  #1
Old 12-14-2009, 12:13 PM
DIESELJEFF DIESELJEFF is offline
CETANE ADDICT
Default Turn off egr with efi live
I recently bought efi live and have been messing with it a lot. I am still confused as to how to turn off the egr system. Anybody want to let me in the secret? Thanks in advance!!!
  #2
Old 12-14-2009, 12:25 PM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Default
If you bought EFI Live from one of the site vendors and got a free tune with it it most likely had the EGR disabled in that tune.
__________________
Dustin
06 Chevy RCLB 2WD "NO REHAB" - Shop Race truck. Stock bottom end, DA heads and cam, S485/96 single, 300% overs and 14mm CP3 by S&S, DA trans. 6.56 @ 106------10.49 @ 122
05 Chevy ECSB SS "OTHRGRL" - DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
04.5 Chevy CCSB "WORKMULE" - Shop Work truck and stock class sled puller thrown together with spare and scrap parts. 11.81 @ 115------7.24 @ 96
  #3
Old 12-14-2009, 04:51 PM
CETANE ADDICT
Default
Im sure it did but i dont know what he did to change it. What table do i change or is it just in the mil request page?
  #4
Old 12-14-2009, 05:48 PM
Big Block 88's Avatar
Big Block 88 Big Block 88 is offline
Multiple choice muscle
Default
Engine systems, EGR, if your values are negative you are good to go.
__________________
"SARGE" 1966 Jeep/Kieser M35a2 duece, whistler multi fuel engine 6x6 pure beast mode
"Maxine" 2007 Silverado CCSB LT3, LBZ/alli, CTS, PYO's and 265 Hankooks, EFI, MBRP, PPE stuff, bilstien 5100,
"Rusty Bullet" 2007 Classic CCSB, 1 LT, Greystone 4X4, Cognito, EFI, tuned by McRat/Neens, DSP by Mike Meyer, PPE stuff, Autometer, Trippin, Airdog, MBRP, Bilstein, Hankook, TransGo Jr SOLD 437 hp 1051tq STOCK TRANS
"Tow Pig" 2003 LB7/Alli EC/LB 2x4 4" straight, cts, EFI, SOLD
"Squirel" 2000 Chevy Silvy 1500 RC/SB 5 speed 4.8 little screamer back to stock, had polished 243's ls6 intake cam and valve train
"Great White Hope" 2013 silverado 1500 z71 CCSB loaded Corsa Exhaust, gmpp intake, leveled, 5.3 HO
"White Power"-2012 GMC Sierra, White on tan leather, CCLB Dually, 4x4 LML Alli, All stock
  #5
Old 12-14-2009, 06:15 PM
MMLMM's Avatar
MMLMM MMLMM is offline
Default
Go to the EGR area and set the ect/rpm values to where it will not see them and good to go. Turning the DTCs off is not turning off the EGR, only the MIL.
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
  #6
Old 12-14-2009, 07:00 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Open the stock and compare it with your tune
If he didnt change the settings for anything EGR related let us kn ow
I will just tell you the table numbers then
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #7
Old 12-14-2009, 08:49 PM
CETANE ADDICT
Default
you guys have answered my question. thank you very much. i looked at the stock tune vs. the new tune and now it makes sense. the rpm number was changed so that it wont come on after 200rpms. i would go ahead and assume that its disabled. thanks again!!!!
  #8
Old 12-14-2009, 08:53 PM
9W3-HD's Avatar
9W3-HD 9W3-HD is offline
Just another Duramax dude
Question
i bought my efi from Nick and he turned the egr off and the tune he sent me and my truck would't run without a blocker plate in the egr. It ran about 1 mile then started spewing white smoke and cutting out. He told me I needed the plate in so he sent me another tune with it turned on and it ran fine. I havn't heard of that happeneing to anybody else's truck though..just mine
__________________
08 D/A CC SB, 6'' Fabtech, HD Tierods, UCA's, EFI Live, RMT Conversion, trans go jr, 5 INCH strait pipe all the junk deleted
  #9
Old 12-14-2009, 09:53 PM
CETANE ADDICT
Default
i have a blocker plate in and it runs great. thanks for the info.
  #10
Old 12-14-2009, 11:59 PM
Turbo Performance's Avatar
Turbo Performance Turbo Performance is offline
Default
Quote:
That does sound odd. I've had mine turned off with no blocker plate for a couple years with no issues (I need one, just haven't done it ). Maybe it's an LMM thing? Either way, first time I've heard of it happening.
  #11
Old 12-15-2009, 12:11 AM
MadMaxx61's Avatar
MadMaxx61 MadMaxx61 is offline
Devilmaxx
Default
Quote:
Nope I don't have a plate in and I have had my EGR off for almost 2 years.
__________________
Steve
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
1984 GMC Jimmy 2-Door
1998 Buick Century Limited
Sold It will be missed. 1985 Mercedes 300SD - Running still need work.
Sold It will be missed. 1995 C/K 3500 4X4 Dually 6.5L
Mods: K&N air intake, 80Hp chip, 97 cooling, twin fans, #9 Resistor, FSD Heat-Sync, Full Pillar 3 Gauge (EGT, Boost, Transmission),
  #12
Old 12-15-2009, 12:16 AM
Default
Quote:
My first idea was definitely a stab in the dark. I don't understand why his truck would white smoke and cut out from turning off the EGR with no blocker plate. Doesn't really make sense to me.
  #13
Old 12-15-2009, 12:32 AM
MadMaxx61's Avatar
Devilmaxx
Default
Ya I am not sure I even started out with tunes from nick and still use some as a base for the tunes I run now.
Never had a problem with any tune that had the EGR off. Now as for the white smoke that could be from it erroring (is that even a word?) out and just staying open. I know that on some tune I have had to play with the number to keep it from erroring out stuff.
__________________
Steve
  #14
Old 12-15-2009, 02:34 AM
LBZ's Avatar
LBZ LBZ is offline
Default
X2. I ran for quite awhile with my egr off and set to no codes with no plate-no problems at all!!
  #15
Old 12-15-2009, 08:09 AM
9W3-HD's Avatar
Default
Ive have a blocker plate, just been lazy to tackle the knuckle buster! I guess I'll find out how that tune runs once I get it in....I have often wondered if there wasn't something else wrong with the tune that he did't tell me about and I never compared the two because Im still EFI Illeteriate!!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
