  #1
Old 08-15-2009, 05:52 PM
Dee7795 Dee7795 is offline
FNG
Default Fuel Rail Pressure Problems
I have a 02 GMC Duramax Diesel 2500 HD Extened Cab truck.With 96,000 miles.
I replaced the fuel pressure regulator 3 weeks ago. The truck drove fine until last Thursday. I'm getting the same symptoms of the regulator but I don't think it can go bad in 3 weeks.(right?) What other possibilites could it be. I replaced the fuel filter in July, and had the injectors done last year. How had is it to change the fuel rail pressure sensor, and where is it located? anyone have pics.
Thanks for any info and or Help.
Dee7795
  #2
Old 08-15-2009, 10:21 PM
SteveFord's Avatar
SteveFord SteveFord is offline
What's Next?
Default
I don't want to mislead you but when I had my 02 when it started having rail codes popping up, my injectors went out about 2 weeks after that. Are you running a big program, any lift pumps?
__________________
2016 Chevy CCSB
  #3
Old 08-15-2009, 10:39 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Moved Here!
  #4
Old 08-15-2009, 10:41 PM
LBZ's Avatar
LBZ LBZ is offline
Default
What exactly is the problem you are seeing? Too high of rail pressure? Too low?
  #5
Old 08-17-2009, 01:50 PM
FNG
Default
I am getting high fuel rail pressure
  #6
Old 08-17-2009, 01:53 PM
FNG
Default
Quote:
Thanks for your honesty, but truck is completely stock
  #7
Old 08-17-2009, 08:36 PM
superpro56 superpro56 is offline
FNG
Default
Check all the wires to the regulator. I hear if they loose connection with the ECM the regulator defaults out to max rail pressure.
__________________
Jason Snyder
2002 Silverado LS 2500HD CC/SB, EFI Live V2 DSP5 by Duramaxtuner, Big Dipper trans w/PI converter, Banks Technicooler, Danville LBZ CP3 w/modded regulator, 4" MBRP all stainless exhaust with 6" tip, K&N filter, Kennedy boost controller, Air Dog 150, Kennedy Billet Pickup and custom bulkhead fittings, Intake horn mod, SD manifold, resonator blocked, Autometer Cobalts on the A-pillar (fuel press, boost and pyro), Recon smoked cab lights and smoked 3rd brake light, Bilsteins, Westin stainless step bars, ExtangRT Tonno, Tecumseh brake controller, Husky liner floor mats, Line X OTR, Lund stainless cold front grill cover
540hp/1033tq @ Danville Performance 9/21/09
  #8
Old 08-18-2009, 10:14 AM
FNG
Default
Quote:
Thanks I'll do that.
  #9
Old 08-30-2009, 05:29 PM
FNG
Default
Hey,
my problem was a broken wire in the wiring harness going to the fuel pressure regulator.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
