  #1
Old 12-29-2010, 04:17 PM
s3gulit's Avatar
s3gulit s3gulit is offline
Teh Farmer
Default Idle is loud as hell and noticeable shake...wtf?
So after christmas eve, i drove home from my lady's parents, was snowing pretty bad and the state boys weren't out, so the 95miles were done in 4hi at about 50, couple time the truck didn't downshift after getting back on the gas from coasting and would try to pull from about 800-900rpm.
Past couple days now, idle has been much lower than normal and truck shakes quite a bit more in idle park, or in gear stopped with the brakes on. Any clues as to what might be going on?
Truck has 90K, fluids changed regularly (oil 10K, fuel every 4 mo, trans 1-2x yearly, etc). Only has the EGR block plate/4" straight, and PPE standard on 4.
__________________
[CENTER]2006 RCLB | DMAX | EGR Plate | PPE | Silverline | Cobalt Boost + EGT
2000 RCSS, 4.8 |5spd | VHP Cam | ASP Pulley's | LS1 Fans | LT's | ORY | Ported TB | 2/4 Hotchkis
  #2
Old 12-29-2010, 04:52 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Whats it idling at IIRC 680s normal warm? Does it run the same way if you put it back to stock?
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #3
Old 12-29-2010, 05:27 PM
FullSpec's Avatar
FullSpec FullSpec is offline
Served cold.
Default
air leak in fuel?
water in fuel?
when was the last time you changed your ff? have you ever changed your wif sensor? are you getting any codes?
__________________
'06 LLY 328k+
work, play, drive it everyday
  #4
Old 12-29-2010, 07:04 PM
s3gulit's Avatar
Teh Farmer
Default
WIF sensor is there but the wires, somehow got stripped. Been like that for atleast a year and never had a problem. FF was changed in october, straight #1 with no signs of waxing/gelling.
Haven't put the stock info back on, tuner has been on again since late october when the truck got done pulling the wagons and support trailer for the farm (put it back to stock so the hired hands dont screw anything up).
Will look at heated idle tomorrow and get back to you guys
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
