  #1
Old 06-17-2011, 12:14 PM
Gmclbz's Avatar
Gmclbz Gmclbz is offline
Default Injector Cups
Maybe this question has been asked, it may be a stupid question...has anyone ever tried green Loctite to seal injector cups? The green Loctite is a sleeve retainer. Just a thought or maybe I am way off base here...just thinking out loud.
__________________
11.57@116
7.31@94
  #2
Old 06-17-2011, 12:22 PM
madmatt's Avatar
madmatt madmatt is offline
Default
I've yet to really see an issue with the red and I'd be afraid of fighting the cups if you ever needed to get them out.
__________________
BLACK 05 CC/LB LT 3500 SRW,,,,,,
  #3
Old 06-17-2011, 12:30 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
Quote:
The lock tight really wont make it any stronger , its used as a sealant not nec a retaining method, it cant hurt but as Matt said you may regret it if you ever have to pull them out .
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #4
Old 06-17-2011, 12:34 PM
madmatt's Avatar
Default
Quote:
true this,, the injector holds them in place while running. That green is BAD shit and i wouldn't use it anywhere i didn't have to. We used to use it at Cat to hold bearings and dowels in loose bores and I've ruined bearings getting them back out
__________________
  #5
Old 06-17-2011, 01:27 PM
duramini2001 duramini2001 is offline
On a Time Out
Default
I have always ran the green loctite, since i started using the green i have had not a single problem with cups, ive prob used it on 90 motors or more, if you do it write the first time with green and hold downs and studs you will never have to worry about pulling the cups. thats my input tho, hope it helps
  #6
Old 06-17-2011, 02:39 PM
Gmclbz's Avatar
Default
Thanks guys, something I have thought about few times and had me curious...
__________________
11.57@116
7.31@94
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
