  #1
Old 10-26-2009, 04:21 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default different size batteries
ok so for the first time in close to 2 years I might put my second battery back in my truck. Yes, it started in -10* on one battery without being plugged in but is cranked very slowly...
The only thing is the battery thats in my truck now is an advance auto platinum whatever, 875cca. The other battery I have (same age and same advance auto platinum brand as the 875cca one) is a 1000cca.
Yes I know you are "supposed to" have batteries with matching cca ratings, but is there an actual electrical engineer (or someone who knows a real answer other than "ive read..." and "everyone says..." or "just because...) out there who can tell me/give me a valid reason why I cant do this?
thanks
ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #2
Old 10-26-2009, 06:47 PM
Leadfoot's Avatar
Leadfoot Leadfoot is offline
Needs Bigger Tires!
Default
FWIW On my gasser I run two different part number Optima Red tops (each have a different CCA rating) with no isolator (both positive side terminals are tied together and both use the frame/chassis for ground) and I have had no issue to date. They were even purchased over a year apart. On another GM truck (non diesel) site I belong to, I asked what the issue would be with running them this way and was told that if one battery dies it could draw the other one down without an isolator but if both batteries are quality/new it should not be an issue.
Disclaimer This is only 1 man's experience, yours may differ....
__________________
2006 GMC CCSB 4WD McRat EFI Live , Kennedy dual lift pumps, Champion Stage IV tranny, Mike L converter, cooler and C3 oiler, Suncoast Brace, Eaton E-Locker, Caltracs, homemade pulling hitch, homemade limit blocks, H2's and cooper STT's, Predator, MBRP Cool Duals (not kitty or muffler), EGR blocker, Finger Stick, and all on headlight mod.
80 K20ish Reg Cab Long Bed, Full Roller 496, Manual TH400, Torque Converter Techniques converter, 3:1 planetary setup, NP205, High Angle driveshafts, 4.56's, 35's, Lockers F&R, Dakota digital dash, and custom interior.
www.matpa.org
  #3
Old 10-26-2009, 08:02 PM
<--- slippery roads
Default
Good!! I like that answer... thanks Chris. If my truck blows up you're responsible
ben
__________________
  #4
Old 10-27-2009, 01:49 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
we'll come help you again
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #5
Old 10-27-2009, 07:25 AM
clayt171's Avatar
clayt171 clayt171 is offline
He's watching you
Default
While you may never see a problem it really isn't a good idea. The batteries will drain and charge at a different rate and their lifes could be shortened. I doubt that anything will blow up. It's kinda like running with a battery that is really old and near the end of its life and one that is brand new.
__________________
Todd 'The Captain Obvious'
"Jebus"
Green 07 2500 Classic - Black Westin Platinum Steps - LineX - ISSPro Boost & Pyro - SD Manifold - P3 Brake Controller
Welcome to the Department of Sarcasm. We're so glad you're here!
I would love to help you out. Which way did you come in??
Member of the Department of Redundancy Department.
  #6
Old 10-27-2009, 09:35 AM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kind of guy
Default
lol i owe ya some truck work too ben
BTW made a little headway on gettin the trans parts issue worked out too will keep you in the loop
__________________
-Fireman
  #7
Old 10-27-2009, 11:52 AM
mmangels22's Avatar
mmangels22 mmangels22 is offline
Monty Python Rules.
Default
So they run all the electronics on one battery? It seems like something would overload in the long run, maybe you get some time out of it but its like doing holeshots with the tuner maxed out its only a matter of time before something goes bad. I am not an engineer but I did stay at a holiday inn express last night.
__________________
Matt
2005 LLY
6 inch fabtech lift
PPE standard xcelerator
35 inch Toyo Open Country AT
17 inch BMF M80 Death Metal Black
I'm thinking of wiping my ass with it, then mailing it back. They should be able to determine everything they need to know by the poopstain. They see the stain, examine it closely, then check the tax records for the information they seek...[/QUOTE]
Good stuff
  #8
Old 10-27-2009, 02:30 PM
<--- slippery roads
Default
Quote:
no...the batteries are wired in parallel... You can run the entire truck on [either] battery, it just cranks more slowly and is a little bit sketchy below 0* outside air temp.
