  #1
Old 04-05-2010, 06:29 PM
dordtrecht5's Avatar
dordtrecht5 dordtrecht5 is offline
Regular Cabs Rock
Default Steering Gear Box
Just a question for anyone who has done a gasket change on the steering gear box?
Is this a simple thing to do? The way that I understand it, it requires a bushing to be replaced as well.
Does anybody have a DIY on this so i can save some money as I am about 500 miles over my Ext. Warranty...kinda pisses me off cause the dang thing was losing fluid well over 2,000 miles ago, but couldn't get it in then. Not sure if they will be nice enough to honor going over the miles, being I have put those 50,000 miles on in a year and a half. That is what I get for not paying close enough attention to the miles.
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
Super High Flow EGR delete kit and Centerlink support by AllSeason
GMAX6 & ML-G HD
BT DieselWorks Lock-up
12.59 @ 105
SOLD
02 CCSB LB7 EFI Big tie rods/PacBrake bags/DVD Pioneer head unit Rockford Fosgate speakers/110-120voltAC inverter/Mastercraft MTR
Thanks go out to 770JOHNNYW and blk smoke lb7
International Association of Bridge, Structural, Reinforcing and Ornamental Ironworkers Local 21 Omaha, NE
United Steel Workers Local 1343 South Milwaukee, WI
  #2
Old 04-05-2010, 07:10 PM
770JOHNNYW 770JOHNNYW is offline
Default
anytime i have ever tore into a power steering box it turned into a disaster!!!!
  #3
Old 04-05-2010, 07:24 PM
Regular Cabs Rock
Default
wow......the one and only time that you have given me useful advice!!! LOL
j/k
That is what I thought. $450 was the quote from the stealership...parts and labor. Maybe the mechanic would do it on the side for a little less.
I don't know what the new box is like, but I hear the "old style" screw gears are not fun to mess with. I almost attempted it on my 70 Impala once upon a time.
Any other input is appreciated!
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
GMAX6 & ML-G HD
12.59 @ 105
SOLD
  #4
Old 04-06-2010, 05:47 AM
stacks04's Avatar
stacks04 stacks04 is offline
Default
just to be sure is it the gasket that is on top of the box under the aluminum cover with 4 bolts and the pitman shaft nut?
__________________
2004 CHEVY CREW CAB
  #5
Old 04-06-2010, 06:27 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
When I rebuilt mine it came with detailed instructions
I got a rebuild kit from the gear center
there was a specific tool iirc that was needed
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #6
Old 04-06-2010, 08:27 AM
Default
Quote:
j/k
come on dallas you always know im full of good advise and shit!!
  #7
Old 04-06-2010, 08:17 PM
Regular Cabs Rock
Default
thanks for the input guys....
here is what is going to happen:
it will be covered under warranty...plus that DAMN (ac/heater) fan speed problem that will happen again since GM won't put in the good one that is available worldwide. Hopefully they will diagnose and fix another problem correctly that they said they fixed incorrectly, which is unrelated to this topic.
However, I only have about 4,000 more miles on my warranty...then I am on my own. This is all good information to know. I have heard that PSC steering gear boxes are the way to go; however, I have not found one on the internet for 05 and above. Everything is 04 and under with the HDs.
If anybody has info, like a link to a page that has one, I would sure be interested in knowing just in case.
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
GMAX6 & ML-G HD
12.59 @ 105
SOLD
  #8
Regular Cabs Rock
Default
Quote:
that IS the one!
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
GMAX6 & ML-G HD
12.59 @ 105
SOLD
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
