  #1
Old 11-21-2010, 08:40 PM
jimjim1990 jimjim1990 is offline
FNG
Default Tranny stuck in third
I was driving my dads truck 2001 gmc 2500 hd duramax with the allison and he has the edge programmer in it. I cranked it up to level four and got on the gas hard, and now the engine light is on and it wont shift out of third gear. It has done this before and all we did was shut the truck off and and let it sit for a bit and it reset itself. However this time it is not resetting itself. What do i do?
  #2
Old 11-21-2010, 08:46 PM
Ridin'GMC's Avatar
Ridin'GMC Ridin'GMC is offline
I like red
Default
Transmission limp mode. The trans slipped and went in limp mode. That's what happens when you crank up the power on a stock trans. Clear the codes, turn down the power. It's going to limp easier next time when you hammer on it.
__________________
07 LBZ CCSB
RIP 4/1/17
06 LLY CCSB
  #3
Old 11-21-2010, 08:56 PM
FNG
Default
is there any way of clearing the codes without the computer?
  #4
Old 11-21-2010, 09:10 PM
66impala's Avatar
66impala 66impala is offline
Gear head, bus driver
Default
the edge should clear all codes. never had a problem with mine that i had. go to the DTC code reader part of the edge. clear the codes and go if not call edge and let them know whats going on.
__________________
2006 Chevy 3500 P/U, D/A, LLY, Cc 4X4. My LLY has the LBZ computer tune stock 360hp, instead of the stock 310hp. PPE hot + 2 w/7 settings, on setting 4. exhaust is a 5" magnaflow turbo back no kitty. ATS Diesel stage 3 turbo 3000, ATS Computer controler for the 06 & new for engine codes, AFE intake stage 2, EGR Blocked, Transgo Jr. 3.73 gears. Next ATS stage 2 trans. Yes this truck is in MAXX TORQUE MAG. in the 08 & 09 issue.
  #5
Old 11-21-2010, 09:44 PM
MWDHAND's Avatar
MWDHAND MWDHAND is offline
Default
If it is a juice with attitude it does not have a code reader in it or at least when I had the edge it never did. Shutting it off should reset it but if it does not then something else may be wrong.
__________________
2004.5 Silverado 2500HD CC 4X4 Charcol Gray
AFE 4" Stainless Exhaust (no kitty), AFE Stage II,XM Radio,EFI Live ,Autometer Phantom II Triple "A" Pillar Gauges (Redone by MPL Motorsports), All On Headlight Mod,NADP Race Trans w/ 1057 (w/ Transynd), EGR Blocked (Thanks MPL Motorsports), Bilstein 5100's All Around (Thanks Lambcooker and MPL Motorsports),AMS Oil Dual Filtration Bypass and AMS Oil in Everything but the Tranmission(Transynd), FRPV Shim and Ported Fuel Rail Fitting Installed (Thanks MPL Motorsports),Diamond Eye Downpipe (Thanks MPL Motorsports),Cognito Pitman and Idler Arm Braces (Thanks MPL Motorsports) Snow MPG MAX (Installed by MPL) Mitusa Pump (Thanks Opie) Belltech 3" drop shackles in rear and torsion bars levelled off (Thanks MPL) Yukon Locker (Thanks MPL) XD Monster 20X9 With Nitto 420's
  #6
Old 11-22-2010, 06:56 AM
FNG
Default
it doesnt have the code reader and shutting it off doesnt do it im gonna try disconnecting the batteries today and see if it helps.
  #7
Old 11-22-2010, 07:41 AM
LBZ_Duramax LBZ_Duramax is offline
Default
IIRC a standard code reader will not clear a trans code in a 01
  #8
Old 11-22-2010, 07:52 AM
Noreaster's Avatar
Noreaster Noreaster is offline
Default
IIRC CEL will shut off after 100 miles
__________________
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #9
Old 11-22-2010, 08:18 AM
FNG
Default
Went out to work on the truck today and everything is reset just need to get the engine light turned off. Thanks for all the help guys.
  #10
Old 11-22-2010, 08:28 AM
dmaxchebby dmaxchebby is offline
FNG
Default
Quote:
Before your dad finds out you slipped his tranny for him...
__________________
04 LLY, MBRP Straight 4", BD Manifold, EFI, Cognito Leveling Kit, Weld Wheels, more.
  #11
Old 11-22-2010, 08:29 AM
MACKIN's Avatar
MACKIN MACKIN is offline
Smell My Finger...
Default
I believe it's start stop engine cycles that get it moving again and or eliminate the SEL light. If you don't have a scan tool like a Tech II or EFI or a Snap On tool see if you can go to a autoparts store like Advanced and see if they will clear it.
Like I said eventually it will go out on it's own
__________________
I have nothing want nothing because what I have cost me to much to have.
01 Big Dually (Gone but not forgotten)
05 Fat-Boy (gets it done)
83 CJ7 (slug but cool)
07 Audi A4 ( I like German Girls they're HOT!!)
LIFES JOURNEY IS NOT TO ARRIVE IN HEAVEN SAFELY IN A WELL PRESERVED BODY,
BUT RATHER TO SKID IN SIDEWAYS,
TOTALLY WORN OUT, SHOUTING,HOLY SHIT WHAT A RIDE!
  #12
Old 11-22-2010, 08:46 AM
scratchrob13's Avatar
scratchrob13 scratchrob13 is offline
<---30+ psi (both)
Default
It is four or so cycles to get it out of limp mode... and that is full cycles, turn on-off, open close door, x4.
__________________
2007 Chevy CC/SB LT3 Black
4" MBRP no kitty, Suncoast Stg IV, Twin Kennedy Lift pumps, EFI Live (BT Diesel tune)
1000+rwtq on my daily tune
To be installed: DSP 5
To Buy: Twins & More tires
2001 Audi A4 1.8TQM
3076r on a built motor...
  #13
Old 11-22-2010, 09:08 AM
MACKIN's Avatar
Smell My Finger...
Default
Flash your headlights blow your horn and run around the truck clockwise. 4x
__________________
  #14
Old 11-22-2010, 09:46 AM
<---30+ psi (both)
Default
COUNTER-clockwise. jeez.
__________________
2001 Audi A4 1.8TQM
  #15
Old 11-22-2010, 10:05 AM
MACKIN's Avatar
Smell My Finger...
Default
Quote:
My bad sorry..........
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
