Old 08-30-2009, 06:59 AM
pgf500 pgf500 is offline
Default 05 duramax wont start?
Sorry if I'm not on the right thread here but I have a "no start" question? I have a 05 duramax 1ton dually with a PPE programmer, a couple days ago I went out and it started up no problem. About 8 hours later I try to start it and it just clicks and sounds like a dead batteries or the starter motor isn't turning over. I checked the batteries with a basic fluke meter and they say right at 13 volts, all the grounds look good, no burnt fuses. Disconnected the batteries and charged till the chargers said both were 100%, nothing. Talked to a few people and they said its a starter is probably bad so I replaced it, no luck same thing. It just clicks once or twice and then nothing. I looked at the DTC on the programmer and it has nothing. Just curious if anyone has ideas or if there is something else I can check before I haul it to the dealer.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
