#1
which one would i need to support about 600hp for now and maybe up to 800 in the future? or any other pump recommendation?
I was looking at Kennedy but for the price and filter combo Airdog seems better...
__________________
05 2500 EC/SB 4x4 EFI Live, DSP5, Straight pipe, AFE MP, PCV reroute, PPE overhead gauges, turbo down pipe 285/75/16 Duratracs
#2
I think that the AirDog 150 is the best bang for the buck. It has the same 150 gph pump as the AirDog II 165. The selling points of the 165 are that it is "easier to install" and has an adjustable pressure regulator. To install it you can do it without lifting the bed or dropping the tank because it doesn't have a draw straw. However with the new quick connect style AirDog 150s you can easily install them without the draw straw if you choose, and if you choose to do so on either you run the risk of sucking the fuel basket in the tank dry faster than what fuel can get into it at low tank levels - making the truck hard to start and hurting performance when you are low on fuel. For the 165 the remedy is to remove the tank or bed and pull the sending unit to drill holes in it so it can fill faster, so there goes the "easier installation". The adjustable pressure regulator is supposed to come preset at the same 9-12 PSI that the AirDog 150 comes with. If you adjust it too much higher it will start to cause idle issues, so what's the point of having it adjustable.
I had an AirDog 150 on my truck installed per the instructions during my 10 second passes - I think it will be plenty of fuel for your 600-800 rwhp goals.
__________________
Dustin 05 Chevy ECSB SS, DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only 835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09 DIESEL POWER CHALLENGE 2010 - 3rd Place Coasted to a 10.74 before retirement to street truck status. |
#3
thank you, that helps alot and was a great reply.
__________________
#4
And he sells them.
EDIT: Oops, didn't realize Dustin wasn't a vendor here anymore. I coulda sworn he was. Sry.
__________________
Mitch 02 Chevy 2500HD D/A EC SB LS SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, 5% tint, partially debadged , Rhino Bed Liner, Cheap Junk Air Intake, SuperDiesel Intake Manifold and Ported Turbo Inlet, 16x8 Eagle 194s w/ 265s1983 GMC K30 CC SHORT BED ![]() 4wd pulling truck awaiting LBZ Dmax/ZF6 conversion...
#5
I can tell you how much better it is to have the draw straw,when i installed my airdog 150 i got the draw straw with the kit i bought so i said what the hell and put it in,when efi was installed in my truck it was the same as the hot +2 eliminator on setting 10 the 425 h.p. tune and we had to take the fuse out as the key had to stay on.well we forgot to put the fuse back in but my truck never missed a beat,we tested it on every tune hard and i was on it hard on the way home and i never lost fuel pressure and the cp3 had to suck thru the pump that wasnt pumping!!! Put the draw straw in
__________________
04 LB7 CC/SB EFI live, dsp5 switch, 4 inch Magna flow, Industrial Injection S366,S483 , keystone ram air hood,Big Dipper trans,MBRP hot side IC pipe, rolling on hummer wheels with 315/70/17s wraped in silverbirch.Carillos, keyed cam, and crank, ported heads,ARP crank and head studs, RDL manifold and uppipes, coated lb7 pistons and some other goodies. Born again 08/10/2011 11.64@117 ![]() Some wicked tuning by Bo-Bo (Bob olson) Thx Bob ![]() Quote: Originally Posted by flyinelvis11 i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h Quote: Carter 44 Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences rollncoal07:Twining is wining ![]() Originally Posted by coker6303 My trucks not a whore...she doesn't lift her skirt for just anyone! |
#6
I have a ADII-165, I like the adjustable feature, I did not use the draw straw, I did drill the cup.
I just got fuel, 33.22 gallons in a 34 gallon tank and had no issues whatsoever with fuel starvation. With the draw straw you screw yourself once the tank level gets low, forget about running down to almost empty. As far as install, if you have to raise the bed it is way easier than dropping the tank.
