  #1
Old 05-29-2011, 06:03 PM
jmaz268's Avatar
jmaz268 jmaz268 is offline
Lead from the Front
Default Best way to do LB7 studs/gaskets in truck
So I'm going to do my studs/gaskets before Numidia in July.
Have no access to lift so body can't come off and don't have an cherrypicker or engine stand......so that eliminates that.
They way I was thinking was to take off the normal studs and disassemble and then clean the threads on the block before I start.
Then tape the new studs in the head so when I drop it on so that I dont have to worry about clearance of trying to drop the heads onto the block with the studs sticking up.
Only side I see being an issue is the driver side with all the crap in the way.
Was curious to see everyone thoughts on it.
John
__________________
John
http://www.duramaxdiesels.com/forum/signaturepics/sigpic5837_2.gif
  #2
Old 05-29-2011, 06:12 PM
THEREDDEVIL's Avatar
THEREDDEVIL THEREDDEVIL is offline
A Bad seed
Default
John I wonder if u could thread the nuts on the studs and drop the heads and all onto the block? Just throwing out an idea.
__________________
Jeremiah
2006 red Chevy cc/sb 4x4 dead devil
12.8 @ 105
2000 gmc 2500 6.0 gasser
1977 silver Chevy vega drag car-ready for LS/turbo.
2011 Harley Davidson super glide custom-Vance and Hines.
  #3
Old 05-29-2011, 06:15 PM
jmaz268's Avatar
Lead from the Front
Default
that could work instead of taping them in place and then just unthread the nuts when its in place.
__________________
John
  #4
Old 05-29-2011, 06:16 PM
delong_1's Avatar
delong_1 delong_1 is offline
<< my work
Default
i did mine one at a time the first time, the next time when i pulled the heads i just set the pass side head on and used the dowels to keep the head in place until i could start droping the studs in. the back lower stud is best put in the head before you set it on the block, it hits the firewall if you try putting it in after. otherwise you will have to tilt the motor forward so it will go in.
__________________
2012 ccsb: ATS compounds, built trans, copilot, ATS twin pump kit, fass 150, etc
2001 ecsb: sold
1016. 10-15-11
7.13@100
11.27@105
  #5
Old 05-29-2011, 06:17 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
If you can get up here we can do it in my garage on the lift,just did a buddies truck with it in the truck(02 lb7) ported heads with arps didnt have to pull the turbo either.dont have to tape the studs in you can get em in after you set the head on
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #6
Old 05-29-2011, 06:18 PM
jmaz268's Avatar
Lead from the Front
Default
thanks Nate.....how did the drivers side go?
__________________
John
  #7
Old 05-29-2011, 06:20 PM
delong_1's Avatar
<< my work
Default
sorry didnt specify well enough, the stud that hits is on the drivers side. the pass side, at least with my setup is free and clear.
__________________
2001 ecsb: sold
1016. 10-15-11
7.13@100
11.27@105
  #8
Old 05-29-2011, 06:21 PM
jmaz268's Avatar
Lead from the Front
Default
Quote:
That would be awesome....I'd be down if its ok with you.
Looking to do in the first part of July, but will have to be a weekend unless I take off work. Which is a good possibility.
__________________
John
  #9
Old 05-29-2011, 06:23 PM
Default
Not a problem let me know what weekend is good for you
__________________
  #10
Old 05-29-2011, 06:33 PM
jmaz268's Avatar
Lead from the Front
Default
Quote:
I'm guessing mine will be the same way.....Pass side is very open and clear looking once the valve covers are off.
__________________
John
  #11
Old 05-29-2011, 06:44 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
pulling the fenders off makes life easier also.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #12
Old 05-29-2011, 07:01 PM
Default
Quote:
That sounds like a pain but then again its no pic nic doing it with them on either
__________________
  #13
Old 05-30-2011, 01:46 AM
jmaz268's Avatar
Lead from the Front
Default
Thanks again guys....
Looks like Scott is gonna hook me up with a lift and a place to lay my head while I do it....
The DMAX community is amazing if i havent mentioned that.
__________________
John
  #14
Old 05-30-2011, 06:04 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
Lifting the cab is the easiest way. The parking brake cable is the only pain if you don't just cut it
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #15
Old 05-30-2011, 07:36 AM
xcablb7's Avatar
xcablb7 xcablb7 is offline
Default
Second from lifting the cab is just pulling the motor that's how I do mine took about 14 hours to take it out tear it down clean everything put it it back in an fire it up
__________________
04 LB7 Denali conversion
626 h.p 1142 tq 5-8-2010 a5k, stock cp3
gt 4088r, gt4718 twins,
custom cam, 15.5:1 forged mahle w/ reliefs
ppe dual fuelers w/ lbz pumps 80% extrude hone inj
837 h.p. 1380 tq 5-14-11
11.40 @ 125.5
Thanks to Toman tysmith and Justind
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
