  #1
Old 07-01-2010, 07:58 PM
TheBac's Avatar
TheBac TheBac is offline
Default injector cup removal tool
Just how does this tool work? Does it latch onto something on the inside of the cup to pull it out?
Can I make something out of a couple sockets and a threaded rod that would do the same thing?
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #2
Old 07-01-2010, 08:02 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
Not gonna be able to make anything work. The top piece goes inside the cup and when you tighten the bottom nut it has fingers that expand and press against the sides of the cups. Then you slide the bottom piece over the first piece and thread the second nut on and tighten. The bottom piece sits on the head and as you tighten the nut it will pop the cup out of the head.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #3
Old 07-01-2010, 08:03 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
when you put it in the cup you tighten the bolt and it tightens on the inside of the cup
ive ghettto rigged a tool but dont recomend it it wasnt made from metal either
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #4
Old 07-01-2010, 08:04 PM
That's better
Default
Tom cant you jut borrow the tool?
__________________
07 RC/LB 2wd
05 CC/LB
  #5
Old 07-01-2010, 08:18 PM
wdino73's Avatar
wdino73 wdino73 is offline
Default
If the head is off the engine u can take a 3/8 ext, an gentle tap it from the deck side, the ext is the perfect size, that my not be the tool of choice for some guys, but it works at 1:30am. I alway replace the sleeves anyway..
__________________
02 Duramax, LB7 lots of toys, 150 hp Injector and match CP3 from Industrial Diesel, Ported Fuel Rail Fitting Out of an 03, FASS Fuel System, GT 3788 Turbo, Stage II Port and Polished Heads, Street Cam with Upgrades to Valves, Springs, Push Tubes ect. ARP Head and Crank Studs, Crank and Cam Keyed, 20 over Malhe Pistons, Piston Skirts Coated, and Bowl delipped, Carrillo Rods, Modified Oil Pump, Banks Intercooler, Suncoast with all the triming, Suncoast Transfer Case Bracket, BD Manifold with MBRP 4 to 5 inch Stackes with resonator, Stage III Snow Water/Meth, Bullydog Propane, Twin Electric Fans, EFI LIVE, Maxx Torsion Keys, Firestone Air Ride, Cpeks with BF Goodrich.
My friends call me Dino like in the Flinstones
Be Safe An Enjoy The Ride
A Picture is worth a 1000 words, or in this case 1000's of dollars.
  #6
Old 07-01-2010, 08:32 PM
TheBac's Avatar
Default
Quote:
I was afraid you guys were going to tell me that tool had "arms" on it somewhere. Looks like I'll have to take a trip to Eric's tomorrow.
Dino, I tried a slightly-less-than 1/2" dia rod like you describe, and it didnt work. I stopped myself before I screwed up the head or the cup.
__________________
Tom
12.14@111.15
  #7
Old 07-02-2010, 05:24 AM
White Duramax's Avatar
White Duramax White Duramax is offline
Default
The tool works good. If you have a dealer that you get parts from they might let you borrow it for a day.
__________________
06 CC/SB 4x4 LBZ/Allison
  #8
Old 07-02-2010, 05:34 AM
jmaz268's Avatar
jmaz268 jmaz268 is offline
Lead from the Front
Default
Couldn't you use a threaded bolt with washers and piece of stiff rubber so when you tightened the rubber it would expand outwards pushings against the cup and thus being able to pull it out.
Never had to take one out so not sure how tight they are in there.
__________________
John
http://www.duramaxdiesels.com/forum/signaturepics/sigpic5837_2.gif
  #9
Old 07-02-2010, 06:58 AM
TheBac's Avatar
Default
Whew. Got the cup out by using a 5/16" deep socket thru the injector hole (just thin enough to clear the head, wide enough to catch the cup edge), and tap, tap, tapping it with a brass mallet.
Learned a valuable lesson, one that I have to keep telling myself....trust my abilities.
Thanks guys for all the help.
__________________
Tom
12.14@111.15
  #10
Old 07-03-2010, 12:03 AM
Jared Duramax's Avatar
Jared Duramax Jared Duramax is offline
<---- $$$ Whore!!
Default
i bought the tool when i did my cups it was the best $150 i have spent tool wise for these trucks.
i wouldnt recommend trying to build a tool since its such a pain in the ass to redo these cups. the tool is still the cheapest in the long run
__________________
Jared
2003 GMC Sierra 2500HD LB7
  #11
Old 12-22-2010, 10:28 AM
1chevy02's Avatar
1chevy02 1chevy02 is offline
Default
where can I buy this tool?
__________________
02 Chevy loaded LT package
4x4 ccsb
Efi live
305/65/17 Procomp Extreme AT on dodge wheels lbz cp3 dsp5
Suncoast Gmax 5 and Precision Converter installed by me! Thanks George at Suncoast!
high idle, Stewart Warner guages, PPE boost increasing valve, full Cognito kit, various other mods, ported and polished turbo intake elbow
FASS 150, MBRP downpipe, Diamond Eye Exhaust.
  #12
Old 12-22-2010, 10:42 AM
05smoker's Avatar
05smoker 05smoker is offline
I'm officially done!
Default
Agreed. This is the best tool I ever borrowed from you.
__________________
2005 2500HD CHEVY CCSB, Blackout VVT, FPE SCIV w/ 1057, 3" lowering shackles, overloads removed, Cooper Zeon LTZs on BMF REPRs. SOLD
Thanks to Fleece, Blackout Performance, Genes Machine Shop, Tim, Bullfrog, Simon, Mark Broviak .......
Remote mount turbo, Electric Water Pump, Cheetah turbo - Member #1
  #13
Old 12-22-2010, 11:00 AM
403turbo's Avatar
403turbo 403turbo is offline
<--It's whats for dinner!
Default
If the heads are off it is easy, I did basically what Tom did. I took some measurements and just turned up a piece of 12L but brass would be even safer.
That's the only way I've ever done it, heads have been off, it seems like squishing a rubber stopper would work though. The right tool is critical but $150 seems like a lot.
Merry Christmas to Everyone.
__________________
2001 EC/SB
EFI LIVE
MA STG III
BAUER RACING HEADS
DE-LIPPED PISTONS
CALICO COATED BEARINGS
AFE Stage 2 Intake
Intake Horn Mod
Bilstien 5100's
Cognito Braces
Tie Rod Sleeves made by me (nobody will miss that bar of 303SS)
"People are bastard coated bastards with bastard filling"
  #14
Old 01-09-2011, 11:44 AM
durallymax's Avatar
durallymax durallymax is offline
Default
It depends on how often you use it. I use mine a lot, so to me it was worth it. I borrowed the dealers tool 4 times before I bought my own. I used it more than they did. The cups are kind of soft though so dont get too bull with ghetto rigged tools.
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #15
Old 02-15-2012, 01:50 PM
sootmonster sootmonster is offline
FNG
Default
i bought a generic puller off ebay that seams to work really well, though i never used the Kent-Moore so i guess i really dont have much to compare it to. ive used it one 4 motors so far with no problems. im sure i could have riged up something that would have got the job done but id rather pay a little and get a tool that is made for the job. i think this is the same one i bought http://www.ebay.com/itm/duramax-inje...item2a19bcd8d7
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
