  #1
Old 10-25-2009, 12:39 PM
coker6303's Avatar
coker6303 coker6303 is offline
Keep Calm and Chive On!!
Default strange 1st-2nd shift
I've been running Rob's 110hp tune on my LMM. Changed from a 70-80hp tune to Robs 110 and did the relearn. light and medium throttle shifts are spot on. Clicks through the gears perfectly. The weird part is at wide open throttle. If you roll along about 5mph and hit WOT the truck will go to shift into second and shut down. Feels like it makes the shift but drops all power, let off and get on it again and it takes off as if nothing happened. No codes. pulls great through 2nd, feels strange in 3rd (feels like you loose some accelleration and may be revving a little high) and then hits 4th perfectly and pulls hard again. Can't tell you about 5th and 6th, I don't pound it shifting into those gears. The TCM has not been changed, all stock shift points.
The only current mod to the tranny is the transgo jr kit. What do I need to be looking at in the ECM or TCM to get these shifts a little better? Any advice is appreciated.
Russ
__________________
Russ
2017 Ford F250 (I know I know...)
  #2
Old 10-25-2009, 01:14 PM
Bako_Dmax's Avatar
Bako_Dmax Bako_Dmax is offline
GTO Slayer
Default
I think your experiencing the truck defueling between shifts, which is saving your trans from slipping.
__________________
2006 Chevy LBZ
MBRP exhaust, Shimmed FPRV, Blocked EGR
Homemade Lift Pump W/ Bypass
Homemade Pitman & Idler Braces
Tierod Sleeves
EFI Live
Built trans w/ triple disc
Homemade Twins S475 w/ 38mm gate
  #3
Old 10-25-2009, 01:17 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Quote:
I totaly agree. Problem is; it still does a lot of damage to C3's even with the engine shut down. Need more trans.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #4
Old 10-25-2009, 01:55 PM
coker6303's Avatar
Default
Quote:
one of these days Mike!! LOL
When it shuts down shifting from 1st to 2nd, I have yet to keep my foot on the floor. I let out and then get back in it. Guess I need to stay in it just to make sure it is the defuel....or we'll be building a tranny sooner than expected!!
__________________
Russ
  #5
Old 10-25-2009, 02:17 PM
The Neens's Avatar
The Neens The Neens is offline
BFD
Default
Quote:
When it shuts down shifting from 1st to 2nd, I have yet to keep my foot on the floor. I let out and then get back in it. Guess I need to stay in it just to make sure it is the defuel....or we'll be building a tranny sooner than expected!!:D
I totally agree
__________________
2007 GMC 4WD CC/SB...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
2002 Chevy 2WD CC Dually...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
Next Taps party on ??-??-??
The sooner you fall behind, the more time you'll have to catch up...
Team Arrogance Founding Member
The Gerbil Clubs founding Member#1
"Gerbil Trainer for the Stars"
  #6
Old 10-25-2009, 03:57 PM
dwax's Avatar
dwax dwax is offline
Default
mine did the same thing (exactly) the first time i tune it with efi. turns out my old ppe was still hung in my computer somehow, so i reflashed the ecm, tuned it again, and then it shifted great... at the time my only tranny upgrades were transgo and T.C.
__________________
lmm with big tunes and stock tranny
  #7
Old 10-25-2009, 06:14 PM
coker6303's Avatar
Default
Quote:
I have flashed it 3 times with the same program to be sure that everything is right. Might do it again just for grins.
Aren't the defuels in the TCM? That would mean the truck should still have the same defuel as before since I did not change the TCM tune right? All I did was pull 1 EFILive tune off the ECU and replace it with Rob's tune.
__________________
Russ
  #8
Old 10-25-2009, 07:06 PM
SteveFord's Avatar
SteveFord SteveFord is offline
What's Next?
Default
Possible torque managment kicking in. I wouldn't worry about it until you get your trans upgraded.
__________________
2016 Chevy CCSB
  #9
Old 10-25-2009, 07:09 PM
Mike L.'s Avatar
Default
Defuel is ECM.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #10
Old 10-25-2009, 07:19 PM
The Neens's Avatar
BFD
Default
I'd give Rob a call, I'm sure he can make an adjustment to help you out...The 1st "big" tune I put in my LBZ acted this way, until it got some tweaking...
__________________
  #11
Old 10-25-2009, 09:30 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
Are you hammmering down in Track/Haul ass mode? or just in overdrive? I'm gueing your TCm has got used to shifting in O/D if taht's the case it will take a bit to figure out the shift point's to shift in/.Most people put it inTH mode to hammer downa nmd only use that switch for getiin on it it
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #12
Old 10-26-2009, 06:16 AM
coker6303's Avatar
Default
I'll give Rob a ring this evening and pick his brain.
On the bright side, Rob's 110hp tune is friggin amazing! Very friendly around town and in traffic, very responsive but not explosive until WOT. Beats the crap out of my 80hp tune I was running before.
__________________
Russ
  #13
Old 11-04-2009, 08:46 AM
coker6303's Avatar
Default
UPDATE
IdahoRob fixed the problem, just a slight change in the tune fixed everything up. Shifts spot on!
Here's a mechanical problem that is developing. After I let the truck sit with the engine off for a couple of hours during the day or overnight (and I let my truck idle before driving) the light-mid shifts are drawn out. The engine revs a couple hundred rpms between shifts instead of snapping to the next gear like it should. It goes away after it is driven for a mile or so.
Here's the best I can explain it: apply light throttle revving to 2200rpms and the shift from 1-2 is triggered, the engine free revs (no trans resistance) an additional 200rpms to 2400 before pulling down into 2nd gear. It will do this whether you are in tow haul or normal. TCM tune is stock.
Again, it only seems to do this after the truck has set for a while. I'm going change the tranmission fluid again (changed 12000 miles ago with Amsoil). Truck has 37000 miles on it.
__________________
Russ
  #14
Old 11-05-2009, 01:41 PM
coker6303's Avatar
Default
logged 4 passes at WOT, during 3rd gear the revs are around 3400 rpms and trans slip rpms are up to 800. Remaining at WOT, it has no problem shifting and locking the converter (+/- 8rpms) in 4th gear. 1-2nd shifts are great, but 2-3 and while in 3rd something strange is going on.
any ideas
__________________
Russ
  #15
Old 11-05-2009, 03:10 PM
The Neens's Avatar
BFD
Default
Did you log it from rolling into the throttle, or from a boosted launch?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
