#1
Ooooo the water pump. Everybody either bitches about it, or is scared of it. And those who let fear get the best of them will sometimes get raped by people charging hundreds and even thousands to replace it. Why does everybody bitch or charge a lot of money? Because one of the mounting nuts for the pump got put behind the harmonic balancer so you have to remove the balancer. people can bitch all they want but the bottom line is that some engineer got a vacation to hawaii for doing that, and you didnt.
Now many of you who have done it may be saying an hour? BS. Well that depends. If you have some good beats, some good drinks and a reason to do it, you can get it done in an hour ish. 1000 ways to skin a cat, this is the way i do it, you dont like it do it your way. This is for an 02-04 LB7, 01s are slightly different and the newer ones I dont know off hand. But the water pump is still in the same spot just different stuff to move Here is the stuff you will need. Supplies: Water pump: NAPA PN: WP58595 You dont have to buy a NAPA one but your local autoparts store can cross this number. A Couple extra gallons of Dex-Cool Drink(s) of choice Motivator (Girlfriend, Boyfriend, wife, dog, etc etc.) Normal Tools Needed: 8mm,10mm,12mm,22mm(7/8"), 36mm 12pt sockets Various ratchets and extensions to your taste 1/2" breaker bar or ratchet or 3/8" adapted to 1/2" 8mm and 12mm wrench, reversible ratchet wrenchs will make life easier Big torque wrench (needs to go to 260lb-ft) Impact wrench (optional) Mini Impact Wrench (optional) Floor jack and stand or car lift Topside creeper (optional, but worth it) Specialish Tools you will need to borrow or buy if you dont already have: Fan Clutch service tools. you will need to 47mm wrench, and the holder with pins. Flywheel hold tool whether it is the Lisle 22100 (comes with 36mm socket), the factory tool, or a socket with an extension that you stick onto a torque converter bolt. More on this later. Body Clip Removal tools ![]() HOW TO DO IT!!! 1. Get all of the parts and tools around. 2. Get a reason to do it in 1 hr ![]() 3. Get some liquid for of energy if needed. ![]() 4. Get some motivational beats pumpin 5. Jack truck up and put on jack stands or lift it up on your lift ![]() 6. Remove passenger side wheel and hubcap using impact wrench and 22mm or 7/8" socket. ![]() 7. Remove fender liner using body clip tools 8. Drain cooling system by removing radiator drain plug which is directly below CAC tube on passenger side. Use a 90* elbow of some sort to channel it into a clean pail, then remove overflow bottle cap to speed things up. ![]() 9. Disconnect batterys using 8mm wrench (just for extra safety) 10. Remove TCM by removing the two bolts holding it using 10mm on and then unplugging the two connectors. ![]() 11. Remove upper fan shroud by removing the two remaining bolts using a 10mm, then using the body clip tools to remove the 4 body clips holding it to the lower fan sheild (2 on each side) ![]() ![]() 12. Using fan clutch service tools, remove fan clutch. It is normal right hand threaded. ![]() ![]() 13.Remove serpentine belt by inserting 1/2" breaker bar into the hole on the tensioner, 01s require 3/8" ![]() 14. Now we need to lock the flywheel. There are a few ways to do this. The fastest and easiest way is to use the Lisle tool which you insert through the inpection hole in the bellhousing. It is very fast. The other way is to remove the start. To remove the starter you just need to remove the two mounting bolts using a 15mm, then lay it to the side out of the way. You can leave the wires connected. Now there are two ways to lock your flywheel this way. You can use the factory flywheel hold tool, J-44643, or you can use a 15mm socket and extension on one of the torque converter bolts, then when you rotate the crank it will contact the bellhousing and hold the flywheel. For any of these methods you may need to turn the crank to get them to engage fully. And if using lisle tool, remember to remove before trying to crank engine. ![]() ![]() 15. Now you need to grow a pair of balls and put your 36mm 12pt socket on the harmonic balancer bolt and using the biggest breaker bar you have, with a cheater pipe if needed, remove the bolt. Then remove the balancer. (yes the water pump is removed at the time of this picture) ![]() 16. Now you want to remove the coolant crossover pipe nuts with the 12mm wrench, you have to do this blind. You can remove the driversside wheel liner to gain better access if needed and you will be able to see them. The coolant pipe is visble in this picture, it has the orange gasket on it. (Water pump is removed in this picture). ![]() 17. Next remove the lower radiator hose using an 8mm. No picture for this one, should be pretty self-explanatory 18. Remove the two bolts that hold the coolant bypass pipe to the top of the water pump using 12mm then swing the pipe out of the way towards the front of the truck. (black pipe in the middle of this picture) ![]() 19. No remove the two bolts and one nut that hold the pump to the motor, using a 12mm. Then remove pump from truck. (picture is of motor on a stand for better view. ![]() 20. Now remove the three bolts that hold the pump to the housing to seperate the two. I didnt take a picture but once you get your housing off you will notice a big pit in it that looks bad. Its normal, they all have