No SES light, no exhaust smoke or injector knock. More than likely injector issue. LB7s were known for having cracked injector bodies and/or ball seat erosion. Mine occurred around 100k. Bosch corrected this issue in 2008. Best way is have a dealer check for high fuel return rates.
__________________
2002 LB7 ECSB Summit White
S366/74 .91 billet 6-blade race cover 360 thrust bearing, S&S 65% injectors w/BMS SAC nozzles, Exergy 10mm cp3, Cognito NTBD 4-6", EFI Live dsp5, Airdog 150, RDL's uppipes, SC IV w/1056, 6" stacks, Wherli Fab S366 intake, all custom led lighting & quad morimoto HID's, x2 12" subs, pillar gauges, debadged, Cognito brace kit & HD tie rods, Bilstein 5100's, 35x12.50 m/t atz's w/ 20" chrome rockstars
12.67 @ 105 w/ stock fuel system
  #12
Old 10-18-2011, 06:06 AM
FNG
Default
Thanks everyone. Had it towed to shop. FYI Oil Pressures never changed since I bought it with 77000 miles ( 50 to 60 on highway and about 30 at idle) Truck ran great for the 1000 mile trip, got 20 mpg. was idleing a little rough, not bad before i left on the trip. should have check the oil then. was still running good before i had it towed to the shop.
  #13
Old 10-18-2011, 06:14 AM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
I have seen more leaking return lines than cracked bodies.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #14
Old 10-18-2011, 08:13 AM
Kspen90's Avatar
<<<got turbos?
Default
Mine is around 60 when cruising on the highway and goes up to 70 under moderate acceleration
__________________
The Climax:
40% injectors
ATP tune
Dual disc clutch
Remote mount NP205
Scarlett:
2009 LMM
Bone stock
  #15
Old 09-12-2012, 07:35 PM
Mwfoshee Mwfoshee is offline
FNG
Default Duramax oil leak
I have been wondering what has been causing my oil pressure toto show "damn near zero at idle" for awhile.
Today I came out to my 2003 duramax with 200k plus miles and found alarge oil leak. I immeadiatly checked the oil level and it was over full.
Safe bet to assume injectors?
My question is this, its it safe to drive the truck to the shop?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
