#1
how much do they cost and are they worth getting? convertin duramax to 1987 chevy pickup
__________________
2004 lb7 cc-sb -EFI with dsp5/ACID -fresh motor build -tranny- george -60%over injectors -batmowheel -arp headstuds -bigger pushrods -headwork and new bigger valve springs -airdog 165 lift pump, - bd manifold -4in. mbrp exhuast -white traction bars -cognito hd tierods, using sleeves now -hd swaybar endlinks -cognito steering braces and idler povit -k&n intake -ppe boost valve - isspro performax guages , hid's -alpine system 400w sub |
#2
most have a core harness price starts around 1300 area last time I looked.I can get a true price for you if you want.
__________________
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4 EFI Live,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter. Alot Of thanks To George aka BigDipper 11.53 @ 116.92 1.66 60's ![]() RIP LBZ 6/1/08@5:44pm she was strong She's Alive again Born on July 27, 2008, 11:59:02 PM ![]() |
#3
what does the core do for you do they re do the one you give them or?..and yea can you get me a price thanks
__________________
#4
They take your stock core harness and take it apart and then put it back together to fit what you said you want. They do them all pretty much on a custom basis per sustomer request is how they explained it to me. I persoanlly did my owm 01 harness and it wasn't that bad to do, but I don't know how much harder the 03+ style would be as I know they made quite a few changes to them in 03+.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, 3.42 gears, 261 T-case Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4 and a PI ML converter DIAMONDEYE 4" exhaust with a CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump and pump rub kit.
#5
PPE will do it as well if you don't want to tackle the task. like henry said it's upwards of 1300 bucks though.
__________________
05 LLY stealth tuner,PPE boost controller, PPE Hot Xcel, 4" t-back 6" custom black stack, Airaid/AEM intake, air ride parallel 4 link. stock trans ![]() Thank you sponsors: XDP, BD Diesel, Raceline wheels, Silverline Exhaust, Pureflow Technologies and McGaughy's suspension. |
#6
ok thanks guys
__________________
#7
you can do the harness yourself. Its really not that hard. I dont know why companies are selling all these fancy aftermarket "standalone" harnesses when you can take a cheap used factory harness, spend a day working on it, and have the exact same thing...
![]() ben
__________________
2005 chevy dmax/allison - "HOT AND DANGEROUS" - built engine and trans with parts/advice/help from the best...MikeL.Trippin.Schulte.IdahoRob.TimHecker-St.JoeDiesel.McRat.juddski.dmaxfireman.BigDipper.M PI.Bobo.GMC-2002-DMAX.fingers.RickDLance.dmaxalliTech.EFILive...sor ry no times yet, I just wanted to reserve the truck-name BT DieselWorks, LLC - Full transmission/engine builds - EFILive tuning - full service for GM gas/diesel trucks and SUVs - Allison lockup controllers - Allison tapshift kits - dmax/alli/GM gasser standalone harnesses - custom truck electronic gadgets All products available for sale through our online store at www.btdieselworks.com Be sure to "like" us on Facebook at www.facebook.com/BTDWorks |
#8
Yes as everyone said PPE takes the harness and sets it up the way you want it to run what you want.
__________________
#9
well whats it consite of when doing it your self?
__________________
#10
x2
__________________
03 cc sb dmax 4x4 zf6 6speed <Gone efi live from mcrat southbend dual disk "you may never have to outrun a deceptacon, but its just nice to know you can." 04 Jeep Rubicon Stock for now
#11
Ben can help you there lots of cutting
__________________
#12
I can help you out with it. I just took a factory harness and made it "standalone" in my vw beetle that has a gen III chevy V8 in it. The harness that the gen III V8's use is basically identical to the dmax harnesses, I cut out all the non-essential wiring, and then tied it all together and added the basic wires to "interface" the stock harness with any vehicle the engine might go in (battery power, ignition power, check engine light, crank voltage, and data wire for the OBD port)
I wired it all into a custom mini fuse box so you dont have to reuse the huge factory UBEC (underhood fuse box) ben
__________________
#13
On my 01 I basically started with the connector printouts that I got from ALLDATA. Then go through and find similiar circuits as GM doubled up in many areas of them. The nice part is everything has a plug underneath the fuse panel and unhooks. Many of the colors are the same for each type of circuit(red for hot all the time, orange for hot when the key is on and so on). I just took the connector diagrams and went through after isolating and narowing them down and one by hooked them into the fuse panel and got that part out of the way. Then I took and went through and hooked in the control circuits like A/C and guages and then hooked up the throttle pedal. Once you get down to it and get it sorted out(make lots of notes on paper about which wires to cut out and which are duplictaes that can be narrowed down) it isn't that hard.
Heres a few pics of mine while I was doing it. I was lucky and found enough of the discontinued terminals at my local dealer to integrate it into my stock fuse panel. Also a packard crimping tool is a must have if you need to add in any wires to the factory plugs. ![]() ![]() ![]() ![]() As you can see everything comes together in a central point to make your connections all in one area. You have a main budle that goes to the engine, another bundle up to the ECM and a pigtail off for the TCM, and everything comes back to the central point at the underhood fuse panel.
__________________
#14
thanks for the help..when time comes ill be asking more questions. but for now thanks guys
__________________
#15
Quote:
![]() ben
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
