  #1
Old 08-01-2011, 05:13 PM
cb197cj5 cb197cj5 is offline
FNG
Default allison transmission Codes P0729, P0735, P02723
I have a 2006 Duramax with the Allison in it. I got a call from the shop today that the transmission had the codes P0729, P0735 and P2723. I ran it for the first 80,000 miles and one of my salesmen has taken it to 120,000. What caused a 5th and 6th gear sync problem on a non chipped stock truck? I did put 265 tires on it. . .That is the only modification from stock. If I do have to put a new transmission in it, what aftermarket beef up parts should I put in to stop this from happening again?
  #2
Old 08-01-2011, 05:22 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
I think you have a typo in your 3rd code
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #3
Old 08-01-2011, 05:40 PM
FNG
Default
OOPS P2723 oil pressure in the transmission.
  #4
Old 08-01-2011, 07:52 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Speed sensor problem is where I would look first. P0729 is 6th gear incorrect ration, p0735 is 5th gear incorrect ratio. P2723 is a tie up. ( 2 gears at once ) transfercase is the next step after speed sensors.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5
Old 08-02-2011, 07:05 AM
FNG
Default
Thanks MikeL transfer case wins the prize. The bushing that goes around the yoke coming out of the Tcase to the front of the drive shaft has been spit out. Just a transfer case rebuild? Any one make beefed up tranfer case kits?
  #6
Old 08-02-2011, 08:42 AM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
Might as well put a pump rub kit in it while you have it open.
http://www.merchant-automotive.com/t...grade-kit.aspx
__________________
02' GMC CCSB
  #7
Old 08-02-2011, 08:49 AM
FNG
Default
Thanks. I guess only the transfer case is bad then? Transmission should be okay?
  #8
Old 08-02-2011, 09:54 AM
Mike L.'s Avatar
Default
Quote:
Fix the TC first and see where that gets you. One step at a time.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #9
Old 02-18-2015, 02:06 PM
Mike L.'s Avatar
Default
Quote:
Originally Posted by greenduramax View Post
Ok guys needin help.....i have an 03 duramax with the 5 speed allison....ive had a chip on it since ive had it no problems....recently i changed the oil in the transmission all of a sudden it started throwin 0700 and 0735 and limpin 5th...pull the chip off its fine! Whats goin on?
You beat the snot out of it. Probably burnt clutches.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #10
Old 02-18-2015, 06:00 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
You don't say.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #11
Old 02-19-2015, 09:47 AM
Mike L.'s Avatar
Default
No had it looked at transmission is fine. And why is it you people cant answer without being smart?
Is this a test?
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #12
Old 02-19-2015, 10:08 AM
56taskforce's Avatar
56taskforce 56taskforce is offline
Default
I think I am tested every time I am here or I feel like I should be tested every time I leave here.
__________________
2006 GMC 3500 CCLB- Danville stage 2 3794,Banks CAC, DHD 3" super high flow intake & 3" hot side pipe, FASS Titanium 150,PPE ported fuel rail & cp-3 inlet fittings, Nicktane/Cat, PPE race manifolds & up pipes, 4"MBRP duel exhaust, 3"PPE down pipe,4.56 gears,Yukon Grizzly locker, Suncoast GMax6 & Goerend R with Mike L springs, PPE deep pan & PTO covers, 1piece aluminum drive line with 1480 u-joints, tuning by Kory Willis and an S-480 waiting introduction to Mark's stg 2.
PLANS:60% over injectors, Sportsman CP-3
Semper-Fi
  #13
Old 02-19-2015, 11:05 AM
ALLY Fox's Avatar
ALLY Fox ALLY Fox is offline
Old Man Truck
Default
My vote: burnt clutches. You can't tell by having your transmission "looked at" unless your expert looker has Xray eyes just like Superman does. Did you send the fluid out for analysis? What tests were performed to reach that conclusion?
__________________
Basic old man '04.5 Sierra SLT long CC tow rig, EFI Live by Rob, trans by Mike L, Magnaflow DP, Airdog II 165, Ride Rites, LBZ MP, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W GN & Companion, Prodigy P3 and some other stuff but I can't remember what it is...
  #14
Old 02-19-2015, 11:10 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Quote:
i dunno, i mean, i have them there calibrated eye balls. every time i look down i see 12". strangely the wife doesnt agree but i feel her eyes are not as calibrated as mine
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #15
Old 02-19-2015, 11:22 AM
Mike L.'s Avatar
Default
P0735 can be caused by speed sensor, transfer case ( loose tone wheel ) or damaged clutch pack. If the problem is speed sensor or transfer case; removing programmer will not make a difference. It will still act up. If the clutch pack is weak; removing power can make a difference. If you had a weak trim solenoid; there would be more codes and other gears slipping.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
