  #1
Old 08-06-2011, 11:21 PM
towboattrash34 towboattrash34 is offline
Default Water in fuel Light ??? What to do ?
I have a water in fuel warning light on.....reset it 2x's changed fuel filter.. still on.... 3/4 tank of fuel what needs to be done ?? Still running good.
__________________
08 Chevy 2500HD LTZ
18x9 Moto Metal 950 w/ Nitto Terra Graplers 285/60/18's
Tie rod sleeves thanks: All Season Diesel Performance,Cognito Pitman/Idler arm support DMAXSTORE, Roadmaster Active suspension,
EFI Live:Idaho Rob,4" MBRPturbo back exhaust:Alligator Performance..
  #2
Old 08-07-2011, 06:07 AM
TheBac's Avatar
TheBac TheBac is offline
Default
First one Ive ever heard of that actually worked. Sure the sensor isnt bad?
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #3
Old 08-07-2011, 06:36 AM
Rhall's Avatar
Rhall Rhall is offline
Old Skooler
Default
Was there actually water in the bottom of the filter? Unplug the harness and put a jumper on it.
__________________
"Caged Hooker"
Tim @ St Joe diesel, Precision Turbos, John @ Floor it Diesel, Johnboy, BT Dieselworks, Banks, Suncoast, Exergy Engineering, Profab Headers, Socal Diesel
  #4
Old 08-07-2011, 06:41 AM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
drain filter into a glass container. let it sit for a bit and see if water seperates from it
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #5
Old 08-07-2011, 12:33 PM
Default
Im on the tug boat for 3 more weeks..... so it will be awhile before i can check anything..... just getting ideas so when i can have it checked out. Had to leave @ 3am so did not have time to check anything else..... Thanks..
__________________
08 Chevy 2500HD LTZ
  #6
Old 08-07-2011, 12:43 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Quote:
This.
Water is heavier, it will sit at the bottom.
1) Get clear bottle, a plastic water bottle works.
2) Loosen plastic nut at top, this is the bleeder. Use a wrench, not a flat blade screwdriver.
3) Hold bottle at bottom nipple, then twist nipple fins until fuel flows.
4) Fill bottle then shut nipple drain.
5) Pump the round metal pump on top until fuel starts to flow out the top.
6) Tighten bleeder.
7) Pump the pump until it feels hard.
8) It will take about 1 minute for the truck to start sometimes. Like 60 seconds - a long time. Be patient.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #7
Old 08-07-2011, 12:51 PM
McRat's Avatar
Diesel Hotrodder
Default
But it's probably just a loose wire.
__________________
Pat and Kat McSwain
  #8
Old 08-07-2011, 11:43 PM
Default
Thanks will check it out......
__________________
08 Chevy 2500HD LTZ
  #9
Old 08-07-2011, 11:51 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Pretty sure the switch is normally open. Mines unplugged and laying in the driveway, no WIF light on.
  #10
Old 08-08-2011, 10:26 AM
MMLMM's Avatar
MMLMM MMLMM is offline
Default
Quote:
correct, unplugged the WIF light i out. Put a jumper in and the light will come on.
check to see if wires are shorted together
check that float thingamajig it up when it should rest to bottom of sensor
could be sensor itself
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
