  #1
Old 08-07-2011, 05:54 PM
LLYD_MAX's Avatar
LLYD_MAX LLYD_MAX is offline
Gearhead
Default Low Oil Pressure LMM
so it seems having some low oil pressure issues with my lmm. I know the lmm is known for having low oil pressure sometimes but is there anything you can do to fix it? the low oil pressure warning light keeps coming up every time I tow something. It did it twice today when I was towing about 5k lbs at about 65mph and it getting annoying. I just changed the oil about 200 miles ago so I know the oil is in good shape and the level is normal.
My question is it just the sender itself reading low? Or is it because its 90*F outside right now? Or does the truck need a bigger oil cooler? Or maybe all 3? I never have this problem with my lly has 3x the oil pressure my lmm does. Anyone else having this problem?
__________________
2005 CC/SB LLY Duramax Diesel EFI Live, Autometer Phantom II, 5'' single, sleeves, lift pump
2008 CC/SB LMM Duramax Diesel EFI Live, DPF Delete, 20'' Gear Alloy's
  #2
Old 08-07-2011, 06:00 PM
calabria69's Avatar
calabria69 calabria69 is offline
Beerstud1
Default
Did u log it the with scan tool just to make sure??? I put an oil cooler on and it works great, added a little more psi and cools much quicker after pulling a long grade....
__________________
2007 LMM
12.55@106xx
2003 LB7
Sport comp II gauges
EFI
5 inch mbrp
  #3
Old 08-07-2011, 06:10 PM
770JOHNNYW 770JOHNNYW is offline
Default
had this problem on an lmm im working on now in a 5500 and ended up being a broken crankshaft...hope u have better luck.
  #4
Old 08-07-2011, 07:55 PM
LLYD_MAX's Avatar
Gearhead
Default
Quote:
Was the motor running smooth and all and just had low pressure?? How do you tell if the crank is broken, im assuming you can look at the balancer and see if its wobbling or anything???
__________________
  #5
Old 08-07-2011, 07:56 PM
LLYD_MAX's Avatar
Gearhead
Default
Quote:
I havent logged it yet. Ill log a run tomorrow and see what goes. What kind of aftermarket oil cooler are you running??
__________________
  #6
Old 08-07-2011, 09:21 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
No warranty? What weight oil? I would also check it with a manual gauge, maybe the sending unit is out of whack.
  #7
Old 08-08-2011, 07:41 AM
calabria69's Avatar
Beerstud1
Default
Quote:
I got the derahle thru Jegs...put a sandwich adaptor where the oil filter goes and mounted it in the front of the truck....
__________________
2007 LMM
12.55@106xx
2003 LB7
EFI
5 inch mbrp
  #8
Old 08-11-2011, 06:21 PM
LLYD_MAX's Avatar
Gearhead
Default
Quote:
Im pretty sure the warranty was voided when I took the DPF off and tuned the truck. The oil is 15W40 rotella. Im in the process of getting a manual gauge to check and see if the sending unit is reading wrong.
I should have just bought another LLY instead of this LMM. Its always somthing with this truck
__________________
  #9
Old 08-11-2011, 09:30 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
why would you have to log it? The cluster shows exactly what the ECM is seeing on the sensor....
so basically, what you're gonna log is exactly what the oil pressure gauge is gonna say.
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
