#1
does eneyone make bigger Intercooler tube for the lb7
__________________
02cc/lbd lb7 only the best ![]() ppe boost increase valve 19.5x6.75 rickson truck wheels 245/70/19.5 kumho krd02 {33"} frontier gear bumper front and rear trans flow 98gl. in bed tank with trax monitoring system airdog 2 165 268hp/539ft-lb {not bad for stock}
#2
Think Banks does for both sides of the LB7 only think AFE make the one side only.
__________________
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4 EFI Live,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter. Alot Of thanks To George aka BigDipper 11.53 @ 116.92 1.66 60's ![]() RIP LBZ 6/1/08@5:44pm she was strong She's Alive again Born on July 27, 2008, 11:59:02 PM ![]() |
#3
I have the Banks driver side tube and it fits great. i wouldnt bother replacing the passenger side because the factory one is 3" all the way to the intake horn. The intake horn is 2.5" so the banks tube is gonna do the same thing as the factory tube except with a reducer boot instead of the reduction in the tube like gm pipe.
__________________
Travis 03 CCSB lb7 06 2500hd ECLB 6.0 gasser 2010 Straight Diesel 2.8 Points Champion ![]() special thanks: B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel |
#4
Does the tube route the same way as the stocker?
__________________
2003 GMC LB7 CC/SB EFI by IdahoRob, Extreme Prejudice Stage 1 Trans , SDP Twins, Modded Intake Horn, FASS 150 -Derek 1/4 Mile 12.78 @ 105.9 MPH |
#5
__________________
#6
Quote:
Not exactly, but the fit on ours is much better: ![]()
#7
Can I get a pm on a price for this pipe
Kris
__________________
2001 Dmax/Alli CC/SB Pewter RIP stock Rods and block....9/2/12....Built motor 12/12/12. Moonshine Tuned, Carillo's, Race cast's, ARP mains/heads,socal cam, ported heads,Exergy 100's,PPE fuelers, Dipper built SCIV with Precision converter, Mike L. Cooler, Dipper pump rub fix Ultra Predator 8's on 285/55/20 BFG G-Force's EPRTriples ![]() ![]() ![]() CT SMOKE MEMBER #60
#8
does the tube help any? If so power or EGT's
__________________
03 Duramax 4 door Black Regency package, 6 inch lift with 305-70-16 on Foosh rims. Banks Ram Air, 4" MBRP exhaust, Heavy right foot |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
