  #1
Old 11-09-2009, 07:58 AM
bradpeterson bradpeterson is offline
FNG
Default Does diesel fuel gel these days
I here diesel fuel gels in cold temperature. Is that something I should worry about? I probably fill up weekly so fuel be fresh. If it gels what do I do about that? I see products at stores for gel diesel. Should i get some just in case? Is it as simple as pour in the tank and then wait so long or what? I hope this is the right area to post this. Many questions i have seem not to fall in the sub forum groups. The site seems to be to racers or pullers. am I on the wrong site?
__________________
2007 3500 red crew cab truck.
  #2
Old 11-09-2009, 08:32 AM
03maxpower 03maxpower is offline
Default
my fuel didnt gel til about -18 degrees but i put some howes fuel treatment in it and didnt have any trouble since and will definately use the same stuff this year
__________________
03 ccsb 4" straight pipe
hp tuners 100hp tow tune THANKS TRENT
SoCal overhead gauge mount with stewart warner gauges 600-2200 degree pyro 0-60lb boost
ppe boost valve
hankook atm rf10 265/75/16 on pyo's 94000miles on truck
  #3
Old 11-09-2009, 10:26 AM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
fuel is usually treated. just use caution from where you buy it from.
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #4
Old 11-09-2009, 10:41 AM
PhilsLB7's Avatar
PhilsLB7 PhilsLB7 is offline
Way Better Than Facebook
Default
Brad,
You are in the right place. If you post something in the wrong place, one of the admin's will place it correctly for you.
As for fuel gelling, I agree with 03maxpower, it has to get pretty cold for the fuel to gel and you can use a good quality fuel treatment to make sure it doesn't. Personally I use PowerService in my truck. They have a summer time (grey bottle) and winter time (white bottle) formula. The winter time formula includes an anti-gel additive in it. I get mine from Wal-mart but you should be able to find it in other auto stores (check the net). If you do expereince a problem with gelling, PowerService also has a product called Diesel 911. It helps get your truck running again.
Keep asking your questions. Everyone on here can help from the simplest questions to the most extreme. Educating yourself is the best tool you can have.
__________________
Phillip
02 Chevy 2500HD CC/SB 4X4 LB7 w/Allison Trans
Just stock
  #5
Old 11-09-2009, 11:43 AM
FNG
Default
Thank you guys so much help. Love this truck more everyday.
__________________
  #6
Old 11-09-2009, 01:58 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Where do you live? Northern states you should keep some Power Service 911 in the truck no matter what. The refinery for your area will blend the fuel according to the temperatures in your area. With that said they are still only human and mistakes can be made. Last winter about half of the diesels here in Fairbanks jelled up because the refinery messed up the blend, But this is very rare.
  #7
Old 11-09-2009, 08:06 PM
Heath Heath is offline
Default
Good to know what fuel you are getting. Try and stick with the same station as much as possible once you know what you are getting. Some may keep #2 fuel all year, many switch to a blend in the winter months.
#2 fuel can actually start to crystallize at as high as 40F, but usually more of a concern below 20F. The blends can go to zero or below, but you just never know. So once you know what fuel you are getting, then you'll know whether to treat.
Also, if you fuel has any percentage of bio in it, this will make it gel a little sooner. The little added expense is worth eliminating a possible headache down the road.
__________________
Heath Palmer
AMSOIL Regency Direct Jobber
Contact me
Website
Purchase options
  #8
Old 11-10-2009, 04:22 PM
coldLBZ's Avatar
coldLBZ coldLBZ is offline
Default
Yes, diesel fuel does gel these days. I run additive in every tank. I just put in twice the amount in winter as I do in summer. When I gelled up it was about -30C. Since I started using an additive my truck has seen -50C, and I haven't gelled, yet anyway.
__________________
Dan
2006 Chevrolet 2500HD 4x4 CC/SB LBZ Allison
PPE Hot+2 ET, S&B Cool Air Intake, MBRP 4", PCV Reroute, BD Manifold, SD Manifold, SCIV/PPE-Precision Converter/Pump Rub Fix/T-Case Brace/SoCal Diesel Flexplate By Ted @ MPL
2014 GMC 1500 4X4 RC/SB 5.3L
2008 GMC 1500 4x4 CC/SB 6.0L 4L70E - GONE
  #9
Old 11-10-2009, 07:18 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
The biggest problem seems to be the mixing of Biodiesel in fuel. Some state like IN mix it in for tax breaks last year it left lots of guys on the side of the road. As of last year a lot of additives weren't stopping the Bio from causing fuel to gel. Howes seemed to work the best, but hopefully a lot of companies got some reformulation done this year.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #10
Old 11-10-2009, 07:51 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
my truck was in -25* winters for the past 4 years and I never had any problem with gelling or anything...
FWIW..
ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #11
Old 12-09-2013, 07:34 AM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Default
I am bring this back to life.......It's two degrees and my truck is not holding rail pressure. I have the truck in the shop to warm it up, but I was thinking of changing my fuel feilters on my fass. Is this always recommend when it is starting to gell. I need to get some part numbers get some new filters, but I am not sure what would be the best to get, what filter micron size and if i should get just napa, baldwin, or cat filters. Does the water separator need replace and what else do i need to do..... I run the normal dose of winter power-service with every tank of fuel.
__________________
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #12
Old 12-10-2013, 02:04 PM
Dozerboy's Avatar
Default
I would change then if they are past the 1/2 way point of your change interval. Napa, baldwin, and cat all have good filters. They generally don't have a bunch of option on what micron to get. Just make sure you have at least 1 on there that is 2 microns.
__________________
  #13
Old 12-10-2013, 02:19 PM
2012 DMAX 2012 DMAX is offline
Gearhead
Default
Is fuel filter % remaining any indicator of fuel gelling ? Let's say when I leave my driveway the % life remaining is 80%. I'm 10 miles down the road and it now says 70 or less. Will it do this if it's gelling ?
  #14
Old 12-11-2013, 03:58 PM
Dozerboy's Avatar
Default
No its not IIRC. It basically uses mileage and throttle % to guesstimate when it should be changed.
__________________
  #15
Old 12-11-2013, 05:43 PM
btfarm's Avatar
btfarm btfarm is offline
you know
Default
Quote:
The FF minder is just a15k mile countdown. No otherb parameters are involved.
Sent from my SCH-I535
__________________
Mike
2006 GMC EC/SB SLT. LBZ on Predator.
Blocked, Fingered & PCV Reroute. DE 4" SS DP Back
BFG 285s on PYOs. Putnam CL V, Prodigy. Adrian Box. 285,000/6545 hrs as of 5/15/15
Proud US Navy Veteran & NRA member
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