__________________
  #9
Old 10-27-2009, 02:39 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
I have a 690, and a 770 in my truck
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #10
Old 10-27-2009, 06:55 PM
hdd-max hdd-max is offline
Gearhead
Default
Quote:
They will drain and charge at the same rate. It should not matter one bit unless one of the two batteries is not big enough to handle its part of the load or if the battery cables were way mismatched in size. The only difference between the 2 is one has more amps available than the other. It will not use more amps it just has more available.
__________________
2007 GMC Duramax/Allison CC/SB the sled puller, MIKE L trans, EFI live, bagged, shimmed.
2009 GMC Duramax/Allison CC/SB X2
2008 Denali XL
  #11
Old 10-27-2009, 07:28 PM
maine04max's Avatar
maine04max maine04max is offline
Default
ive had 2 different batteries in mine for well over a yr . ones an autozone gold and other is a optima yellow top. i have never had any issues
__________________
9/26/09 450 rwhp & 869
4/01/10 mild built motor
05/23/10 656rwhp 1190 trq 12.06 @113
07/20/10 Homebuilt 366 /480 twins
10/23/10 11.74 @121 soft launch
9/11/11 11.39 @120
  #12
Old 10-27-2009, 07:42 PM
duramax hd's Avatar
duramax hd duramax hd is offline
Default
I have one OEM AC Delco and one optima red top with no problems to date. Just to cheap to go buy another optima
__________________
2001 Dmax/Alli CC/SB Pewter
RIP stock Rods and block....9/2/12....Built motor 12/12/12-Failed. On the road back to stock. Moonshine Tuned, Dipper trans, Mike L. Cooler,Ultra Predator 8's on 285/55/20 BFG G-Force's
  #13
Old 10-28-2009, 12:39 PM
mmangels22's Avatar
Monty Python Rules.
Default
Quote:
You probably could run the whole entire truck on just one battery but the question is how long will it run on just one battery? If we can run 5-7 years with the two battery set up you would figure that the time would at least be shortened a year or so maybe more because the truck was designed to run on two batteries not one.
Do it and see what happens. I am subscribing to this.
__________________
Matt
2005 LLY
6 inch fabtech lift
Good stuff
  #14
Old 10-28-2009, 01:53 PM
<--- slippery roads
Default
probably???? Re-read the first post and you'll see thats what ive been doing for the past (almost) two years.
Ive ran it on the same single battery (from advance auto, not some special battery) and ive never had a problem with it. The only thing is it just cranks a little slower at all temperatures and cranks really slowly below 0*.
My single battery is just as good (load test, crank speed, etc) as it was when I put it in a long time ago. Am I shortening the life of it by putting a BIG load on it when I start the truck? Im not really convinced. Remember the BIG load is on the battery for all of what, 5 seconds? Its not like im sitting there cranking it until the battery is almost dead, then the engine starts and blasts the battery with full charge current from the alternator. THATS what kills batteries. Draining them down to nothing with a big load, then charging them up again really fast.
the two batteries is because when you start a diesel, you are running the starter and the glow plugs (or, sorry, excuse me cummins guys, the grid heater). Especially when in very cold temperatures. So far ive proven that with only 1 battery, yes, it sure cranks a lot faster below 0*, but it still starts just fine and so far there are no long term effects on the battery's health.
Im just wondering because I have two batteries sitting here. One 875cca thats in my truck, and another 1000cca sitting under a bench in the shop. (yes, its still fine, the old myth about batteries dieing when you leave them sitting on concrete is buffalo chips) Its a big PITA to put my second battery
Here is how it starts at 7 degrees below zero on only one battery. Yeah, it cranks slowly, but its still acceptable in my own opinion.
http://www.youtube.com/watch?v=6iA72Mzv9ek
Ben
__________________
  #15
Old 03-31-2011, 03:57 AM
ArrBee ArrBee is offline
FNG
Default
I believe there was a SCARE many years ago that batteries wired in parallel and not PERFECTLY matched would somehow discharge into each other.
OK, that is probably moot;
The wiring schematics for '03 and on show an aux battery relay and the way that I have been reading them that battery is only connected (via the aux battery relay) to the regular battery (as in single battery gas trucks) when the key is ON.
So for the few seconds of pre-heat and starting a weakened battery is a LOAD to a good battery. After that each draws from the 14 volt or so line from the alternator, e.g. each draws according to it's need, neither gets "boiled" by the high charge rate of the other.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
