  #1
Old 09-01-2010, 12:25 PM
rings343 rings343 is offline
FNG
Default 01 lb7 smokes bad, no power
I got this truck in pieces and just finally got it running the CEL isnt on I am new to diesels I assume it needs injectors is there anything else that may cause this and is there a way to DIY clean your injectors? I have access to an ultrasonic injector cleaner for car injectors
__________________
01 LB7 Silverado 2500hd SCLB (well used) stock for now
  #2
Old 09-01-2010, 05:58 PM
FNG
Default
Ok so I was digging around in part #'s and think I may have ordered a baro sensor instead of a boost sensor I ordered a boost sensor and will try again when it gets here I will update then
__________________
  #3
Old 09-02-2010, 09:14 PM
niteflite1287's Avatar
niteflite1287 niteflite1287 is offline
Now with 3 antennas
Default
Although I'm far from the expert on this, relatively new learning my self...what color is the smoke? from my understand white smoke = injector problems, but black smoke can indicate other issues as well. In particular a lack of boost. The LB7s seem to have an issue with the steering lines rubbing through the charge air/boost tubes which are aluminum. (I can't remember which side (intake or discharge to the intercooler). I'm sure someone here who knows a lot more than me will correct if I'm wrong but if you have black smoke would check that first before you drop 2-3k on injectors.
It would smoke the worst when you lay on the throttle and you would have absolutely no power.
__________________
2002 Sierra 3500 LB7 CC Flatbed | 7 Isspro Preformax Gauges | Airdog II DF-200 | Banks Ram Air | MBRP 4" SS Exhaust | Pacbrake PBRX & Air System| Denali DIC Upgrade
  #4
Old 09-02-2010, 10:27 PM
jmaz268's Avatar
jmaz268 jmaz268 is offline
Lead from the Front
Default
I spent 1400 on injectors when I did all 8..... but yes more info is needed for sure.
get us codes the poor gal is popping.....will help 100x more
__________________
John
http://www.duramaxdiesels.com/forum/signaturepics/sigpic5837_2.gif
  #5
Old 09-04-2010, 04:18 PM
FNG
Default
Its popping a overboost code I think p0234 I know I have the wrong turbo pressure sensor (map) I also know I have at least one bad injector it must be dumping fuel cause now it wont even start unless I hit it with ether how can I find which injector is leaking I was thinking about removing each injector one at a time and leaving them installed and capping the port on the rail then start the truck to see if it is still smoking will it hurt to run the injectors like this temporally
__________________
  #6
Old 09-04-2010, 04:46 PM
Now with 3 antennas
Default
see if u can find a friend, a guy on the forum, or a shop with a tech II or other advanced scanner. it can tell u the balance rates and a bunch of other good stuff that can help pinpoint the problem. efi live works too for looking at injectors if i'm not mistaken.
__________________
  #7
Old 09-04-2010, 04:56 PM
FNG
Default
I called the guys at twin peaks diesel and talked to them yesterday and they sugested the same but with the way the injector is leaking cylinder balance and injector balance wont tell me what I need to know I have access to auto enginuity and it dosent help the injector is leaking so bad I just need to eliminate the fuel supply to it I guess
__________________
  #8
Old 09-04-2010, 06:23 PM
FNG
Default
ok so I found a old fuel line and made myself a cap I knew the leaky one was on the right bank so I just started at the front and un hooked the feed line for each injector and capped it for the first two primed it and it still wouldn't start when I got to the third one it primed the button got hard finally it never has yet and vroom it started my question is how long can I run it like this at idle it takes a few mins to start smoking
__________________
  #9
Old 09-04-2010, 07:19 PM
66impala's Avatar
66impala 66impala is offline
Gear head, bus driver
Default
check your waste gate. a buddy of mine his waste gate blew out the tail pipe and had no power and smoked bad. the fix was a new turbo housing the waste gate baffle blew out where its welded to the lever for vacum.
__________________
2006 Chevy 3500 P/U, D/A, LLY, Cc 4X4. My LLY has the LBZ computer tune stock 360hp, instead of the stock 310hp. PPE hot + 2 w/7 settings, on setting 4. exhaust is a 5" magnaflow turbo back no kitty. ATS Diesel stage 3 turbo 3000, ATS Computer controler for the 06 & new for engine codes, AFE intake stage 2, EGR Blocked, Transgo Jr. 3.73 gears. Next ATS stage 2 trans. Yes this truck is in MAXX TORQUE MAG. in the 08 & 09 issue.
  #10
Old 09-04-2010, 07:20 PM
66impala's Avatar
Default
oops i see you found the problem.
__________________
  #11
Old 09-04-2010, 07:27 PM
FNG
Default
Yea I'm just trying to figure out how long I can idle it this way I really dont see the issue aside from no fuel running thru the fuel injector may overheat it but who cares its junk any way
__________________
  #12
Old 09-06-2010, 06:28 PM
FNG
Default
ok so I disconnected the boost sensor just till I get one and it runs rough and smokes still but it has the power back. so I went through and disconnected and capped each injector till it straitened out so I threw a spare I had laying around in and started it up it was running fine till I heard it start missing shaking and smoking right before my eyes it roached another injector so I had to start all over with the ghetto injector test I was dooing this time it took 7 cylinders to find the bad one but I guess its bad when I cap it the truck runs fine (shakes a little) and dosent smoke i have 2 more spares so I'll try one of them tommrow and I'm looking into a 2 micron filter setup also
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
