  #1
Old 05-19-2010, 07:54 PM
knagel's Avatar
knagel knagel is offline
weakest link finder
Default who makes the best 2.8 and 3.0 turbo
Like the title says..... who makes the best 2.8 and 3.0 turbo for our trucks. List the pros and cons. Drivability? all out performance? Compressor size vs. turbine size and housing A/R. Lbs/min if modified. ETC.
Let me know what ya think.
Kev
__________________
2006 GMC, CCSB, 4x4, LBZ, EFI Live, 33x15.50x18 Mickey Thompson AT, SoCal fully built mortor with stage 2 heads and pulling cam, "big" head studs, main studs, 60% over injectors, dual CP3's, 3.0 turbo, BD manifold, FASS 95 GPM pump, Sun Coast Stage 4 with a 1055 converter, Eaton front locker, cold air induction ram air hood, PVC reroute, single 5" mitered stack, 6" Fabtech lift, Cognito braces, HD tie rods and center link, front and rear dirveshaft loops and ujoint shields, rear bumper kill cord, turbo shield, HD idler pivot assembly, steel drive shaft with larger u-joints, custom front weight bracket, custom hitch
"Wound Up"
  #2
Old 05-19-2010, 08:08 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
Precision Turbo
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #3
Old 05-19-2010, 08:15 PM
jpowel29's Avatar
jpowel29 jpowel29 is online now
Default
Hard to argue with the success of Precision Turbo
__________________
Trying some new things...
  #4
Old 05-19-2010, 08:28 PM
JD Dave's Avatar
JD Dave JD Dave is offline
In way over my head
Default
Curtis Emery got his new 2.8 from ED.
__________________
Special thanks to: HSPDiesel.com, Wagler Competition and S&S Diesel.
  #5
Old 05-19-2010, 08:34 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
What they said.
If you aren't into spending as much money as a Precision costs (they are $ because they have custom machined billet wheels in them), you can get something about as good from Engineered Diesel. This is the route I'll be going. The price for what you get s great IMO and I've seen excellent customer service from them.
I'm sure there's several others that can set you up a custom charger but I'm just not familiar with many others.
BTW, I doubt you are going to be able to do much towing or even have very good street manners with the best, meaning most competitive, 2.8 or 3.0 chargers. If you've got to have that, you might as well get an A5K or something similar from a turbo shop. No, it may not be the best on the track but its pretty dang good and still has as much street manners as one can realistically expect from a charger that size.
Good luck
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #6
Old 05-19-2010, 08:40 PM
JD Dave's Avatar
In way over my head
Default
Before I went with MPI Twins I was going to get Danville to build my 2.8. They might be worth looking into also.
__________________
  #7
Old 05-19-2010, 09:36 PM
Dan@PPE's Avatar
Dan@PPE Dan@PPE is offline
Diesel Enthusiast
Default
Kevin,
Give me a call...
Dan
714-985-4825
__________________
2500HD CC/SB LB7 2 Wheel drive 950+ RWHP
11.17@126 in the 1/4 with a 7.2x@100 in the 1/8th.
NEW BEST in the 1/8th 6.95@102, 10's Here I come!!
2500HD CC/LB LB7 4X4, Towpig
2500HD RC/LB 4X4.............. 9 seconds of fury!!!
Pushing the D to the MAX........
  #8
Old 05-19-2010, 09:59 PM
JoshH's Avatar
JoshH JoshH is offline
Default
Are you looking for something off-the-shelf or custom? I hear really good things about Precision's custom turbos. There are a few members here running them, but I think they are a fair amount larger than 3.0".
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #9
Old 05-20-2010, 04:31 AM
02bigstrokin's Avatar
02bigstrokin 02bigstrokin is offline
Default
Quote:
Originally Posted by SmokeShow View Post
What they said.
Good luck
you know i used to think the exact same thing about big singles and daily driving them and such, but i rode in dustins truck yesterday and hes running a s480 a single and i think its all in the tuning. his truck is not bad at all, and i would even venture to say you could probably tow with it. surpised the shit out of me.
__________________
Iím Kenny Powers! And I am very upset with how I am acting right now. I just have a very hard time expressing my emotions, and I canít stop from yelling.
  #10
Old 05-20-2010, 05:08 AM
Slick Slick is offline
Default
Somehow I don't think Kusilek would be towing/daily driving with his setup if it was in a stock truck chassis... Could be wrong.
As with most things, if you are going all out, there is some give and take.
  #11
Old 05-20-2010, 06:46 AM
CurtisEmery's Avatar
CurtisEmery CurtisEmery is offline
Default
I am very happy with my e.d. 2.8 its spools very easily for the size of the wheels it was speced with. Mine set up with a 72mm inducer and I believe 114mm exducer comp wheel and race cover. Flow rating is right around 110lbs/min. The turbine is a 87/80 wheel with a 1.00 housing. The drive pressure is very low compared to my old set-up. I am seeing 40-45 psi at 4000-4200rpm drive pressure is about the same. I am hearing a lot of great things about Precisions offerings as well. I think you would be very happy with either companies offering.
__________________
The Puller: 2003 Red Chevy CCSB LB7 "Locomotive Breath" -SOLD!
Socal Diesel-Profab Performance-Turbo Re-Source-Pressurized Solutions-Ridgerunner diesel-Inferno Diesel-Inglewood Transmission-Precision Convertor-Schaeffers Specialized Lubricants
  #12
Old 05-20-2010, 06:51 AM
Default
Oh I forgot the price was very reasonable at $1850 I don't drive much on the street anymore but it has very good street manors for the size of the charger.
__________________
  #13
Old 05-20-2010, 01:42 PM
knagel's Avatar
weakest link finder
Default
Thanks for all the replies guys! This helps. I am looking for something with low drive pressure, spools easy, and flows aroung 120 lbs/min. Will be looking at precision.
__________________
"Wound Up"
  #14
Old 05-21-2010, 06:38 AM
Default
I believe the E.D. 3.0" is flows more than 120lbs/min. Chris told me they had a dodge with a S400 and their billet 83mm wheel made 1340hp a while back. Just some food for thought. Anyone know what the Precision 2.8, 3.0, etc flows lbs/min? Last time I spoke with them they were pretty standoffish on giving me the exact specs of what I would be buying.
__________________
  #15
Old 05-21-2010, 07:06 AM
madmatt's Avatar
madmatt madmatt is offline
Default
add another vote for precision!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
