  #1
Old 06-18-2011, 01:33 PM
CHYKYNLIPS CHYKYNLIPS is offline
GA Diesel
Default Steering gear box service?
is there any way to (or need to) pack grease in the lower section of the gear box? I have the pitman off to install the dmaxstore steering package. i pulled out the rubber boot/seal and noticed there is grease in there. just wondeing while i have it apart....thanks guys.
edit...i had a blonde moment. is there a grease zerk on the base of the box? im not at home now to look.
__________________
07.5 LMM, ccsb, Z71
MBRP 5", Diamond Eye DP
Banks Ram Air, Edge Evo Race
EGR blocked, PCV Reroute, Transgo Jr.,
Mag Hytec Rear Diff., Fabtech 6" Lift,
18X9 Diamo 8 Karat, 35X12.50 Toyo M/T
  #2
Old 06-18-2011, 09:18 PM
brunok's Avatar
brunok brunok is offline
jngahsfvjkafui
Default
The steering gear box and bearings are lubricated by the power steering fluid. No grease fittings on the box
__________________
05 2500 EC/SB 4x4
EFI Live, DSP5, Straight pipe, AFE MP, PCV reroute,
PPE overhead gauges, turbo down pipe
285/75/16 Duratracs
  #3
Old 06-19-2011, 03:54 AM
GA Diesel
Default
Right...i didnt know why there was all of the blue grease around the output shaft when i pulled the seal down and off of the shaft. I just squirted some grease up in there and slid the seal back on. maybe just serves as adust/debris catcher in case any trash or moisture gets by the seal. thanks
__________________
07.5 LMM, ccsb, Z71
  #4
Old 06-19-2011, 08:21 AM
brunok's Avatar
jngahsfvjkafui
Default
Well it shouldn't hurt. I used to grease the bearings before installing so that probably explains why there is grease there. But when I disassembled boxes I'd say 95% had no grease on the bearings, just PS fluid.
The rubber boot u say u pulled are u talking about the seal above where the pitman arm would attach?
__________________
05 2500 EC/SB 4x4
285/75/16 Duratracs
  #5
Old 06-19-2011, 12:07 PM
GA Diesel
Default
yes, thats the one. i didnt pull it off for any particular reason. i just saw that it would when i pulled it back down so i was curious. i had slid it up earlier as to not damage it with the pitman arm puller.
__________________
07.5 LMM, ccsb, Z71
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
