  #1
Old 10-27-2009, 07:05 PM
HiMilz's Avatar
HiMilz HiMilz is offline
Default PPE Overhead gauge mount
I know I am going to feel stupid for not seeing it, but I got my PPE overhead gauge console last night and was going to install it tonight and I cant make it fit to save my life. Do you have to cut the peices out behind it that stop it from going in flush or am I just crazy. It didn't come with any instructions so I am lost. Has anyone done this? Can anyone help me?
__________________
01' ECSB 2WD - SOLD
200K+
EFI LIVE
Drag Truck 02' EC/LB - 2WD-SOLD
225K+
EFI-live
SC-IV
Raptor 150
CalTracs
5610-LBS
N20-150
12.94 @ 106
  #2
Old 10-27-2009, 07:31 PM
ynotracing2221's Avatar
ynotracing2221 ynotracing2221 is offline
DMaxed
Default
I bought Mine from socal diesel, not sure if it's the same but all I had to do is remove the cubby, then press it in. It is hard as hell to push in, but it does go, like I said not sure if they are the same, but mine was hard as hell to push in. Good luck
__________________
2016 GMC 2500HD Denali
Stock......For now.
  #3
Old 10-27-2009, 07:40 PM
bcjoe's Avatar
bcjoe bcjoe is offline
JERK
Default
On my truck the cubby had some tabs I had to cut a bit and then heat it up with a hair dryer for a few minutes then push with those girly fingers.
__________________
02 seirra
MPI bigguns
DSP5 Idaho Rob
Mike L stage 4 with pink monster
40 over Tripp sticks
airdog 165
5" MBRP
RickD castflows and uppies
Fleece tapper
  #4
Old 10-27-2009, 07:44 PM
HiMilz's Avatar
Default
Thanks thats what I was wondering about. I didn't want to cut anything I might need later.
__________________
01' ECSB 2WD - SOLD
200K+
EFI LIVE
225K+
EFI-live
SC-IV
Raptor 150
CalTracs
5610-LBS
N20-150
12.94 @ 106
  #5
Old 10-27-2009, 09:13 PM
uwyo_dmax's Avatar
uwyo_dmax uwyo_dmax is offline
Default
just push really hard its a tight fit
__________________
Justin
2003 Chevy LB7
EFILive
5" Exhaust, PPE Boost Valve, Modded Intake SD Intake Horn SD Tie Rod Sleeves
  #6
Old 10-27-2009, 09:15 PM
Hellrazr78's Avatar
Hellrazr78 Hellrazr78 is offline
Gearhead
Default
Heat it up!!! I cracked my console putting mine in. It slides out a little on boosted launches now.
__________________
Murdered CC/SB LBZ Duramax/Allison, Modded Stock Airbox, N-Fab Six Step, MBRP 5" Straight Pipe,EGR Blocker, EFI Live By Rob Coddens, Socal Overhead Mount, Spek Boost + EGT Guages, Cognito 4" Lift, HD Tie Rods, 20" KMC Ambush, 33" Toyo MT's, Big Dipper Suncoast Stage IV, Precision Converter, Airdog II 165.
  #7
Old 10-27-2009, 09:22 PM
Trippin's Avatar
Trippin Trippin is offline
SoCal Diesel
Default
The 01 consoles need to have the tabs in the corner trimmed away. Hellraz78 is correct. The 01 consoles are made from a harder plastic. I recommend heating them with a blow drier or setting them in the sun for a little while.
Guy
__________________
I have disabled the PM feature, feel free to send me an email. info@socaldiesel.com
SoCal Diesel Web Store
Hard Core Duramax Parts!
$ Contact Me To Become An EFILive Reseller $
SoCal Diesel CNC Ported Dmax Heads (661) 775-5620
How Big Is Your Duramax? 7.1 Liter Kits Here!
Mahle HP Cast Pistons with Thermal Barrier Coating
Alternative Firing Order Duramax Camshafts Designed by SoCal Diesel
**Carrillo Rods In Stock**
Mahle Forged Duramax Piston Kits Available Here
  #8
Old 10-28-2009, 11:30 AM
HiMilz's Avatar
Default
Thanks got it!
__________________
01' ECSB 2WD - SOLD
200K+
EFI LIVE
225K+
EFI-live
SC-IV
Raptor 150
CalTracs
5610-LBS
N20-150
12.94 @ 106
  #9
Old 10-28-2009, 11:52 AM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
Now post up some pics
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #10
Old 11-20-2009, 03:11 PM
Greydog65 Greydog65 is offline
FNG
Unhappy Disappointed with PPE
Hey guys, sorry to resurrect an old thread, but I just received my PPE gauge mount today and was disappointed to find out that there is no mounting hardware or instructions. Why did they put the two threaded holes in the back if it's a "press fit?" They don't even have any instructions posted on their site for it. Now I'm smart enough to figure this out, but this is unreal for a unit that cost me $114.50! I guess I'll have to fabricate some kind of mount for it so I don't have any issues during hard launches. Would appreciate any ideas or tips. Thanks!
  #11
Old 11-20-2009, 03:16 PM
uwyo_dmax's Avatar
Default
Here look at this...
http://www.bmdmax.com/Gauges.html.0.html
it doesnt need a mount made.
__________________
Justin
2003 Chevy LB7
EFILive
  #12
Old 11-20-2009, 06:14 PM
Alligator Alligator is offline
Default
Quote:
You don't need to make any mounts. I can launch as hard as I want, and that mount doesn't move. Just heat up the console, push it in, and leave it alone. I've never had a problem with one staying in place, and I've done several.
__________________
2006 CC/SB 4x4 LBZ Built - 900hp tow rig
2006 SC/LB LBZ Built - Caged
2002 SC/LB LB7 - 500hp parts getter
Team Borrowed Time #15
  #13
Old 11-27-2014, 08:12 AM
56taskforce's Avatar
56taskforce 56taskforce is offline
Default
I am going to use one of these for lift pump pressure and rail pressure. EGT, boost and drive pressure will go on the pillar. My truck came with one of these mounts for the edge monitor that I am selling with that programer, it was just a press fit as well tight fit never came out.
BTW it is posted for sale here on the boards add section.
__________________
2006 GMC 3500 CCLB- Danville stage 2 3794,Banks CAC, DHD 3" super high flow intake & 3" hot side pipe, FASS Titanium 150,PPE ported fuel rail & cp-3 inlet fittings, Nicktane/Cat, PPE race manifolds & up pipes, 4"MBRP duel exhaust, 3"PPE down pipe,4.56 gears,Yukon Grizzly locker, Suncoast GMax6 & Goerend R with Mike L springs, PPE deep pan & PTO covers, 1piece aluminum drive line with 1480 u-joints, tuning by Kory Willis and an S-480 waiting introduction to Mark's stg 2.
PLANS:60% over injectors, Sportsman CP-3
Semper-Fi
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
