  #1
Old 11-26-2007, 06:06 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default Valve Adjustment??
Does a person ever really need to do this as preventative/tune-up maintenance on a duramax? If so, proceedure and acceptable specs would be sweet.
Was restless last night trying to go to sleep and thought about this so I'm asking.
C-ya
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #2
Old 11-26-2007, 06:48 AM
dynarex dynarex is offline
Default
pretty sure they are hydraulic-no adjustment needed
__________________
07 lbz/ally-285/75 revos-banks intake and nokitty dual exh-kennedy lift pump-efi liveMCRAT merchant s/c iv and 1057 and lots of other cool crap
  #3
Old 11-26-2007, 09:22 AM
MAXLLY's Avatar
MAXLLY MAXLLY is offline
No Lemming Here
Default
IMHO, i would say no. They are hydraulic rollers, unless i screwed up the original adjustment at build time and they aren't makin' any noise, they are good. You can change characteristics a little with a tighter set up and a looser set up, but at what cost/benefit?
__________________
LLY/CCSB 4X4 SOCAL DIESEL-MIKE L-PPE-DPR-3 STG NX-II-ENGINEERED DIESEL-EATON-MAC RACING-BAYER 4 LINK-PW PERFORMANCE-ALSTON CHASSISWORKS-BOV-DUAL GATES.
Still tuned by a REDNECK TEXAN
  #4
Old 11-26-2007, 10:09 AM
MAXLLY's Avatar
No Lemming Here
Default
Quote:
I lied... I looked at the pictures i took and they are solid rollers. Don't crucify me, this is the first DMAX build i have done.
Sorry man.
__________________
  #5
Old 11-26-2007, 04:09 PM
JOHNBOY's Avatar
JOHNBOY JOHNBOY is offline
< Rocking the Big Single!
Default
Will let it slide this time!
Yes they are solid rollers.
Mitch
To answer your question. Unless it is noisy I would leave alone. My stick truck was in spec even after the high RPM beatings it took. IMHO Don't worry 'bout it!
__________________
The Big Stick
2002 GMC 2500HD Crewcab Long Bed LB7 ZF6 Southbend Triple Disk clutch, Alive with EFI Live from Mcrat Racing, Crower rods, LB7 cut pistons by JB, Cam and push rods by EEP 80% Extrudehone injectors, CP3 X 2, Socal Diesel Springs and Ti Retainers, A/C delete by JB
The wifes truck
2007 Classic Chevy Crewcab Shortbed LBZ 6speed Allison Loaded Basicly stock. Little EFI tune and a Trans Go Jr.
  #6
Old 11-28-2007, 06:59 PM
Default
wow there solid lifters-wheres the adjustment/lock nut on the rocker arm?
cool learned something again on this site!
__________________
  #7
Old 11-28-2007, 07:14 PM
SmokeShow's Avatar
Default
Mitch
IMO, my truck is louder (rattle - and it is louder, even on the stock tune) than others I hear, like my fiance's identical truck with about 75K more miles than mine.
Just thought maybe valve adjustment could be something else to add to the list of things to do.
John, you mentioned yours as being "in spec". What is considered "in spec" - looking for numbers.
C-ya
__________________
Mitch
  #8
Old 11-28-2007, 08:01 PM
02freighttrain's Avatar
02freighttrain 02freighttrain is offline
Team Salad Bartender
Default
The spec is .012 cold........ This is pretty sloppy compared to a gasser. I run mine @ .010, don't ask why. (.002) more lift.
They are a total pain in the ass to get to, especially the drivers side. If they are not noisy, forget about it. Most of the time a motor will sink the valves in the head a little after high miles and tighten up the lash. This may be why the factory spec is fairly heavy on the Dmax, considering it is made to last a while (high miles).
The possibility of screwing up something taking it all apart to adjust the valves ain't worth it.imho.
  #9
Old 02-16-2008, 10:24 PM
05lly2500hd's Avatar
05lly2500hd 05lly2500hd is offline
(903)293-6026
Default
ok I'm gonna have to do this when I recieve my shortblock.
I'll be installing heads and all myself.
Any pointers?