__________________
2007 GMC "Classic", LBZ, SLE1 ,RC/LB, 4x4~Powered By "MOONSHINE" 12.525 at 107.07 mph for now 2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE" |
#7
Sorry for the off topic, but where are yall drilling the cup? Around the base? Would a billet pickup be adequate?
__________________
James 05 LLY CC/SB 4x4 EFI Live, ML Built Trans, Precision Converter, ADII 165, ATP DSP5 Tuning and some little mods. 2011 Camaro 1SS/RS 6.2L 6 Speed Manual SoCal Diesel Trucks |
#8
Quote:
I installed the draw straw and have run my truck within a 1/2 gallon of empty without issue. Also it takes 10minutes to drop the tank and you dont need a extra set of hands like you will if you pull your bed, JMHO.. Heres a pic of how I cut some slots on the draw straw...![]()
#9
I did the Hellman sump instead of the draw straw with the AD150 on my truck so I wouldn't have to worry about the 1/4 tank issues. Worked great and was pretty easy to install.
__________________
2002 GMC EC/SB 1500 Daily Driver Sold: 2007 Chevy 2500HD CC/SB LTZ Z71 LMM Fully Built and Twin Everything Sold: 2008 GMC 2500HD CC/SB SLT Z71 LMM Stockish RIP: 2006 GMC 2500HD CC/SB SLT 4x4 LBZ Mild Build |
#10
Quote:
__________________
#11
I just install them without dropping the tank. I don't see the need. I've never had a problem with the lift pump holding pressure with the stock pickup.
__________________
06 Silverado 4x4 CC/SB 11.13 @ 123.5 <---The good old days 06 Express 2500 Duramax Van "The Dumpster" 11.57 @ 115.6 |
#12
Quote:
I have had to drive over an hour with the low fuel light on in my truck to find a station that had fuel; when I filled up my 26 gallon tank it took just over 25 gallons. I'm not saying that there is anything wrong with the AD II pumps, only that the extra cost is not warranted in my opinion. A new spring will adjust the pressure in the AirDog 150.
__________________
#13
The only kit that comes with the draw straw is the 150. The DF165 hooks right to the top of your stock sending unit like the 100. The 165 has dual inlet ports to allow more fuel to enter the gerotor thus pushing more fuel, also the DF or demand flow means that not as much fuel is returned to the tank, the ADII has a different base that recycles the unused fuel back through the filters to be filtered again and reused. This way the filters will have more of a capacity and less chance of draining them.
Some trucks that need the extra fuel capacity for heavy fueling motors (like the cummins killer truck) we will run an FPII class 8 unit, this will usually double the fuel capacity and eliminate any fuel recovery issues.
__________________
05 LLY stealth tuner,PPE boost controller, PPE Hot Xcel, 4" t-back 6" custom black stack, Airaid/AEM intake, air ride parallel 4 link. stock trans ![]() Thank you sponsors: XDP, BD Diesel, Raceline wheels, Silverline Exhaust, Pureflow Technologies and McGaughy's suspension. |
#14
Parking on a hill with low fuel and a draw straw is a recipe for a no-start or a stall condition.
The purpose of the factory fuel cup is so that the fuel is pulled from/returned to the same location. I am not trying to start an argument over this, just pointing out that not everyone lives in flat land and not everyone parks on a flat driveway. I have been in trucks tuning them that run with small amounts of fuel and when then accelerate the fuel goes to the back of the tank and starves the truck for fuel. To each their own I guess. As far as changing a spring, it is far easier to loosen a jam nut and turn a adjustment then dick around changing a spring to save a few $$$$, JMHO.
__________________
#15
Tony, i most certainly agree with you. Parking on a hill 90 percent of the trucks life i had too go with the Airdog 2, i have no modifications too the fuel cup. I like running my tank down too a half gallon and have no issues on a moderate incline. Airdog 2 gets my vote!
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
