  #1
Old 01-23-2010, 11:59 PM
ghostrider01's Avatar
ghostrider01 ghostrider01 is offline
on here to learn!
Question Good or Bad?
Ive found a 2007.5 LMM for sale and im just wondering if there is anything really difficult with this motor such as tunning wise or overheating or just anything in general? Ive had a LB7 and a LLY and i have heard the LB7 is peoples favorite and the LLY's overheat until you solve that over heating problem, so im just really curious what are some pro's and con's with this year and the LMM. Ive been looking around on some of the threads but havent really seen any people having any trouble with them. Ive seen some people still running thier stock tranny's and able to be in the 12's, so does that mean that the 6 speeds are pretty tough? Ill probably be using this truck for DD and drag racing and kinda interested in sled pulling also.
__________________
01' LB7
  #2
Old 01-24-2010, 03:31 AM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
just the added emmisions crap (dpf)which im sure you will get rid of. after that it basically turns into a lbz. i think the lmm have defueling issue on the 2-3 shift. you got an updated transfer case(no pump rub). the 6speed trans with a transgo jr is a very good cheap band aid for small hp increases. good tuning will get you far plus you now have the dsp switch available. i think what people dont like about these engines are the pistons.
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #3
Old 01-24-2010, 05:30 AM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
Default
yea the expensive parts
__________________
2015 GMC Denali 4X4 CC/SB 2500 LML
20" MOTOs
Delete/PPEI/5" straight soon to come
2008 GMC 2500 (SOLD)
EFI,all deleted,rode hard,stayed together
2009 Chev 2500 (traded) EFI, all deleted, rode just as hard as her ^^^, stayed together
  #4
Old 01-24-2010, 11:29 AM
duramaximizer's Avatar
duramaximizer duramaximizer is offline
#1 Abuse Enabler ;)
Default
General tuning complications and the pistons are known to be weak as are the LBZ's. Everything else is good.
__________________
Currently driving a 2007.5 RCLB 4x4 LMM W/T White. Basic Mods Stock Turbo Transgo Trans & Mike L trans.
A hole in LMM piston #1 At the moment and 7 was cracked. Awaiting rebuild.
12.67 and I have to find the slip again.
Furthest Pull this year was 359.XX and limited by concrete blocks.
  #5
Old 01-24-2010, 11:37 AM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
Yes people are geting them in to the 12s with a stock trans but that does not mean the trans will holde much longer with out limping. pistons would be my consern.
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #6
Old 01-24-2010, 12:14 PM
on here to learn!
Default
So it looks like the pistons are the weak link on the LMM so far. Something else im concerned about is the dpf has been deleted and now has a Magnaflow exhuast on it but what happens if something would happen to the truck that could be covered by the factory warranty but since it dont have to dpf anymore what would i do? Because since the dpf is deleted the factory wont work on it correct? Where can i take it? Could i take it to a GM dealer and say that i have a 60 month 100,000 mile warranty, would they replace stuff for me then or would i just be crap out of luck?
__________________
01' LB7
  #7
Old 01-24-2010, 12:28 PM
JMDuramaxLB7's Avatar
JMDuramaxLB7 JMDuramaxLB7 is offline
YOU SAID MEMBER!!!
Default
Alot of warranty work depends on your dealer, some don't have a problem with mods but alot of them do and G.M. is cracking down on it also.
__________________
04 CHEVY EC/SB 2500HD
LB7, ALLISON, 4X4
MBRP 4" TURBO BACK
AUTOMETER PILLAR MOUNT BOOST/PYRO
EFI LIVE W/DSP5
BCI COLD AIR INTAKE W/ AEM DRY FILTER
BUILT TRANNY BY SMOKIN DIESEL PERFORMANCE (MIKE BODINE) W/ ML CONVERTER
MOTO METAL CHROME 955's W/ 305/65/17 DC CRUSHERS SUMMER
PYO'S AND 285 NITTOS WINTER
ALL ON HEADLIGHT MOD
COOTER TIE ROD SLEEVES/TRACTION BARS
GOODMARK 2 INCH COWL HOOD
  #8
Old 01-24-2010, 06:05 PM
unfinished business unfinished business is offline
Default
I went 12.80's on a stock trans with 20" rims. So far I have been very happy with my LMM (knocking on wood)
__________________
2008 LMM 4x4 SB CC -A few boltons
  #9
Old 01-24-2010, 07:30 PM
on here to learn!
Default
yeah i like the look of it and all i am just mainly worried with the warranty. Could i just buy a dpf for some one and put it on when i have to take it in? Is efi detectable when you set you ecm back to stock? Im wondering if i would be better off getting a different ecm and putting a tune on that on and just switch them out. This truck has 305/55/20 tires, but im already aware ill have to build the tranny because it wont last forever without limping
__________________
01' LB7
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
