  #1
Old 10-14-2010, 07:01 PM
schulte schulte is offline
Truck: 2004 CCSB
Engine: LB7-LLY Hybrid
Transmission: Automatic
Default Transfer case/driveshaft vibration
My dad's got an '04 2500HD 6.0L gasser with the manual floor shifter. About 55,000mi on it. Some towing, nothing more than 8,000lbs here and there.
Got a BAD vibration between 65-75mph, especially bad when accelerating. Sounds like maybe pump rub in the transfer case has let all the oil out, or maybe a bad u-joint.
Weird part is, it's supposedly been like this for about 5,000mi. 4x4 still works, shifts easily into 4x4, etc.
Got two videos... first, the vibration under acceleration (60-75mph); second, the shifter movement under acceleration (all speeds).
Any ideas?
  #2
Old 10-14-2010, 07:26 PM
Noreaster's Avatar
Noreaster Noreaster is offline
Truck: 2002 GMC
Engine: LB7
Default
my shifter does the same thing while accelerating
__________________
02 GMC 2500HD RC/LB 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB
Bay State Diesels
  #3
Old 10-18-2010, 07:19 AM
Truck: 2004 CCSB
Default
Does this seem like it could be caused by no oil due to pump rub?
  #4
Old 11-16-2010, 05:24 PM
Truck: 2004 CCSB
Default
Just replaced the U-Joints today; no change.
Also notice t-case almost empty; about 4oz of BLACK fluid came out. Re-filled it with Transynd (didn't have any Dex-III on hand).
No change.
Also notice the driveshaft has a few areas that're dented. No dents deeper than 1/8", but they're definitely there. Not sure if this could cause/contribute to it.
Anyone wanna wager on internal to the transfer case vs. output shaft bearing?
  #5
Old 11-16-2010, 05:41 PM
LBZ_Duramax LBZ_Duramax is offline
Truck: CC/SB 4WD
Engine: LBZ
Default
The fluid evaporates and was likely overdue for an oil change. BTW my dads 1500 with the floor shifter does the same thing.
  #6
Old 01-27-2011, 04:56 PM
07dirty 07dirty is offline
country boy
Truck: 07 classic 2500HD
Engine: LBZ
Default
i just put 5w30 mobile 1 synthetic in my case and now i have a bad vibration too. but im thinkin it has to do with the pump not being able to pump it has quickly plus my brand new output shaft seal is leaking also. so im gonna put atf back in mine and see if that helps. i think your is the pump hub tho, my transfercase doesnt fall under the catagory of pump hub, but i believe yours does since its a 04
  #7
Old 01-27-2011, 05:10 PM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kindof guy
Truck: 2006 Silverado
Engine: LBZ
Default
dump the atf and fill the t-case with 5w30. if there is a chance aat saving it that will help.
__________________
-Fireman
  #8
duramaxdiesel's Avatar
duramaxdiesel duramaxdiesel is offline
Dmax Nut
Truck: Big
Engine: Expensive
Default
Dents are never good no matter how big when it comes to a driveshaft. Remember, that thing is spinning pretty fast. Maybe it's out of balance now?
Nick
__________________
2001 Chevy K2500HD Duramax/Allison Ex/Sb...Waaayyyyy far from stock;-)
2001 Chevy 3500 Dually Reg. Cab Duramax/Allson...Stock other than a Juice Box
  #9
Old 01-27-2011, 05:12 PM
DuramaxSMOKE11's Avatar
DuramaxSMOKE11 DuramaxSMOKE11 is offline
Diesel Smoke
Truck: EC/SB
Engine: LLY
Default
juat went through this with a workd truck. the tailshaft bushings were shot in the t-case and the driveshaft was bent
__________________
Mike
2005 Chevy 2500HD Duramax LLY
BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, FASS 220gph pump Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, EFI Live, 3/5 djm drop, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
2003 lb7 plow truck/winter rig
  #10
Old 01-28-2011, 08:48 AM
country boy
Engine: LBZ
Default
i still have a vibration aound 64-69mph. i put atf back in in it and that seemed to help alot. it only vibrates under a load and in top gear. it had a bad carrier bearing, so i installed a new carrier bearing. that seemed to help. but its still their and bugs the shit out of me, it vibrates on cuise control also when set at like 64-69mph range.
  #11
Old 02-01-2011, 10:32 AM
Truck: 2004 CCSB
Default
This ended up being a dented driveshaft. The dents were very very minor, almost unnoticeable. I brought the shaft to a driveshaft shop and they checked it for balance and found the dents.
New driveshaft, problem solved (for now, until the transfer case lets go because it was run out of oil).
  #12
Old 02-01-2011, 12:40 PM
Jetty LBZ's Avatar
Jetty LBZ Jetty LBZ is offline
work in progress
Truck: 2007 CC/SB 2500LT
Engine: LBZ
Default
my dads transfer case started poping and when he got on it the trans didnt want to shift. we took it apart and the gears were wore out and we had to get it rebuilt but his truck has 300k on it and thats the only problem its had thus far.
__________________
2007classic Allison/Duramax LBZ LT CC,SB
duel piller ProSport Digital BOOST,EGT
EGR plate MBRP down pipe,5"into 6"tip
Akuza Ricco 18s on 275/65 Kumho AT's
GM rain guards, Bully billet door handles,
PopUp2 gooseneck hitch.
  #13
Old 02-03-2011, 10:25 AM
country boy
Engine: LBZ
Default
i just bought a tail shaft bushing and bearing. maybe that will take care of the problem
  #14
Old 02-21-2011, 12:27 PM
country boy
Engine: LBZ
Default
tail shaft bushing and bearing was my problem... btw i had a broken pump hub clip too.
  #15
Old 04-30-2011, 02:44 PM
mtl_dmax mtl_dmax is offline
Gearhead
Truck: EC/SB
Engine: LLY
Default
I got my front end totally rebuilt and now I've got a vibration at highway speed primarily under load. All the U-joints felt fine and the only play I saw was on the tailshaft bearing as well as the front output shaft bearing. I'll need to pull my transfer case to fix the pump rub anyway so I may as well get the full rebuild kit with bearings and seals to do it all at once. Truck drives great except that vibration so it's quite annoying to say the least.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