I have a copy of GM's service manual on my pc, but this is the most intimidating part to accomplish at least for me.
Thanks ahead.
  #10
Old 02-17-2008, 05:19 PM
mvnvltn's Avatar
mvnvltn mvnvltn is offline
Part's Limit Tester
Default
Its easy to do. Only two crank rotations required for proper adjustment.
__________________
2002 C/C Dually LB7
It has some (broken) stuff
  #11
Old 02-17-2008, 05:36 PM
Default
This may Help.
Adjustments
Valve Clearance Adjustment
Remove the fan clutch.
Remove both upper valve rocker arm covers.
Rotate the engine in the normal direction and put the number one piston at Top Dead Center (TDC) of the compression stroke. Number one cylinder is right side front. While turning the engine watch the intake valve to open and close. Align the mark on the crankshaft balancer with the pointer on the engine.
Loosen the valve clearance adjusting screws for the valve being adjusted.
Insert the feeler gauge between the tip of rocker arm and the valve bridge.
Notice: Refer to fastener Notice in Service Precautions.
Adjust the intake and the exhaust valve clearance to 0.3 mm (0.012 inch) with the engine cold. Shown are the valves that can be adjusted at number one COMPRESSION stroke TDC.
Tighten valve adjusting screw lock nut to 22 Nm (16 ft. lbs.) .
Turn the engine one turn in the normal direction and put the number one piston at Top Dead Center (TDC) of the exhaust stroke to adjust the remaining valve clearance. While turning the engine watch the exhaust valve to open and close. Align the mark on the crankshaft balancer with the pointer on the engine.
Loosen the valve clearance adjusting screws for the valves being adjusted.
Adjust the valve clearance to 0.3 mm (0.0112 inch) with the engine cold. Shown are the valves that can be adjusted at number one EXHAUST stroke TDC.
Tighten valve clearance adjusting screw lock nut to 22 Nm (16 ft. lbs.) .
Install both upper valve rocker arm covers.
Install the fan clutch.
  #12
Old 02-17-2008, 05:43 PM
(903)293-6026
Default
Thanks!
__________________
MAD AMERICAN DIESEL PERFORMANCE, LLC
Amsoil lubricants, S&B intakes, AFE, EFILive, MBRP, Suncoast, MPI twins, EFILive tunes and more...
website will be up soon...stay tuned..
(903)293-6026
  #13
Old 02-17-2008, 05:57 PM
(903)293-6026
Default
Here are the drawings I have. What I'm confused about and is probably a stupid question, but remember I've never done this before; is how do you tell compression stroke from exhaust? By the postition of the valves/rockers?
Like say cyl 1,3,5,7 intake and 1,2,7,8 exhaust are open with cyl #1 @ TDC on the compression stroke.
And
2,4,6,8 intake and 3,4,5,6 exhaust are open on the exhaust stroke of #1 TDC.
Is this it? That's what it seems from the manual but not sure?
__________________
(903)293-6026
  #14
Old 02-17-2008, 06:03 PM
Default
And
Not a stupid question....... Turn the motor over while watching the intake valve on number 1 cylinder. When it opens, keep turning the crank until it closes then continue turning the crank until the TDC indicator lines up on the Balancer. That will be TDC. One comment, it is not recommended to turn the balancer backwards if you go past TDC. It's always better to go through process again (only moving the crank in the normal rotation direction. Also pull the glow plugs. It will eliminate the compression resistance while turning it over.
Hope this is not confusing.
  #15
Old 02-17-2008, 06:18 PM
(903)293-6026
Default
Quote:
Originally Posted by 02freighttrain View Post
Not a stupid question....... Turn the motor over while watching the intake valve on number 1 cylinder. When it opens, keep turning the crank until it closes then continue truning the crank until the TDC indicator lines up on the Balancer. That will be TDC. One comment, it is not recommended to turn the balance backwards if you go past TDC. It's always better to go through process again (only moving the crank in the normal rotation direction. Also pull the glow plugs. It will eliminate the compression resistance while turning it over.
actually, that clears it up a bit. I think I've got it now, thank you!
__________________
(903)293-6026
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
