  #1
Old 07-17-2011, 11:41 AM
Duramax 6.6L Duramax 6.6L is offline
Diesel Nut
Exclamation ECM Loss Communication
While flashing a 2007 Silverado Classic with a LBZ, EFILive lost communicating with the ECM half way through the programming.
Now I am getting the error message of no data received. It is as though the ECM is gone. The body control is showing a code U1000.
I have checked all the fuses, made sure batteries a fully charged, checked all grounds, unplugged ECM connectors and checked for problems.
If I look for the vin number with the V2, their is no vin number, but the computer does show operating sys # 12597107
If you look a the GPM CVN it shows:
part# 00000000 cvn# 0708
Part# 00000000 cvn# 88F6
I can still read the tcm, tcm shows vin number.
One other thing that I noticed is that the fuel guage shows no fuel and if you turn the key to crank the engine over, nothing happens.
Any ideas how to fix would be greatly appreciated.
Frank
__________________
Burn Rubber - Not Your Soul
2015 GMC Denali Crew Cab Diesel
LML Duramax Vin Specific Tuning Files Available
2012 Dodge Crew Cab Dually Cummins
2011 Silverado HD3500 Crew Cab Diesel
2007 Silverado Classic K3500 Crew Cab Dually
EFI Tuned / Tie Rod Sleeves / Steering & Idler Braces
2-Fast 150 Lift Pumps / 5" Exhaust - Muffler Delete
2006 Silverado Crew cab
2001 Silverado Crew Cab
  #2
Old 07-17-2011, 11:42 AM
Gmclbz's Avatar
Gmclbz Gmclbz is offline
Default
Have you tried a full reflash?
__________________
11.57@116
7.31@94
  #3
Old 07-17-2011, 11:44 AM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
smokinum
Default
disconnect the grounds on the battery for a few min., re connect them and the truck should be fine.
__________________
(Russ) NorCalTruck.com
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #4
Old 07-17-2011, 11:46 AM
Diesel Nut
Default
Quote:
Originally Posted by RPM Motorsports View Post
disconnect the grounds on the battery for a few min and the truck should be fine
Already tried disconnecting the batteries, no difference, Even left them unhooked over night and tried again in the morning, no difference.
__________________
  #5
Old 07-17-2011, 11:49 AM
Diesel Nut
Default
Quote:
Yes I tried a full flash, I get the error message ( no data received )
When watching the screen, show as ECM not detected.
__________________
  #6
Old 07-17-2011, 11:50 AM
smokinum
Default
I had one truck (LLY) that did this as well. do an emerg. re-learn on it. http://www.duramaxdiesels.com/forum/...rgency+relearn
__________________
  #7
Old 07-17-2011, 12:16 PM
Diesel Nut
Default
Did not work
__________________
  #8
Old 07-17-2011, 12:25 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Default
is it getting power to the ob2 port?
__________________
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
  #9
Old 07-17-2011, 02:37 PM
Diesel Nut
Default
Quote:
Yes it has power to the OBD port
__________________
  #10
Old 07-17-2011, 11:12 PM
8100 Power 8100 Power is offline
FNG
Default
Have you tried connection the scan tool to it and seeing if it responds? Seem to get me out of a similar situation when I flashed my dads LMM and it failed..
__________________
Jeff
SOLD
06 LBZ
11 LML
  #11
Old 07-17-2011, 11:36 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
Quote:
x2 reading has unlocked if you will my ECM from failed flashes... shit ive probably have a flash failed 15-20 times lol these ECMs are hard to kill
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #12
Old 07-20-2011, 05:22 PM
Diesel Nut
Default
Scan tool can not connect to ecm either. Tech II is not able to connect or read. The odd thing is that my Snap on Pass Thru Pro can comunicate with the ecm. Can search for codes and comes up that ecm needs operating software installed.
I will post more as I test and find out what happened.
__________________
  #13
Old 07-20-2011, 07:46 PM
paytonlb7's Avatar
paytonlb7 paytonlb7 is offline
Owner at Torq Industries
Default
I've ha this happen on my lbz when trying to monitor egt's with a bully dog watch dog. Try removing the snap on pro and reflash it again.
__________________
Owner at torq-industries.com
07 LBZ, Suncoast GMAX, Reybestos, 1054 Converter, EFI live, Edge insight CTS, Diamond Eye DP, 4" straight pipe, 6" mitre cut stack,
  #14
Old 07-23-2011, 10:34 AM
$Smokin_Duradog$'s Avatar
$Smokin_Duradog$ $Smokin_Duradog$ is offline
Default
Unplug the body control module for a few minutes then plug it back in. Has worked for me in the past.
__________________
2005 LLY CCSB 4x4, 12" Lift 40"x15.50"20" Nitto Mud Grapplers on 20"x12" MHT Fuel Offroad "Throttles" (Black/Machine Mill), Stage 4 trans ATS Converter, Dual 6" Chrome stacks, NFab nerf Bars, DiProcol Guages, 78 Ford Front Dana 60 Trussed/4 Linked/ w coilovers 4 Linked rear trussed 11.5" AAM. Road armor winch bumpers front and rear. EFI Live
  #15
Old 07-28-2011, 05:07 PM
Diesel Nut
Default
OK this is what happened, There is a bug in the V8 program that can cause this to happen. The bug has been fixed with the latest beta and firmware. Only problem is that I am stuck with an ecm that is not programmable.
Trying to find out if there is a fix to make the ecm usable again.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
