  #1
Old 06-05-2011, 03:33 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default How do you remove stuck injectors?
My #1 and #2 injector are stuck. I was able to get the #2 injector to come out an 1/8 inch and it will not budge. I was using an 8 foot breaker bar on a pry bar placed in between the valve cover and injector hold down.
Any body have any ideas?
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #2
Old 06-05-2011, 05:15 PM
jneal's Avatar
jneal jneal is offline
Default
Is this on the LMM in your sig? And why are the injectors being removed?
__________________
TOW RIG: 1996 Dodge club cab 12v
TOY: 2006 Reg cab LMZ/ally 4x4
FLEECE PERFORMANCE ENGINEERING
  #3
Old 06-05-2011, 05:17 PM
gmduramax's Avatar
Shits broke
Default
Quote:
Yes it is. I'm getting SoCal 100% overs
__________________
10.98@124mph
  #4
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
an 8 foot breaker bar SHOULD work
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #5
Old 06-05-2011, 05:19 PM
gmduramax's Avatar
Shits broke
Default
Quote:
Sadly it didn't. Don't know why there stuck. Isn't the first time they came out.
__________________
10.98@124mph
  #6
Old 06-05-2011, 05:24 PM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
Default
My #7 was stuck pretty bad. Try putting the fuel line back on the injector and using that to hold onto. Wiggle it, turn it, rock it ,whatever movement you can get it to make is good. We fought with it for about 15 minutes but it eventually worked itself loose. Mine had rust on it. I think it was caused by me & my pressure washer.
__________________
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
  #7
Old 06-05-2011, 05:49 PM
schulte schulte is offline
Default
Quote:
x2 on the fuel line as a handle. You can't pry it out with a prybar/extension bar. If you pry up on the hold-downs they just twist and you aren't pulling at the right angle.
You could also buy one of these, although I've never need to use one.... http://cgi.ebay.com/ebaymotors/OTC-J...c#ht_499wt_957
__________________
2004 CCSB LLY
  #8
Old 06-05-2011, 06:01 PM
jpowel29's Avatar
jpowel29 jpowel29 is offline
Default
Heat will liquify the carbon build up - that is what finally freed a stuck injector in mine. The injector loosened up during a race and I simply re-torqued it back in place (thinking nothing about). Once I took the motor down for maintenance over the winter, it was stuck. I guess the copper washer didn't re-seat properly and the injector bore had enough carbon build up that the injector removal tool wouldn't budge it.
__________________
Trying some new things...
  #9
Old 06-05-2011, 06:06 PM
gmduramax's Avatar
Shits broke
Default
Quote:
What did you use to heat it with?
__________________
10.98@124mph
  #10
Old 06-05-2011, 06:39 PM
jneal's Avatar
Default
Quote:
Wow. Usually just takes a small screw driver under the hold down to pop them out, that is if they don't come out by hand. But a 8ft cheater on a prybar is definately in the category of STUCK! I've never had one stuck that bad.
__________________
  #11
Old 06-05-2011, 07:50 PM
jpowel29's Avatar
Default
Head was removed - had to cut around lower vc - very small tip on gas torch - and an infrared thermometer to make sure we heated everything evenly. Worked very well and help clean out the injector bore nicely. Everything checked out well on the heads and they are back on running again.
__________________
  #12
Old 06-05-2011, 09:19 PM
gmduramax's Avatar
Shits broke
Default
Looks like I'm pulling the heads. Thanks for the help.
__________________
10.98@124mph
  #13
Old 06-05-2011, 09:28 PM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
We just had this problem on an 05. Used tons of penetrating oil, put the fuel line back on and used a pry bar between the fuel line and injector top to twist in back and forth as someone else used a big ass pry bar under the hold down. We ended up breaking the hold down and trashing the lower valve cover. We put a 4x4 block on the frame under the injector to pry against and it seemed to help.
http://www.duramaxdiesels.com/forum/...ad.php?t=31888
__________________
02' GMC CCSB
  #14
Old 06-05-2011, 09:37 PM
gmduramax's Avatar
Shits broke
Default
Might give this a try. I was thinking about welding a hook to the injector line and pulling up on it with a cherry picker.
__________________
10.98@124mph
  #15
Old 06-06-2011, 12:24 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
I broke the tit off of mine. It's pretty much useless if there rusted or packed with carbon.
I still think the slide hammer idea will work...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
