#1
I have an LLY/Allison that was originally from a 4wd model, but I have replaced the factory 261XHD with a 241/241 doubler. I have very limited knowledge about the electronics on these trucks/transmissions, will I need to do anything sensor wise for this to shift properly in 2wd, 4wd or double low with the factory case missing? Maybe add a VSS to the tailshaft in the Allison so that it will continue to shift regardless what range it's in???
__________________
1985 S10 extended cab longbed with an LLY/Allison/241/241, Dana 60, 14 Bolt, Air-ride and 38's. |
#2
the allison MUST have an output speed sensor present, otherwise you'll never make it out of 1st gear.
Im not sure how it would work with the doubler...since the TCM is only designed/programmed to work with a 2-range transfer case. If the TCM sees a gear ratio its not programmed to expect it will immediately limp.
__________________
2005 chevy dmax/allison - "HOT AND DANGEROUS" - built engine and trans with parts/advice/help from the best...MikeL.Trippin.Schulte.IdahoRob.TimHecker-St.JoeDiesel.McRat.juddski.dmaxfireman.BigDipper.M PI.Bobo.GMC-2002-DMAX.fingers.RickDLance.dmaxalliTech.EFILive...sor ry no times yet, I just wanted to reserve the truck-name BT DieselWorks, LLC - Full transmission/engine builds - EFILive tuning - full service for GM gas/diesel trucks and SUVs - Allison lockup controllers - Allison tapshift kits - dmax/alli/GM gasser standalone harnesses - custom truck electronic gadgets All products available for sale through our online store at www.btdieselworks.com Be sure to "like" us on Facebook at www.facebook.com/BTDWorks |
#3
Will placing the sensor in front of the cases keep it happy? I don't really care if the speedo is correct when in either low range.
__________________
#4
Yes
__________________
06 Silverado 4x4 CC/SB 11.13 @ 123.5 <---The good old days 06 Express 2500 Duramax Van "The Dumpster" 11.57 @ 115.6 |
#5
This will be how you must do it. Search at pirate 4X4 for the post of how I believe pussow did it with his 205. Also the guy that built the DURAMAX search and recovery buggy also installed his TOSS in the transfer case housing before the transfer cases(he used a SUNCOAST housing though to avoid the cracking problem).
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, 3.42 gears, 261 T-case Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4 and a PI ML converter DIAMONDEYE 4" exhaust with a CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump and pump rub kit.
#6
Ok guys, thanks for the input.
So lets see if I understand this correctly. BTW, these are Okie terms, lol. Since the Allison is "keeping track" of the RPM's coming into the tranny, in the middle and as it exits it's able to tell that something isn't right when the final sensor isn't rotating at the speed that it's pre-programmed to be at? Except when you have it believing it's in low range on a 4wd model, but for only one low range because the doulber would throw it off again?? If that makes any sense to you guys and I can use it with it in low range in the 1st transfer (same reduction as factory 261) and everything shift as it would have stock while in low range, could I mount the sensor between the 1st and second case as it would have been in the stock transfer and have perfectly normal shifts and an accurate speedometer when in high and single low range and then just throw the speedometer off when it's locked in double low? Make any sense? If I can fit it there I won't have to fool with the Allison tail housing or output shaft.
__________________
#7
Ok, I'm just thinking here, so bare with me. I read that the low range gear ratio can be changed with EFI Live, so would it be possible to place a speed sensor just after the 1st case (as mentioned in the last post) and make it think that it is a factory setup from a 4wd model, then add another speed sensor to the rear of the second case (which it already has) and wire it so that it can be switched manually from one to the other from inside the cab. Then when I am doing my EFI Live tuning I will do a "Crawl" tune where I will tell it that the low range gear reduction is 7.40:1 and just manually switch between the two speed sensors when in and out of that "crawl" tune. Could that work?
My electrical skills are somewhat limited, so I really don't know if any of that is even possible, but if it is wouldn't that get me a fully functioning Allison in 3 different ranges with an accurate speedometer in every range??
__________________
#8
Or you could just run one speed sensor. The ECM / TCM is only looking for a signal to tell it what the slipping inside the transmission is while in overdrive and TC locked.
If you are running the ABS, then there will be a complete different issue to deal with. IIRC the ABS light will stay on since it also reads signals from the Trans sensor and the wheel sensors. If they are different, then it does strange things. Since I see it is in an S10, it may not have the ABS.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold. Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install. EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe). Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission. ----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.---- Added to the family 06 GMC CCSB 2WD LBZ SLT package. Upgrades will follow. |
#9
Quote:
__________________
#10
Quote:
The TCM is constantly calculating the ratio between the turbine speed sensor and output speed sensor. If the calculated ratio doesnt match the intended/programmed ratio, the TCM will limp. Meaning, if, in 1st gear, the ratio/difference between the turbine speed and output speed is anything other than ~3.10:1 (the first gear ratio in an allison), the TCM will detect this as trans slip, and go into limp mode. Remember this ratio calculation has nothing to do with converter slip. Its measuring turbine speed and output speed when it does this "ratio calculation". Turbine speed is POST CONVERTER. Turbine speed is NOT THE SAME as "input speed". Quote:
__________________
#11
Duratothemax is right about the ABS, it hasn't ever and won't ever have it.
It is driven nearly everyday when it isn't under construction though.
__________________
#12
One more question guys, I have seen references to cruise control modules here and there, is this something that I will need to make the cruise work or does it have everything with the ECM, TCM, BCM and the factory full size harness and steering column intact?
__________________
#13
You don't need anything else, just simply wire in a cruise control switch to the ECM.
__________________
#14
It has the factory cruise switch in the '05 full-size column that I'm using, will that do it?
On a side note, what kind of mileage have you been getting since the Duramax swap? I think I finally figured out how to simplify the wiring to the point that I can actually make it work, lol. I ended up using the PDC, the cluster, the dash harness and the steering column from an '05 Duramax. That way it seems like it is basically a plug and play. I actually went ahead and plugged it all in today and powered up the cluster, did the relearn for the Passlock and cranked the engine. Now I just need to permanently mount/route everything. Finish the fuel and tranny lines/cooler and mount the VSS sensor and reluctor ring. Oh, one more thing, what controls the Odometer? My engine/tranny has 90,000, but my ECM, BCM, TCM, and cluster are from a truck that had 396,000 on it, is there a way to get it to what is one the engine? BTW, thanks for all of your assistance through out this little undertaking.
__________________
#15
mileage is stored in the cluster ONLY.
The only way to reset the mileage is to buy a new cluster (or used one with lower miles in it) or send the cluster to a speedometer shop.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
