  #1
Old 02-25-2011, 04:13 PM
crashz71's Avatar
crashz71 crashz71 is offline
FNG
Default shifting problem
Can anyone help me out? i am having a problem if i do a burnout my truck will shift from 2nd to 3rd immediately and then bog a little and down shift back to 2nd and spin again.I have changed the spin on filter and fluid it did not help the tranny. i took the pan off did not have any debris it looked new nothing on the magnet in the pan it was perfectly clean. thanks
__________________
2002 Duramax
4" Dual 4" Down Pipe
6" Lift Custom Ladder Bars
PPE Boost Valve
EFI Live Fass Fuel K&N intake
  #2
Old 02-25-2011, 05:41 PM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
Not to be a jerk but I would suggest not doing burnouts!
__________________
02' GMC CCSB
  #3
Old 02-25-2011, 05:49 PM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
The trannys don't like burnouts.
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #4
Old 02-25-2011, 06:08 PM
jonathancasey19's Avatar
jonathancasey19 jonathancasey19 is offline
yepppp
Default
Exactly how I blew my rear end.
__________________
2002 LB7 ECSB Summit White
S366/74 .91 billet 6-blade race cover 360 thrust bearing, S&S 65% injectors w/BMS SAC nozzles, Exergy 10mm cp3, Cognito NTBD 4-6", EFI Live dsp5, Airdog 150, RDL's uppipes, SC IV w/1056, 6" stacks, Wherli Fab S366 intake, all custom led lighting & quad morimoto HID's, x2 12" subs, pillar gauges, debadged, Cognito brace kit & HD tie rods, Bilstein 5100's, 35x12.50 m/t atz's w/ 20" chrome rockstars
12.67 @ 105 w/ stock fuel system
  #5
Old 02-25-2011, 07:46 PM
crashz71's Avatar
FNG
Default
i very rarely do burnouts i just did one showing off the other day and the truck shifted very quick to 3rd and back to 2nd and i don't know why. just thought there may be an issue.
__________________
2002 Duramax
PPE Boost Valve
  #6
Old 02-25-2011, 08:32 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
Quote:
You are the issue.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #7
Old 02-25-2011, 08:35 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 10.12 @140 815rwhp
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #8
Old 02-25-2011, 08:57 PM
MaxPF's Avatar
MaxPF MaxPF is offline
JAFAWAM
Default
Quote:
Originally Posted by hondarider552 View Post
X2. Looks like a loose nut behind the wheel
__________________
1991 K5 Blazer, 5.9 Cummins P-pumped 12V, 6 speed Allison, 203-205 doubler, 14bff and D60 with 4.10's, rolling on 35's
  #9
Old 02-25-2011, 09:47 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Quote:
Hey now, I represent that remark.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #10
Old 02-25-2011, 09:55 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Default
The truck thinks it's going faster than it is. It upshifts.
Traction is gained and the mph goes down, causing a downshift.
Sent from my iPhone, not teh interwebz.
__________________
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #11
Old 02-25-2011, 10:06 PM
crashz71's Avatar
FNG
Default
thanks for the info.
__________________
2002 Duramax
PPE Boost Valve
  #12
Old 02-25-2011, 10:33 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
I'm not allowed to do burnouts The one and only time I did bad things happened
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #13
Old 02-26-2011, 08:34 AM
Mike L.'s Avatar
Default
Quote:
I remember that.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
