  #1
Old 11-11-2009, 09:19 PM
dmaxadermist's Avatar
dmaxadermist dmaxadermist is offline
FNG
Default no oil pressure
ok heres the deal, i bought an 03 silverado duramax that was wrecked and not running, got it tore apart and the trans computer was gone and some of the wires on the clear clip (c2) were pulled out, well after buying both computers and repairing the wires with a bunch of papers i started it up after getting the security mode off and only had a couple minor codes but the oil pressure hand doesnt move but very a little and only when i rev the engine but the motor runs super smooth and no noises and also the low oil pressure light or ding just isnt there im thinkin the sensor is messed up but im open to suggestions please help
  #2
Old 11-11-2009, 09:36 PM
wikdlmm's Avatar
wikdlmm wikdlmm is offline
<-- OWFA
Default
Sensor would be my guess...
__________________
08 CC/SB 2WD-sold
12.89 at 106mph 1.82 60ft.. Tuned by JOSH H
[B]
  #3
Old 11-11-2009, 10:14 PM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
Default
I have no idea if this is even something you can log, but there may be a way to use EFI to see if you have oil pressure. The guages in these trucks are inaccurate as hell, mostly just idiot lights. Someone with EFI experience can maybe clarfiy that though....
  #4
Old 11-12-2009, 05:37 AM
lotsofmiles lotsofmiles is offline
Father of the Van
Default
heres a couple oil pressure threads when mine went out.
http://www.duramaxdiesels.com/forum/...ad.php?t=12433
http://www.duramaxdiesels.com/forum/...ad.php?t=12507
__________________
Quote:
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
  #5
Old 11-12-2009, 09:26 AM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Default
If the computer that you installed is not from the right year of LB7 it can cause the gauge to not work. A tune from an 03/04 loaded onto an 01-02 LB7 will cause this and I assume it would work the other way around as well. A reflash of the right tune for your truck will likely fix the problem.
__________________
Dustin
06 Chevy RCLB 2WD "NO REHAB" - Shop Race truck. Stock bottom end, DA heads and cam, S485/96 single, 300% overs and 14mm CP3 by S&S, DA trans. 6.56 @ 106------10.49 @ 122
05 Chevy ECSB SS "OTHRGRL" - DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
04.5 Chevy CCSB "WORKMULE" - Shop Work truck and stock class sled puller thrown together with spare and scrap parts. 11.81 @ 115------7.24 @ 96
  #6
Old 11-12-2009, 06:08 PM
FNG
Default
ok i finally think i figured somthin out i put a mechanical oil pressure gauge on the oil filter housing there was a plug in ther i took it out and screwed it in,, would this be accurate? my gauge only goes to 80 psi and it was hitting the tack past it just wondering. i appreciate the help
  #7
Old 11-12-2009, 06:54 PM
othrgrl's Avatar
Default
Depending on which port you put it in that is probably reading pressure from before the filter and cooler. It is likely what I described above, flash the correct tune for the truck onto it and the gauge should work. If that's not the case then the sensor or wiring is faulty.
__________________
Dustin
  #8
Old 11-12-2009, 07:34 PM
FNG
Default
ok how would i do a flash tune?
  #9
Old 11-12-2009, 07:44 PM
othrgrl's Avatar
Default
You would have to either have a GM dealership do it for you, someone with a Tech II and subscription or someone with EFI Live and access to a stock tune that would work correctly on your truck. You could also send your ECM to an EFI Live tuner for them to flash it. Where are you located? If you are local to a reputable EFI Live tuner they could likely set you up with a performance tune for the price that GM would charge you to put a stock tune on it, or like I said you could send it to one.
__________________
Dustin
  #10
Old 11-12-2009, 09:20 PM
FNG
Default
well i am located about 40 miles east of bowling green kentucky.. if that helps, and call me stupid but i dont know what efi is i am new to the diesel scene also, what kind of cost would either of the tunes cost... and the last thing i was wondering if the port i put my gauge in was before the filter and cooler an everything would it read higher than what it would if it had already went through it doesnt really bother me that the gauge isnt working,,, i just want to make sure that my engine isnt junk for now thanks again
  #11
Old 11-13-2009, 06:38 AM
othrgrl's Avatar
Default
Yes, if you are reading it before the filter and cooler it will read higher, you lose some pressure in the filter and cooler and then the pressure is regulated after them. EFI Live is a tuning and logging tool used to write custom tunes for 98+ GM cars and trucks, including the Duramax. I'll PM you pricing.
__________________
Dustin
  #12
Old 11-13-2009, 09:12 AM
LBZ_Duramax LBZ_Duramax is offline
Default
It is the cluster most likely. 2003's are notorious for going out and if you have oil pressure on your mech gauge it is about 99% chance faulty cluster. Replace the stepper motors and then it will work fine with the updated parts and you wont have anymore problems
  #13
Old 11-13-2009, 09:36 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Check the oil to insure it's not 50% diesel fuel.
The engine computer will tell you if their no oil pressure, but it's threshold is very low. 10 psi or something like that.
Yes, checking it with a mechanical guage is good insurance.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
