  #1
Old 06-07-2011, 11:40 AM
jkaps jkaps is offline
FNG
Default Brake controller fuse
Hey everybody, I got an 06 3500 sierra and was wondering is there a fuse or breaker for the brake controller. I know if you don't use the factory wiring harness pigtail you have to put a breaker inline somewhere. I put the P3 in and it had a premade harness that goes from the controller to the fuse box and i can't find the fuse or breaker. Any help would be greatly appreciated
__________________
06 GMC cclb drw LBZ, transgo jr, pump rub mod, diamond eye downpipe, PPE deep trans pan, line-x, B&W turnover ball & 5th wheel adapter, pcv reroute, BD exhaust manifold, MBRP 5" SS downpipe back exhaust,EFI live by Idaho Rob w/dsp5 switch,EGR blocked,Air Dog II 165, PPE race valve,EDGE CTS insight monitor,MAG-HYTEC rear diff cover,bilstien 5100's,AFE stage 2 intake
02 Dodge qbsb 2500 6 spd cummins Smarty,egt/boost/fuelpressure gauges, fass pump, volant airbox, cipa mirrorrs,line-x,bilstien 5100's mag-hytech rear diff cover,adjustable boost elbow
84 Chevy K30 srw restored inside and out to much to list, occasional sled puller
82 Chevy K30 drw work truck/beater
  #2
Old 06-07-2011, 02:33 PM
trailerpro's Avatar
trailerpro trailerpro is offline
Junior Member
Default
It should be pre installed at the factory, it is under the hood labeled either stud #2 or Aux B. The fuse that everybody talks about adding is Stud #1 or Aux A which is for the 12V + circuit in the trailer plug, not the brakes.
__________________
Truck pulling videos:
http://www.youtube.com/user/trailerpro
2004.5 Chevy cc/sb lly/ally 4x4 LT sled puller
2004 GMC 2500 4x4 cc/sb slt quadrasteer
2011 Chevy LML 2500 4x4 cc/sb LTZ
2011 Chevy LML DRW 4x4 ext/lb LTZ
  #3
Old 06-07-2011, 05:18 PM
FNG
Default
thanks for the reply, so if i am understanding correctly there is a fuse that controls the entire plug?
__________________
  #4
Old 06-07-2011, 06:03 PM
trailerpro's Avatar
Junior Member
Default
Well the aux A(or stud 1) fuse is just the constant hot (trailer battery charge) in the plug. It's the terminal in the upper right corner of the 7-way plug. Aux B(or stud 2) fuse is just for the power feed wire under the dash for the brake controller.
__________________
  #5
Old 06-08-2011, 11:13 AM
FNG
Default
thanks, I"ll take a look today
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
