  #1
Old 12-13-2009, 08:25 PM
blowinsmoke's Avatar
blowinsmoke blowinsmoke is offline
obsessed not addicted
Default LB7 dOWNPIPE?
Does the lb7 have enough room to do the downpipe mod and will it make a big difference if i do it?
__________________
2002 E/C Longbed 2500HD 4WD Chevy Duramax, PPE Hot Race Tuner, 15% over Extrude Honed injectors, S & B Intake, Silverline 4" SS Turbo back exhaust, , Airdog Gen II 150 Lift pump, Air Intake Horn Modified, Banks Big Head Wastegate, Isspro Pyro and Boost Gauges and Suncoast IV with 1056 converter coming after Jan 1 if it makes it that long
  #2
Old 12-13-2009, 08:33 PM
KEVINL KEVINL is offline
Default
What is the downpipe mod?
  #3
Old 12-13-2009, 08:44 PM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
other than heat wrap, what is there you can do?
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #4
Old 12-13-2009, 08:54 PM
Mike_S's Avatar
Mike_S Mike_S is offline
OOPS!
Default
Threre is enough room for 3.5 inch pipe if you rout it right. I built the DP off of my S400 turbo with 3.5 and wrapped it and it works great. I did pull the sound mat off the firewall to do it though.
__________________
Nancy:
2004 CC SB, LB7, 2500 HD, Borg Warner spinny thingy, Carillo tough stuff, Transgo/suncoast tranny stuff, DMP squirt guns, and a couple custom parts.
The General:
1994 EXT Cab, SB, 1500 HD, 350 SBC, Whole Buncha $hit And Its Still Not Fast.
(I do all my own work...and thats not always good)
Good, Fast, Cheap...You Can Only Have Two!
You only need 2 tools: duct tape and WD-40. Duct tape for when it moves and isnt supposed to, and WD-40 for when it don't move and should!
  #5
Old 12-13-2009, 09:05 PM
maine04max's Avatar
maine04max maine04max is offline
Default
talk to Henry , I believe he has a aftermarket downpipe for the lb7 without breaking the bank
__________________
9/26/09 450 rwhp & 869
4/01/10 mild built motor
05/23/10 656rwhp 1190 trq 12.06 @113
07/20/10 Homebuilt 366 /480 twins
10/23/10 11.74 @121 soft launch
9/11/11 11.39 @120
  #6
Old 12-14-2009, 08:13 AM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Default
Quote:
The ATS downpipe will fit an S400 and is 4" all the way through, that's what I run on my truck.
Quote:
I also sell the ProFab true 3" high flow downpipe. If you want to keep the band clamp to the front pipe there is no reason to go bigger than 3". It comes ceramic coated black and runs $350:
He is also considering building a 3.5" downpipe that will delete the band clamp to the front pipe and flare to 4" at the end to meet up with a front pipe (after you cut the front bend off the front-pipe), so if you would rather have that speak up so we can let him know what the demand is.
__________________
Dustin
06 Chevy RCLB 2WD "NO REHAB" - Shop Race truck. Stock bottom end, DA heads and cam, S485/96 single, 300% overs and 14mm CP3 by S&S, DA trans. 6.56 @ 106------10.49 @ 122
05 Chevy ECSB SS "OTHRGRL" - DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
04.5 Chevy CCSB "WORKMULE" - Shop Work truck and stock class sled puller thrown together with spare and scrap parts. 11.81 @ 115------7.54 @ 92
  #7
Old 12-14-2009, 12:54 PM
Mike_S's Avatar
OOPS!
Default
Quote:
True, but I like to build stuff, and thats what I had laying around. It seems to work fine, but for those that don't want or dont have the tools/ability the ATS pipe is a great option for sure.
__________________
Nancy:
The General:
  #8
Old 12-14-2009, 04:12 PM
Vasbinder's Avatar
Vasbinder Vasbinder is offline
Default
how much?
__________________
2011 Duramax
  #9
Old 12-14-2009, 06:36 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Default
Quote:
Originally Posted by Vasbinder View Post
how much?
It's in the post 350.00
__________________
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
  #10
Old 12-14-2009, 09:32 PM
ynotracing2221's Avatar
ynotracing2221 ynotracing2221 is offline
DMaxed
Default
The 3.5 to 4 sounds cool, What kind of gains have you guys noticed with the one pictured?
__________________
2016 GMC 2500HD Denali
Stock......For now.
  #11
Old 12-14-2009, 09:37 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
Quote:
I have the 3" one pictured on my GMC , i felt really good gains for what the part is , my best guess was 20-25 hp by the SOTP meter , and flow was increased enough that i had to crank down my manual waste gate alot tighter because it was being blown open a whole lot sooner after the down pipe install I dont have an EGT gage in the truck so i dont know what the reduction was but my guess is they would be lower .
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #12
Old 12-14-2009, 11:18 PM
DMaxed
Default
Quote:
Thanks Trent, I think it is time to save for one of these, prob. after christmas.
EDIT: By the way, how much of a PITA was it to install?
__________________
Stock......For now.
  #13
Old 12-15-2009, 08:59 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Pull the trans.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #14
Old 12-15-2009, 09:07 AM
TrentNell's Avatar
Default
Its a pain , not horrible if you have decent tools and a little bit of "gumption " , for really tight bolts get a small bottle jack and a good quality wrench or socket and put the bottle jack between the top of the firewall and the wrench , it will help you crack them loose . heat/torch helps sometimes too.
__________________
Trent Nell
  #15
Old 12-15-2009, 12:59 PM
Mike_S's Avatar
OOPS!
Default
Quote:
Originally Posted by Mike L. View Post
Pull the trans.
X2
I made the mistake of trying to BILD mine with the trans in there...LOL!
__________________
Nancy:
The General:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
