  #1
Old 09-19-2011, 05:40 AM
williambryan williambryan is offline
Gearhead
Default Injector Balance Rates
Balance rates are as follows: 1.3, .5, 2.4, .3, 2.5, 1.2, 4.5, and 1.5. Tested by GM dealership. Truck has always had filters changed and 20% of fuel has had additive..........does not smoke, make oil and gets an honest 18.5 mpg at 62 mph. Engine has 160000 miles. Does this test confirm that the injectors are bad? They also said the fuel pressure reg is failing.
I didn't realize what the dealer had written there are some minus's they are as follows: 1.3, .5, 2.4, -3, 2.5, 1.2, -4.5, -1.5 PLEASE PROVIDE SOME MORE COMMENTS REGARDING IF I NEED TO CHANGE THE INJECTORS. THANKS
  #2
Old 09-19-2011, 06:20 AM
coker6303's Avatar
coker6303 coker6303 is offline
Keep Calm and Chive On!!
Default
The 4.5 is on its way but i don't think you should change anything yet.
delivered via tapatalk by your forum daddy!!
__________________
Russ
2017 Ford F250 (I know I know...)
  #3
Old 09-19-2011, 06:44 AM
Gearhead
Default Balance rate
Just what does the balance rate mean and what is good? You mentioned 4.5 is on it way out ..............I thought this was probably the good one
  #4
Old 09-19-2011, 07:05 AM
coker6303's Avatar
Default
+/- 4.0 is what you are looking for according to gm. Your 4.5 is just out of spec, but not way out like some have been.
Hopefully someone else will chime in.
What symtoms are you having since you are worried about balance rates?
__________________
Russ
  #5
Old 09-19-2011, 07:24 AM
fast03's Avatar
fast03 fast03 is offline
Default
It could go a long time with a 4.5 in park. Keep driving it.
__________________
2011 LML maybe a little not stock
Previous Dmax: 2003,CCLB,4088r,mikel trans and other goodies
Steve
  #6
Old 09-19-2011, 08:03 AM
Gearhead
Default
  #7
Old 09-19-2011, 08:08 AM
coker6303's Avatar
Default
Relax! Keep driving it, you don't have anything to worry about yet.
What year truck is this on? 160K and injectors look that good, i'm guessing it's an LBZ.
As far as the FPR failing, you still need to tell us why you are worried about any of this. What symtoms are you having? Something wrong? What triggered you to start checking these things out?
__________________
Russ
  #8
Old 09-19-2011, 08:10 AM
Gearhead
Cool Updated balance rate
Delivered via tapatalk by your forum daddy!!
i have 160000 miles on them and want to know if they need changed as the dealer advised. Also, noticed the dealer's documention on scrap paper has some minus on some of the numbers. 1.3, .5, 2.4, -3, 2.5, 1.2, -4.5, -1.5 please advise on these different numbers thanks
  #9
Old 09-19-2011, 08:19 AM
coker6303's Avatar
Default
If they are offering to change them at no cost to you then go for it. If they are suggesting you change them and it will cost you out of pocket then you are crazy to do so.
__________________
Russ
  #10
Old 09-19-2011, 08:25 AM
Gearhead
relax! Keep driving it, you don't have anything to worry about yet.
What year truck is this on? 160k and injectors look that good, i'm guessing it's an lbz.
As far as the fpr failing, you still need to tell us why you are worried about any of this. What symtoms are you having? Something wrong? What triggered you to start checking these things out?
i am retired and once a year i go on a long trip with my camper and worried that the injectors will go out on a trip leaving me at the mercy of a dealership. I have 3 friends with same model truck that had to change injectors at less than 130k, i am a retired acft mech and although diesel is not my strong point i have the ability to change them myself. I am the original owner can't afford a new one and want to keep it dependable. Year is 2003 DOESN'T SMOKE, DOESN'T MAKE OIL, RUNS SMOOTH, GETS 18.5 MPG AT 62 MPH
Last edited by williambryan; 09-19-2011 at 08:27 AM. Reason: ADDITIONAL INFORMATION
  #11
Old 09-19-2011, 08:35 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
If your worried about them, then do it. 160k on LB7 injectors is good... You have one that is borderline & could stay that way along time or crap out tomorrow. So it's your call.
  #12
Old 09-25-2011, 04:47 PM
Darin13's Avatar
Darin13 Darin13 is offline
Gearhead
Default
can you test injectors with a ppe excelerator?
  #13
Old 09-25-2011, 05:46 PM
BCata's Avatar
BCata BCata is offline
BCata
Default
yes you can test balance rates with an xcelerator. when you get to the main menu on the programmer it should say data scanning as an option. once you select data scanning you should start the engine and it will start showing you real time data. Use the down arrow button to scroll through the options. it gives you real time data on alot of things.
__________________
My Truck: 2006 LBZ CC/SB, AFE Stage 2, MBRP 4" Cat Delete, PPE Hot+2 Race, FASS 150 Platinum, Hellman Sump, EGR Block Plate, CenTex Full-Built Trans, Autometer Phantom 2 guages in Triple Pillar Pod, ReadyLift Torsion Bar Sleeves, 6" RCD Lift, Upgraded mirrors and Cab Lights, etc.
In Progress: Lowering, different rims/tires
Wish List: Twins, CP3 upgrade, Nozzles, Studs, Cal-Tracs
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
