  #1
Old 04-08-2010, 10:52 AM
2004ChevyDmax 2004ChevyDmax is offline
FNG
Default Engine Operating Temperatures
My water pump was leaking out of the weep hole so I replaced it and now I have noticed that the engine temperature varies quite a bit. Used to, it hold steady at 185, now it seems to vary. I have noticed it getting up close to 210. The temperature will go from 185 to almost 210 while I'm driving.
Anyone know why it varies like this? Also, what temp. should I be concerned about it getting too hot.
Thanks,
__________________
Jason
04 LB7
Completely Stock, for now
  #2
Old 04-08-2010, 11:06 AM
stroke250's Avatar
stroke250 stroke250 is offline
diesel freak
Default
how many miles on it since the water pump replacement? did u bleed the system of air afterwards??
__________________
Todd
2013 F350
Tuned
  #3
Old 04-08-2010, 11:32 AM
FNG
Default
only a handful of miles since the replacement. I put the pump on Friday and noticed the temps varrying over this past weekend. I pulled the bolt that's on top of the housing when I filled the coolant up. This should allow "most" of the air to escape, but I am sure there are more air pockets in it. I am hoping that's what it is and it will all eventually bleed out. Is there another way to bleed the system?
__________________
Jason
04 LB7
  #4
Old 04-08-2010, 11:40 AM
Jared Duramax's Avatar
Jared Duramax Jared Duramax is offline
<---- $$$ Whore!!
Default
in the winter my truck runs at 185 and in the summer the needle never leaves 210
as long as it doesnt go over 210 you should be fine
__________________
Jared
2003 GMC Sierra 2500HD LB7
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