it. ![]() 21. Now install the new pump into the housing by lubricating the Biggest o ring of the three and then reinstalling the three bolts 21. Now reinstall the pump into the truck by lubricating the middle sized o raing and installing it over the pump, then using transgel, vaseline, or grease to hold the coolant cross over pipe to the studs, and waiting to install the smallest o ring till later. Torque bolts to 15-18lb-ft 22. Now reinstall coolant bypass pipe after lubricating the smallest o ring and installing it into the groove in the water pump. Take extra caution to make sure the o ring doesnt get pinched during this process. Install two bolts to 18lb-ft 23. Now reinstall the two nuts on the crossover pipe to 18lb-ft 24. Now reinstall the lower radiator hose 25. Now reinstall the harmonic balancer making sure you put it on facing the right direction and making sure to line up the keyway with the crank pin. The picture below shows the face that should be towards the crank, it is the face that is flush with the outer edge of the balancer, the recessed face goes towards the bolt and washer. Install the bolt and torque to 260lb-ft. ![]() ![]() 26. Now reinstall everything else and then fill the cooling system up by removing the vent with a 12mm. Its the bolt in the middle of this picture. ![]() Now you should be good to go, check for leaks, and check coolant level. If you have overheating issues soon afterwards you may have gotten a bad pump that the impeller fell off of, I just had this happen to me. In that case you will need to go back to the autoparts store and request a new pump and housing at no cost. Hope this helped. Vinny
__________________
"The Maxitron" 2018 LYZML DMaximus/Allitron Bully Dog Shift Kit, Stock Clutches, TTS C3, other "secret" mods, Amsoil Plutonium fluid,BHAF,#10 Fuel Plate,Cracked,Honed,ceramic plated 956% Injectors, OCTA-CP3.9 Pumps(that would be 8), Billet Everything, Aluminum Rods, Titanium Aluminum Sodium Bi-Carbonate Space Alloy Block, HX9000 Bi-Compounded Triple Quad Turbo's, Turbo Silencer Rings Removed, Water Cooled Canuter Valve, Cryo Treated Rotary Girder 36" Stacks Homomod by Brian Lockup Knobber by Ben Tuned by KE$HA while on a boat. ![]() 3.967 @ 452mph 4,324,756hp |
#2
My motivation would be those Matco 88s! Mine are orange though. I also might add that you will want at least a 3/4" breaker for the harmonic balancer bolt. We broke a snap on 1/2" breaker bar a few weeks ago
__________________
2004 LB7 CCSB Built trans, tuning, fabbed stuff by me |
#3
thats why they got warrenty dammit. haha. I use a 3/4" bar I bought at a surplus store for $50. Dont wanna hurt my Matco one.
The 88s are a dream come true. The soft grips take a little bit more work to clean but I still like them.
__________________
#4
Good right up one edit on TQ
Crankshaft Balancer Bolt 363 N·m 278 lb ft
__________________
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4 EFI Live,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter. Alot Of thanks To George aka BigDipper 11.53 @ 116.92 1.66 60's ![]() RIP LBZ 6/1/08@5:44pm she was strong She's Alive again Born on July 27, 2008, 11:59:02 PM ![]() |
#5
my 2003 manuals said 260lb-ft , did it change over the years or was there a tsb?
__________________
#6
Thank You for the DIY
__________________
Spooky bone stock 09 CTS-V 12.36 @117 Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51 Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice. McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9 |
#7
even a new one
http://www.duramaxdiesels.com/forum/...614#post432614
__________________
#8
nice right up Vinny! I might have to make the trip up to Dairy Land if I ever need mine changed
__________________
Ben 05 LLY Alli the "Dream Crusher" Proud member of Pipefitters Local 597 certified mig tig and stick pipe welder thanks to Bobo_Team Twisted_Danville Performance_Big Dipper_Sandwich Crew and Todd |
#9
so now its a torque-yeild bolt?
So which one is right henry, ive got this on a few different forums and want to make sure the correct spec is up. My manuals are just the paperback ones. you have acess to the most updated stuff.
__________________
#10
Quote:
If you reuse the bolt that was in there I would use the 260 to 278 spec. They have changed the damn specs to many times in the last year along with part numbers. They were selling 2 different balancer bolts 1 tq to yeild and 1 just straight up tq. The last ones I could get were the straight up tq to 278. The link I posted is upto date specs from Gm and I also checked and all the other Tq specs I have posted are still the same.
__________________
#11
So if an owner has the original bolt then it is 260 or 278 but if they replace the bolt it is the new specs? Plus the who knows factor.
__________________
#12
I will see if there back to 2 part number with the bolt or just using the non tq to yeild. If there still not selling 2 bolts and only the older ones from the 01's even a truck like mine will need tqed to 278. I will check and see what is going on with these I need to have a few on hand anyways.
__________________
#13
Quote:
Quote:
__________________
#14
Quote:
I dont care to look it up aslong as it not electric lol
__________________
#15
So did you change the water pump??? I got hung up at step 2
Just kidding nice write up!
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
