  #1
Old 06-28-2011, 09:06 AM
TrueStreetVW's Avatar
TrueStreetVW TrueStreetVW is offline
FNG
Default Driveshaft carrier bearing.
Is there any difference between the 2wd and the 4wd carrier bearings? I can only seem to locate one for a 2wd and don't wanna spend the 165 dollars at the stealership. Thanks in advance. Sorry if this isn't the right place for this question.
  #2
Old 06-28-2011, 10:34 AM
Grizzly5531's Avatar
Grizzly5531 Grizzly5531 is offline
Super Slow
Default
Post a picture of your's and I will compare it to my 2wd one when I get home tonight.
__________________
05 GMC Sierra CC/LB Dually
4" MBRP
Home brew lift pump
EFILive By Idaho Rob, Thanks to Holton at Alligator Performance
14.482 @ 93.93 AUG 13 My tuning (sucks)
  #3
Old 06-28-2011, 02:48 PM
Canadian Cowboy's Avatar
Canadian Cowboy Canadian Cowboy is offline
Gearhead
Default
There is no difference between the 2 and 4 wheel drive the carrier bearings are the same.
#32
GM 09436881 CK2(ML6,M74 BEARING,DIFF(INCLS CUP & CONE)(TIMKEN)(387AS-382A)(2.250 INCH ID X 3.812 INCH OD X .826 INCH THK)(5.855)(ACDelco #387AS/382A)
CC
__________________
2008 GMC 3500HD SLT CC 4X4 SRW Nav,Rear DvD,Sunroof,Loaded
  #4
Old 06-28-2011, 02:58 PM
Super Slow
Default
Where in that schematic does it show a driveshaft carrier bearing. Correct me if i'm wrong but he is referring to the Bearing that goes between the two piece steel driveshafts.
__________________
4" MBRP
Home brew lift pump
  #5
Old 06-28-2011, 03:04 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Default
I did a fast look and they all look to be the same.They do offer a few different ones from National Bearing.
__________________
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
  #6
Old 06-28-2011, 03:05 PM
Gearhead
Default
Carrier bearings hold the carrier in the pumpkin in the diff as I posted.
A center drive shaft bearing is called a center support bearing or some people call it a hanger bearing it is not called a carrier bearing.
#6 BEARING,PROP SHF CTR SUPT
CC
__________________
  #7
Old 06-28-2011, 03:20 PM
Super Slow
Default
__________________
4" MBRP
Home brew lift pump
  #8
Old 06-28-2011, 03:22 PM
Super Slow
Default
Those are pics of a two wheel drive driveshaft CARRIER BEARING there's a million names for everything google carrier bearing and atleast half the hits on the first page are for Drive shaft carrier bearings. But thats besides the point.
__________________
4" MBRP
Home brew lift pump
  #9
Old 06-28-2011, 03:37 PM
Gearhead
Default
Quote:
When I read his post he stated Carrier Bearings not carrier bearing meaning to me as I read it more than one bearing.The driveshaft on his and your truck only has the one bearing not 2 or more on the driveshaft so I took that fact that he was talking about the carrier bearings in the Diff.I was only trying to help the member out.
__________________
  #10
Old 06-28-2011, 03:39 PM
Super Slow
Default
I understand the miscommunication but the title does say Driveshaft carrier bearings.
__________________
4" MBRP
Home brew lift pump
  #11
Old 06-28-2011, 03:45 PM
Gearhead
Default
Quote:
You are right,I didn't see till just now reading your post,Had I seen that I wouldn't have posted the diff pics.I usually try to make sure my info is correct when I post.O well he has some diff pics as well now.
CC
__________________
  #12
Old 06-28-2011, 03:46 PM
Super Slow
Default
No biggie
__________________
4" MBRP
Home brew lift pump
  #13
Old 06-28-2011, 04:08 PM
FNG
Default
Thanks guys. Sorry for the confusion. So I will just get the 2wd bearing. Thanks so much.
  #14
Old 06-28-2011, 05:04 PM
ripmf666's Avatar
Default
When you have time fill out your sig for what year truck you have helps everyone out.
__________________
Name to come
  #15
Old 06-28-2011, 05:08 PM
FNG
Default
Will do Henry.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
