  #1
Old 04-06-2010, 11:15 AM
FF34PIP's Avatar
FF34PIP FF34PIP is offline
FNG
Default Smoke or blow by
I was pulling my camper and noticed some slight smoke from under the hood when i stopped, it smelled like oil. Pulled over and could find nothing. Once I got back home and looked a little better I noticed some oil below the tube that comes out of the front passenger side of the block. I cant tell if it's doing it all the time, I've only seen and smelled it a few times since. Doesn't seem to be running any different. I have a PPE tuner set on #2 and a boost valve.
Anyone have any ideas?
  #2
Old 04-06-2010, 11:54 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
fill out your sig.
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #3
Old 04-06-2010, 01:26 PM
03maxpower 03maxpower is offline
Default
sounds like blow by to me check your oil if it aint dropping and you dont see oil anywhere else i wouldnt worry about it
__________________
03 ccsb 4" straight pipe
hp tuners 100hp tow tune THANKS TRENT
SoCal overhead gauge mount with stewart warner gauges 600-2200 degree pyro 0-60lb boost
ppe boost valve
hankook atm rf10 265/75/16 on pyo's 94000miles on truck
  #4
Old 04-06-2010, 01:40 PM
FF34PIP's Avatar
FNG
Default
How do I fill out my sig
  #5
Old 04-06-2010, 03:09 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Oil on pass front of an LB7 is "normal", thats where the crankcase vents.
Many questions to answer to even make an attempt to help...
How much weight were you towing? Hills or level ground? Engine under a lot of stress? Does it only make the smell after towing or under normal drivng?
How many miles on the truck? Last time you changed oil?
Ever checked the injector's balance rates? If so, how did they look?
Only real way for anyone to diagnose it is to be there to check the vehicle out, so the more info you give helps.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #6
Old 04-06-2010, 03:43 PM
FF34PIP's Avatar
FNG
Default
I'm towing about 9500 over the hills and through the valleys. Motor under stress. This was the first time to ever smoke or smell, now it does it all the time. Got under the truck today and I could see a little smoke comming from the vent tube. I changed the oil less than a 1000 miles ago, the truck has 160,000 mi. on it. I dont know how to check the balance rates.
  #7
Old 04-06-2010, 03:49 PM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
Default
Pull your dipstick and let a drop fall on a paper towel. If it @eperates into a light ring and a dark ring theres fuel/coolant in the oil. A crankcaase full of fuel will cause the breather to huff oil or smoke.
Its an easy check. Also, anyone with a tuner or efi can check your balance rates. Dealer can as well
  #8
Old 04-06-2010, 04:19 PM
FF34PIP's Avatar
FNG
Default
There were a few dark spots when i first dropped it on the towel but it didn't make two distinct rings. If there were coolant, wouldn't it make the oil milky looking.
  #9
Old 04-06-2010, 06:27 PM
Default
Quote:
Yep. You'd see it on the dipstick too. Fuel is hard to see, but when dropped on a towel, it seperates from the oil. Fuel in the oil is usually a sign of a bad/hung injector on an lb7.
If all you have is oil, thats a good sign. I know my lb7, when hot, would smoke a little out of the breather, but I had to be beating on it pretty hard to get that.
You're saying that just daily driving it does that now??
  #10
Old 04-07-2010, 06:13 AM
FF34PIP's Avatar
FNG
Default
Ya, since the camping trip it does it all the time after it warms up.
  #11
Old 04-07-2010, 09:52 AM
maxaholic maxaholic is offline
Default
How hot did your egts get? Or do you even have a pyro. My guess is that you either burnt a piston or gaulded the rings. But that's just a guess.
__________________
Shane
Gone but not forgotten 06 GMC RCLB 3/4 ton 4x4 Duramax ZF6
Now pimpin a '08 Dodge 3500 Mega Cab.
  #12
Old 04-07-2010, 03:04 PM
FF34PIP's Avatar
FNG
Default
I dont have any guages, need some obviously, if anyone has some for sale.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
