  #1
Old 01-05-2011, 05:31 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default Passlock II issues
Well i dont know what the heck is goin on, my damn security light in the message center wont stay off, it jsut stays on solid. its on my truck (02 chevy 2500hd) heres some background on the truck. I have a viper alarm on the truck with remote start. it uses a DEI 1700g passlock override deal so that the truck can start with the remote. It did this two weeks after i put the twins in (doubt it has much to do with any of that) and the GM security is disabled in EFI Live.
Heres what ive found. One, if i remote start the truck and get in, the security light stays off even after i put the key in, turn it to run, and hit the brake to kill the autostart. Two, Ive pulled the colum and bottom panel searching for any broke/bad wires and have found non, all connections are good and ive reset the DEI controller three times but no fix. Three, i tried seein if EFI Live can read the code (assuming there is one if the light is stayin on) but nothing, pulls no codes at all. I may have forgotten a few other things i did as ive been messing with it over the past few days.
All i can figure is for some reason the ignition cylinder has an open in it or the key is not making the contact point it needs to complete the circuit. Has anyone run across this problem or have any steps for me to try to get the code and/or reset the passlock?
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #2
Old 01-05-2011, 05:46 PM
Chevy1925's Avatar
Default
oh, another little tid bit. the light could have been comin on shortly after i finished the twins as i used my remote start almost all the time to warm the the truck up
__________________
James
  #3
Old 01-06-2011, 07:42 AM
Chevy1925's Avatar
Default
bump
__________________
James
  #4
Old 01-06-2011, 08:33 PM
Chevy1925's Avatar
Default
damn i cant believe no one has any thoughts lol. Checked all fuses, all good. tried disconnecting the batt for a bit, no change.
__________________
James
  #5
Old 01-07-2011, 10:34 AM
turbo_bu turbo_bu is offline
Default
Did a lot of reading on Pass Lock trying to help a buddy with a 99 Grand Prix. I realize that this is not quite the same animal, but in all the reading ... it seems as though the lock cyclinder in the column was wearing out. Thus it didn't match what the BCM was looking for. Turning off the security in EFI Live just makes it so the engine will run. It doesn't fix the BCM.
__________________
Got Boost?
2004 CC SB LB7 Auto
OS - 15189044
  #6
Old 01-07-2011, 11:37 AM
darkness's Avatar
darkness darkness is offline
Default
might want to get ahold of Trent. he wrote some tunes for my truck and wrote it off his '01. my truck would not start (crank) period, even with the security stuff turned off in efilive. mines an '04. yours being an '02 could still run being closer to an '01. but thats what im thinking...it needs to be written for the '02
p.s. Trent did get it fixed
__________________
Rob
2004 2500hd bought new in June 2004. Sold on 12/28/16 .
2007 classic 2500hd Chevy bought 3/16/18. Letís start spending money
  #7
Chevy1925's Avatar
Default
Quote:
i had a feelin about that. Im tryin to find my spare key to try that. my originals pretty worn
__________________
James
  #8
Old 01-10-2011, 07:07 PM
Chevy1925's Avatar
Default
well figured it out. turned the security back on in my truck to see if it would give me a code or something, or not allow the truck to start. When i did that and flashed it in, light stays off lol. So what i gather is turing the security system off in EFI live will disable it but will illuminate the security light in the truck. Atleast on my 02 it will (stupid one of a kind truck lol)
__________________
James
  #9
Old 01-10-2011, 08:25 PM
MMLMM's Avatar
MMLMM MMLMM is offline
Default
Have you disconnected the passlock module and plugged it back in?
If my battery draws to low it resets everything like the clock and such. And I have to unplug the prt that communicates with the factory security/bcm/door locks, and then its back to normal.
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
  #10
Old 01-10-2011, 09:03 PM
Chevy1925's Avatar
Default
yup. didnt make a difference. Its weird, cause the remote start would keep it off, like the key was the wrong resistance but after puttin the security back on with efi live, it went right away
__________________
James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
