  #1
Old 02-23-2008, 07:54 PM
JoshH's Avatar
JoshH JoshH is offline
Default Transmission cooler line questions
My cooler lines have been leaking for almost 20k miles. I'm really wanting to do something about it besides replacing them with stock replacements. I found some cool AN fittings that can be clamped onto a straight tube. I was thinking about doing this and replacing the rubber on the stock lines with braided stainless hose and AN fittings. The only problem is the fittings I'm looking at are only good up to 50 psi, and I'm not sure how much pressure runs through there. Anyone know?
What about the fittings that go into the cooler, anyone know what they are?
If that doesn't work I may end up taking them to a hydraulic shop and having them make me something.
Anyone have any cooler lines for an 06 or 07 classic laying around they want to get rid of?
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #2
Old 02-23-2008, 08:27 PM
chevmike's Avatar
chevmike chevmike is offline
WI Salad
Default
Same problem here. I have been looking into it for awhile too. I believe there is more than 50psi running in those lines, not sure how much. Please let me know what you figure out.
__________________
EFI Live Team Salad
5" turbo back MBRP
AFE intake
fuel shim
egr blocker
SD centerlink and sleeves
  #3
Old 02-23-2008, 08:29 PM
The Neens's Avatar
The Neens The Neens is offline
BFD
Default
I think it's more like 200psi...
__________________
2007 GMC 4WD CC/SB...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
2002 Chevy 2WD CC Dually...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
Next Taps party on ??-??-??
The sooner you fall behind, the more time you'll have to catch up...
Team Arrogance Founding Member
The Gerbil Clubs founding Member#1
"Gerbil Trainer for the Stars"
  #4
Old 02-23-2008, 08:33 PM
JoshH's Avatar
Default
Quote:
I'm afraid you're right. I kind of figured it's higher than 50.
__________________
  #5
Old 02-24-2008, 03:52 PM
coldLBZ's Avatar
coldLBZ coldLBZ is offline
Default
This summer I plan on getting some hydraulic lines made up. I'm on my 3rd set of factory lines.
__________________
Dan
2006 Chevrolet 2500HD 4x4 CC/SB LBZ Allison
PPE Hot+2 ET, S&B Cool Air Intake, MBRP 4", PCV Reroute, BD Manifold, SD Manifold, SCIV/PPE-Precision Converter/Pump Rub Fix/T-Case Brace/SoCal Diesel Flexplate By Ted @ MPL
2014 GMC 1500 4X4 RC/SB 5.3L
2008 GMC 1500 4x4 CC/SB 6.0L 4L70E - GONE
  #6
Old 02-25-2008, 11:20 AM
MAXLLY's Avatar
MAXLLY MAXLLY is offline
No Lemming Here
Default
I looked into this and talked with Mike about it. IIRC he thought the lines saw 70-80 PSI, trans temps could be assumed at 275 MAX.
Earls has lines that fit this spec.
The tolerances between the lines and the block/starter/frame are tight down there. I would "sleeve" a braided line if you choose that mat'l. Braid is cool, but it chews through anyhting it contacts.
The hydraulic shop will have a SUPER TOUGH mat'l/sleeve you can wrap the braided line in, I can't memmer the name of it. It's black and they use it to cover the large hydraulic bucket lines at the mast, these rub the mast while in operation all day long. I use a stainless wire and wrap the cover to the line, versus zip ties. The zip ties will get brittle after a few months and break.
Good luck Dude.
__________________
LLY/CCSB 4X4 SOCAL DIESEL-MIKE L-PPE-DPR-3 STG NX-II-ENGINEERED DIESEL-EATON-MAC RACING-BAYER 4 LINK-PW PERFORMANCE-ALSTON CHASSISWORKS-BOV-DUAL GATES.
Still tuned by a REDNECK TEXAN
  #7
Old 02-25-2008, 11:50 AM
Turbotug's Avatar
Turbotug Turbotug is offline
BEER SLAYER
Default
I used one of the tube nut style connections that you are refering to when I assembled my lift pump/filter set up. It doesn't seem to seal all that well. It doesn't drip, but just has some build up crap. Doesn't work all that well at lift pump pressure, doubt it will at trans line pressure either.
__________________
Brandon
SunCoast
EFILive
HTT
588hp 1096tq
  #8
Old 03-05-2008, 04:08 PM
coldLBZ's Avatar
Default
Ordered my 4th set of trans lines under warranty today. Should be on the truck in 2 weeks.
__________________
Dan
  #9
Old 03-05-2008, 05:04 PM
LBZ's Avatar
LBZ LBZ is online now
Default
Your hard on equipment Dan!!
They just replaced mine under warranty-the first set-25000km.
  #10
Old 03-05-2008, 05:11 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Cooler lines normaly see 83 psi in the Alli and with pump upgrades even more. I would not take out the flex part of the line as it is there to absorb vibration and avoid rubbing against metal.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #11
Old 03-20-2008, 12:44 PM
coldLBZ's Avatar
Default
Just got my 4th set of lines put in along with the TCM recalibration at 35 200 km. The whole ordeal took over 4 hours. It seems like the trans is relearning again, probably just because of the reflash.
__________________
Dan
  #12
Old 03-30-2008, 10:34 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
If you did decide on hyd lines you wouldnt neccesarly have to go there
you could rought the lines in a different way....Just a thought
Agree with that
Good luck Dude.
zip ties in Canadas winter last about a day I would almost consider if i had the room cutting a larger hose to go over top of the hyd hose to protect it.....if you had the room to do so?
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #13
Old 01-04-2009, 10:19 PM
coldLBZ's Avatar
Default
Bump:
My 4th set of trans lines are leaking again. So what size, thread, etc are the fittings on these lines? In the Summit catalog I found Aeroquip AQP racing hose. It's good for 1000 psi, and temps from -55F to +300F. It was -44F at my place on Saturday, so I need hose rated for cold temps. Anyone else been thinking about this?
__________________
Dan
  #14
Old 01-05-2009, 12:12 AM
ruffmanatv's Avatar
ruffmanatv ruffmanatv is offline
Yeah, its got a D-Max!
Default
Quote:
Originally Posted by coldLBZ View Post
Bump:
Let me know what you are looking for. I can most likely get it cheaper then you can get it through Summit. I work at Aeroquip, which is now a division of Eaton.
__________________
Steve
2006 Chevy 2500HD 4x4 CCSB SOLD
LLY, Summit White, 35% Tint, Prodigy, Airbox Mod, Blocked and Fingered, Tie Rod Sleeves, Powdercoated 17" Welds on 285 Courser CT's, Autometer Gauges in Trippin Mount, TransGo Jr., 4" Exhaust, EFI Live Tune (Thanks Ed)
  #15
LBZ's Avatar
Default
Your hard on tranny lines Dan. No problems with mine at all
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
