  #1
Old 04-26-2010, 06:01 PM
MMLMM's Avatar
MMLMM MMLMM is offline
Default Rail pressure with 2 micron filter....
So I ditched the factory setup and went with my own setup by my lift pump (after it) I am running a 2 micron filter there. I noticed my rail pressure has been low but not sure if I am having lift pump issues again or not. I just swapped on a 12 micron baldwin to test so Ill see if that clears it up a bit later.
What are you guys seeing? 2 micron too little for getting enough fuel through?
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
  #2
Old 04-26-2010, 06:45 PM
dmaxlover's Avatar
dmaxlover dmaxlover is offline
Default
I'm running twin CP3s on my LB7, so not sure if my input will help or not. My Airdog 150 has a 2 micron filter on it, and it's the only filter I run. All the stock filtering is gone, and there is no issues with rail pressure, or lift pump pressure.
  #3
Old 04-27-2010, 03:55 AM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
Default
I have a 2 micron CAT filter on my truck and the stick filter ( 2002-LB7 ) with the Laing twin lift pumps.
On my biggest tune it will dip to 19,500 and recover to about 21,000 psi and hold steady.
I have not logged the LBZ with the AD-II/165 yet but as a side note my 2002 has 125K miles and since 7K miles it has had a 2 micron CAT filter on it and it still has original injectors.
I will take the 2 micron filter over a little lost rail PSI any day.
__________________
2016 Denali LML----> 2012 Denali LML SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB, 4x4
~Powered By "MOONSHINE"
12.525 at 107.07
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009...................SOLD 01/2014
  #4
Old 04-27-2010, 04:37 AM
JOHNBOY's Avatar
JOHNBOY JOHNBOY is offline
< Rocking the Big Single!
Default
I run a CAT(actually WIX) 2 micron filter after my lift pump (Holley HP150). Works great. Bad fuel will clog it in a hurry. What do you have for a lift pump? Have you check pressure after the filter idling? I know I loose almost 2 PSI thru a fresh filter. So if your running a setup with a built in regulator like the PPE then you probably need to up the pressure. I moved my regulator after so the filter gets full pressure.
__________________
The Big Stick
2002 GMC 2500HD Crewcab Long Bed LB7 ZF6 Southbend Triple Disk clutch, Alive with EFI Live from Mcrat Racing, Crower rods, LB7 cut pistons by JB, Cam and push rods by EEP 80% Extrudehone injectors, CP3 X 2, Socal Diesel Springs and Ti Retainers, A/C delete by JB
The wifes truck
2007 Classic Chevy Crewcab Shortbed LBZ 6speed Allison Loaded Basicly stock. Little EFI tune and a Trans Go Jr.
  #5
Old 04-27-2010, 05:07 AM
skintback's Avatar
skintback skintback is offline
Take this one to church
Default
When i installed the AD i did away with the stock setup so i can't say what mine did for psi +/- but before that i ran a edelbrock 1792 with stock filter at 10-17 psi with no problems.
What is the filter # on the cat 2 micron and does it separate water? I'm looking to ditch my AD but i'v already did away with the stock filter so i'll need to get a new filter setup.
__________________
LLY CCSB 4x4
Howards rods
Lockup Box
66/80
100%
2CP3's
  #6
Old 04-27-2010, 05:45 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Mike, didn't you ditch your factory filter too?
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #7
Old 04-27-2010, 06:47 AM
BoiseRob's Avatar
BoiseRob BoiseRob is offline
Default
The new filters max flow is 50 gph...
  #8
Old 04-27-2010, 07:17 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
im running the cat 2 micron and the stocker filter and I havent seen any rail pressure loss
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.85 @ 145
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #9
Old 04-27-2010, 07:59 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Mike it's all about the gph of the filter it has nothing to do with the micron rating
you can have a 2 micron that flows 500 gph or 5 gph
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #10
Old 04-27-2010, 09:12 AM
MMLMM's Avatar
Default
I have the factory filter gone. I'm running the cat 2 micron. Yea ever thought about the actually filter flow. I honestly think its my piece o chit fass non filter pump. The pump used to read about 14psi at. Idle but I have since removed gauge when I ditched factory filter. I run quite a bit of duration in my tune. Anyone know some flow numbers for these 1-14 (thread size) filters like the cat? I drop to about 131mpa on the rail.
__________________
2002 LB7 EC/SB
  #11
Old 04-27-2010, 10:30 AM
stacks04's Avatar
stacks04 stacks04 is offline
Default
mike for what its worth, i just logged a wot run to check, i am running the a-d 150 and stock filters. i have not changed or checked the a-d pressure so i dont know what its at but on wot i drop down to 21k and recover to hold 22.5-23k. not a huge pulse but 2900ms. i command 170 mpa. hope this helps.
__________________
2004 CHEVY CREW CAB
  #12
Old 04-27-2010, 01:17 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Quote:
What is the Cat part number on your filter? I'll see what I can come up with for a GPH.
  #13
Old 04-27-2010, 01:27 PM
kjp800's Avatar
kjp800 kjp800 is offline
Default
Not to be off topic, but what filter heads are you guys using with the Cat filters? Are you getting them directly from Cat?
__________________
15 Chevy CCSB
05 Chevy CCSB
02 GMC ECLB Limited Pro Stock puller
  #14
Old 04-27-2010, 04:58 PM
Turbotug's Avatar
Turbotug Turbotug is offline
BEER SLAYER
Default
I run three fuel filters. 10m Cat, to a 2m Cat, and finally through the OE filter. With a single Kennedy lift pump I can hold 22k+ @3200ms.
__________________
Brandon
SunCoast
EFILive
HTT
588hp 1096tq
  #15
Old 06-09-2010, 07:24 PM
backe backe is offline
FNG
Default
Can you guys get some pics of your lift pump/filter set ups and stock filter delete. thx
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
