  #1
Old 03-21-2010, 07:08 PM
backtanner backtanner is offline
Mr FNG to you
Default Fuel pump
02 2500 sputtered and died with no restart. Fuel supply shows psi of 4-5. Turning key to run does not get buzz from fuel pump (i assume). If it is pump where is it located? Checked autozone's site and looks like might be mounted to frame rail. One they gave was included with sending unit assy? Which is correct and if this is the problem what is the best course to get at this thing? Drop the tank or unbolt and slide bed back? Thanks all.
  #2
Old 03-21-2010, 07:14 PM
rgullett83's Avatar
rgullett83 rgullett83 is offline
Default
Need more info. Is this a Duramax?
__________________
Riley
Mine: 01 CCSB Siverado frame off restored with various parts from 01-06 built lly motor, built 03 trans, 2xcp3, 100% exergys, billet s366 and much more that I wont fill this space with...
Hers: 07.5 CCSB GMC Sierra SLT LMM, XD Spys, Tuned and deleted
  #3
Old 03-21-2010, 07:26 PM
okierzr's Avatar
okierzr okierzr is offline
Default
If it is a gasser drop the tank or remove the bed.I would use a DELPHI fuel pump,i have had to many problems with AIRTEX,CARTER,ETC.
__________________
2003 Crew Cab duallly 2WD
allison/lb7
amsoil bumper to bumper
afe stage 2 intake with amsoil-
air filter
EFILIVE WITH MCRAT TUNE
  #4
Old 03-21-2010, 08:05 PM
Mr FNG to you
Default
Yep it's the dmax
  #5
Old 03-21-2010, 08:19 PM
maxaholic maxaholic is offline
Default
There is no lift pump on a dmax. Unless you have added an aftermarket.
__________________
Shane
Gone but not forgotten 06 GMC RCLB 3/4 ton 4x4 Duramax ZF6
Now pimpin a '08 Dodge 3500 Mega Cab.
  #6
Old 03-21-2010, 08:27 PM
Mr FNG to you
Default
With that being said, what is the buzz that previously accompanied the key turned to the run position?
Also (and I know it is Autozone ) why do they show this pump listed?http://www.autozone.com/autozone/cat...&parentId=49-0
  #7
Old 03-22-2010, 04:51 PM
01LB7's Avatar
01LB7 01LB7 is offline
Default
i would crawl underneath and look on the inside of the frame under the driver's side and look to see what's been put under there
__________________
2003 CCSB, Arival Blue, lifted, SCIV w/ 1057, DSP5, AFE intake, 4in exhaust
2001 ECLB, sold
Thanks Bluemax and to Henry @ www.creaturesofthenightperformance.com
  #8
Old 03-22-2010, 07:06 PM
PhilsLB7's Avatar
PhilsLB7 PhilsLB7 is offline
Way Better Than Facebook
Default
How many miles do you have on your truck and have you had the injectors replaced yet?
My 02 did a similar thing. Mechanic I had at the time replaced the fuel pickup in the tank (really didn't know what he was doing). Ran for less than two weeks and stopped running again (don't ask because I don't understand it either). Took it to the dealer and found out one of the injectors was bad. Dealer went ahead and replaced all eight.
__________________
Phillip
02 Chevy 2500HD CC/SB 4X4 LB7 w/Allison Trans
Just stock
  #9
Old 03-23-2010, 06:16 PM
Mr FNG to you
Default
303k. With injectors being done about 15k ago.
Cranked the engine with the plunger on the fuel test port depressed and only got a gurgle. Am I correct in thinking that it should have squirted out of there like a porn star?
  #10
Old 03-23-2010, 06:22 PM
KEVINL KEVINL is offline
Default
I think The test port is the vacuum side
  #11
Old 03-23-2010, 06:25 PM
rgullett83's Avatar
Default
If you pump the heck out of the primer, there should be pressure at the port, however when the engine is running, it will be vacuum.
__________________
Riley
  #12
Old 03-23-2010, 06:26 PM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
Quote:
Yes it is.
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #13
Old 03-23-2010, 06:27 PM
Vrabel's Avatar
TOYAHOLIC
Default
Posible bad plunger/primer. leaking in air?
__________________
R.I.P.
ProFab Performance
  #14
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
No, there is no fuel pump in the tank to create pressure to push fuel out of the test port. Only way you will get fuel out of the test port is if you have added an aftermarket lift pump. The fuel test port is on the vacuum side of the CP3 so by depressing it and trying to crank the truck you will just allow air into the system.
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #15
Old 03-27-2010, 09:30 PM
Mr FNG to you
Default
I get fuel to the filter assy by way of the primer, but after 2 mins of pressing the primer button it still does not stiffen up. Is this normal? If not, what would it be indicative of? I would really like to rule out the CP3 if possible. Possible?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
