  #1
Old 08-31-2009, 06:03 PM
Vasbinder's Avatar
Vasbinder Vasbinder is offline
Default LB7 intake horn
What is the procedure of making the intake horn flow better. Do you machine or polish it out? I haven't seen any pictures and didn't want to mess it up doing it the wrong way
__________________
2011 Duramax
  #2
Old 08-31-2009, 06:07 PM
KEVINL KEVINL is offline
Default
Machine it to where it does not kneck down right before the compressor housing.
Polishing can't hurt either
  #3
Old 08-31-2009, 06:36 PM
maine04max's Avatar
maine04max maine04max is offline
Default
imo the horn from super diesel is well worth the money and hes a vendor here to boot
__________________
9/26/09 450 rwhp & 869
4/01/10 mild built motor
05/23/10 656rwhp 1190 trq 12.06 @113
07/20/10 Homebuilt 366 /480 twins
10/23/10 11.74 @121 soft launch
9/11/11 11.39 @120
  #4
Old 08-31-2009, 06:37 PM
03 D-max's Avatar
03 D-max 03 D-max is offline
Honorary "Tosser"
Default
X2 go with super diesel you wont go wrong. Its very cheap and it is done right
__________________
JACOB
Post Whore want to be#1
Easter Whore Member#2
Team Borrowed Time Member#23
Quote:
Originally Posted by The Neens View Post
I don't spray much...Usually only after Mexican food
03 2500hd Efi Live, SD, PPE, FASS, MBRP, K&N
  #5
Old 08-31-2009, 07:07 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Quote:
You need to machine it, either a mill or lathe. You can use a 1/4 endmill in a die grinder but you better have steady hands.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #6
Old 09-11-2009, 08:58 PM
Vasbinder's Avatar
Default
I would like to do it myself. I have my own Machine shop but I would like to see a finished product to get right Idea
__________________
2011 Duramax
  #7
Old 09-11-2009, 09:37 PM
MaxPowerLB7's Avatar
MaxPowerLB7 MaxPowerLB7 is offline
Amateur
Default
Just make it the same size as the rest of the horn. It necks down right before the turbo. Take it off and you will see. It's not very difficult.
__________________
02 4x4 Reg Cab Long Bed
10.47@132
  #8
Old 09-11-2009, 09:41 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is offline
Book 'em, Danno!
Default
its actually machined out to the same diameter as the gasket for the intake horn
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #9
Old 09-12-2009, 11:32 AM
Vasbinder's Avatar
Default
Thanks for the Info
__________________
2011 Duramax
  #10
Old 09-12-2009, 04:53 PM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
If you have a mill or drill press you can take it one step further.
It works and you don't have to remove the whole turbo just the compressor housing.
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #11
Old 09-12-2009, 05:42 PM
WolfLLY's Avatar
Making Chips
Default
Well if you havent done it yet, here ya go. Build a fixture to hold the horn by the three mounting holes. I you have a CNC your life just got easier, bolt fixture to table and interpolate away. If your doing this on a manual you can use a turntable (pain in the ass) or use a fly cutter.
__________________
LB7 ECSB 4X4
  #12
malibu795's Avatar
malibu795 malibu795 is offline
Default
man that is hoggin that whole thing out....
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #13
Old 09-12-2009, 05:57 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Quote:
Looks like crap.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #14
Old 09-12-2009, 06:10 PM
Vasbinder's Avatar
Default
No CNC but have a Turn Table for the Mill
__________________
2011 Duramax
  #15
Old 09-12-2009, 06:14 PM
Vasbinder's Avatar
Default
The Compressor housing what is the reason for hogging it out. Does it make the housing weaker. Does it flow more air
__________________
2011 Duramax
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
