#1
Well, for the past two weeks my truck has been having a rough idle after a cold start. Once I put the truck into gear it tries to "lope" around, lopey idle. Well today I cranked it up at around 3pm and was getting ready to make my way to town. Well once I put the truck into gear and holding the brakes it started hazing white smoke. But once I start driving the truck; the truck runs fine and smokes the normal black color and runs fine for the rest of the day.
Now before Harley at Georgia Diesel checked my injectors last time I was down in Georgia (around April I think), he noticed that injector #8 was requiring more fuel than the rest of the injectors. Which I found to be true when a month later I recieved a code on my truck (P0308 cylinder H (8) misfire) which would later pop up out of the blue every now and then. Once that code popped a long time ago, I began to add injector additive/lubricator like every chance that I think that it needed it. Well it looks like that only held off the injector problem to a degree. I DO have enough money to replace one injector (if only one injector is bad) but I was told if you're going to change a injector u might as well change the 4 on that side or change all 8. I know theres no way I can afford all 8, and to change 4 I might have to ask for some help from someone with money (which I absolutely HATE doing). So what should I do?
__________________
2001 Chevrolet LB7 Duramax S366, ARP Head Studs, 5" intake, Suncoast Trans, Airdog 165, Trac Bars, 5" Exhaust, Dsp5, 50 coats of wax. Special thanks to: ATP Trucks, Suncoast Transmissions, and Mr. Poole Last edited by SparkZ03DMAX; 08-25-2010 at 02:48 PM. |
#2
personally, cause im in the same finacial boat as you (can afford one injector at a time) id just replace the one. Now i dont know if you plan on changin it yourself but when the time comes for me ill be changin it myself.
__________________
James 02 LL7 2500HD CC/LB dmax/alli "The Limo" BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me. ![]() best time to date: 12.39 motor died/bent rods = 3/11/11 back from the dead 7:04pm 4/9/2012 Limo is back in the garage, now driving a built chevy tracker ![]() Tailgate Crew Member #4 |
#3
There is a guy on here selling new in the box no core injectors for 1,385 shipped in the US I know a guy that bought a set and there new from GM.Thats about as cheap as your going to find them.
Here they are http://www.duramaxdiesels.com/forum/...ad.php?t=24393 |
#4
Oh man this sucks. I'm in the same boat you are with my dually. I put all my money into my motor build for my other Dmax. Same year, color and configuration as yours. My dually won't even start after sitting all night. I hate to admit it but I need to give it a shot of ether then I'm good for the day. It's been like that for about a year now but the use of ether started recently. If I was in your shoes and you have no fuel in the oil I would just keep driving it until you have the cash to change all the injectors at one time. That's just my opinion.
Hope everything works out for ya with whatever road you take. Nick
__________________
2001 Chevy K2500HD Duramax/Allison Ex/Sb...Waaayyyyy far from stock;-) 2001 Chevy 3500 Dually Reg. Cab Duramax/Allson...Stock other than a Juice Box 2008 Chevy 2500HD Duramax/Allison CC/SB with some more info to follow... ![]() |
#5
Glad I have some ppl who understand. I took care of this truck the best I could, adding additives and lubricants because I knew about the LB7's almost only flaw. I've actually been thinking about selling my motorcycle to pay for the fix.
I might have to ask dad for help but I know he doesnt want to because he wants me to be on my own; I dont blame him but I sure could use the help ![]()
__________________
2001 Chevrolet LB7 Duramax S366, ARP Head Studs, 5" intake, Suncoast Trans, Airdog 165, Trac Bars, 5" Exhaust, Dsp5, 50 coats of wax. Special thanks to: ATP Trucks, Suncoast Transmissions, and Mr. Poole |
#6
Let me know if you want help putting them in. I will do it for cheap and you can help and learn a thing or two. That way next time you will be able to do it yourself.
__________________
Travis 03 CCSB lb7 06 2500hd ECLB 6.0 gasser 2010 Straight Diesel 2.8 Points Champion ![]() special thanks: B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel |
#7
Thanks alot dude. If theirs anyway u can send me ur phone number or something threw a PM that would great I might have to call u up on this.
__________________
#8
Should I replace one? four? or all eight?
__________________
#9
If you cant afford 4 or 8 just do one. When you have the cash do all 8.
__________________
F250 6.7 |
#10
Just replace one if that's all it is I did that now have to change another one out on the other side
__________________
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tune 3 11.61 @ 119 !! 2012 mega cab 6.7: Tuned and deleted (reliable) ![]() 2016 CCSB custom sport lml ltz deleted with sotf tunes by me |
#11
ok that helps, i hope its just one that I have to fix, and dont have to worry about the others for a long time. I'll pray for that
__________________
#12
Good luck Ethan
__________________
04 LLY EFI, Trans, Etc. Sold |
#13
Replacing 4 isnt going to make a difference in the truck opperating. I think the "replace 4" theory comes from the LB7s since they are a PITA and you have that side apart and a big chunk of the cost is the labor.
It would be ok to do just one, but a lot of work to do just 1 when three other are right there and could be done to make sure they last longer.... However if its cash strapping you, and your doing the work, do 1 for now. Whats another learning experience right? If you are paying for someone to do the labor, I would do what ever it takes to have the other 3 on that side done....
__________________
![]() 2002 LB7 EC/SB Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles, Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods |
#14
If you have less 200,000 on the truck GM will replace all 8 injectors for FREE I have had 5friends take advantage if this
__________________
06 LBZ Sting Built Sled Puller,Race Truck, Daily Driver EFI Live FASS 95 2.6 Turbo Fleece 60% Over Injectors SunCoast Stage 4, 1056, Carrillo Rods Yukon Gears, Axles, Grizzley Locker, Eaton E-Locker PPE Tie Rod Sleeves Cognito Braces Hamilton Cam Valve Springs Mahle Pistons PPE Duel CP3 Big Thanks To Jeff Dean (stingpuller) and Henry Webb (ripmf666) www.creaturesofthenightperformance.com |
#15
![]() Quote:
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
