  #1
Old 07-28-2009, 05:15 PM
tomc983 tomc983 is offline
tomc983
Default steering clunking STILL????
i replaced my intermidate shaft and that cleared up one noise but it still makes a clunking noise when i hit bumps. what should i try replacing next
__________________
2003 chevy 2500 hd
4" MBRP
AEM brute force hd intake
cognito leveling kit + 285 rf10s
Wish list: guages, and a tunner
  #2
Old 07-28-2009, 05:17 PM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
check sway bar bushings
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #3
Old 07-28-2009, 05:31 PM
Big Block 88's Avatar
Big Block 88 Big Block 88 is offline
Multiple choice muscle
Default
Are your shocks tight?
__________________
"SARGE" 1966 Jeep/Kieser M35a2 duece, whistler multi fuel engine 6x6 pure beast mode
"Maxine" 2007 Silverado CCSB LT3, LBZ/alli, CTS, PYO's and 265 Hankooks, EFI, MBRP, PPE stuff, bilstien 5100,
"Rusty Bullet" 2007 Classic CCSB, 1 LT, Greystone 4X4, Cognito, EFI, tuned by McRat/Neens, DSP by Mike Meyer, PPE stuff, Autometer, Trippin, Airdog, MBRP, Bilstein, Hankook, TransGo Jr SOLD 437 hp 1051tq STOCK TRANS
"Tow Pig" 2003 LB7/Alli EC/LB 2x4 4" straight, cts, EFI, SOLD
"Squirel" 2000 Chevy Silvy 1500 RC/SB 5 speed 4.8 little screamer back to stock, had polished 243's ls6 intake cam and valve train
"Great White Hope" 2013 silverado 1500 z71 CCSB loaded Corsa Exhaust, gmpp intake, leveled, 5.3 HO
"White Power"-2012 GMC Sierra, White on tan leather, CCLB Dually, 4x4 LML Alli, All stock
  #4
Old 07-28-2009, 05:40 PM
T2CH's Avatar
T2CH T2CH is offline
<<<Me...Not My Wife...
Default
Did you replace the plastic bearing in the column as well? Mine was worn out when I replaced the ISS.
__________________
2011 GMC Duramax, CC
Sold:'06 GMC Duramax, CC, SB, SLT 4SA, Chrome H2's, 285 BFG's, Downpipe back MBRP, Autometer guages, AD II, BigDipper trans, Tuning by IdahoRob
  #5
Old 07-28-2009, 05:52 PM
tomc983
Default
sway bar is tight shocks are tight but are getn prety soft.and the plastic bearing, no i didnt know there was one where is it located
__________________
2003 chevy 2500 hd
4" MBRP
  #6
Old 07-28-2009, 05:54 PM
Vrabel's Avatar
TOYAHOLIC
Default
look at sway bar with load on a arms, not with wheels hangin'
__________________
R.I.P.
ProFab Performance
  #7
Old 07-29-2009, 10:13 AM
T2CH's Avatar
Default
Quote:
At the bottom of the steering column. Just above the ISS joint you unbolted to get the ISS out. It will either be green or white. It pushes inside the column.
__________________
  #8
Old 07-29-2009, 02:40 PM
tomc983
Default
thats what the noise is thanks guys
__________________
2003 chevy 2500 hd
4" MBRP
  #9
Old 07-29-2009, 06:20 PM
PhilsLB7's Avatar
PhilsLB7 PhilsLB7 is offline
Way Better Than Facebook
Default
So what exactly did you do to stop the noise?
__________________
Phillip
02 Chevy 2500HD CC/SB 4X4 LB7 w/Allison Trans
Just stock
  #10
Old 07-29-2009, 07:03 PM
tomc983
Default
im ordering the bearing tomorow. i climbed under the steering wheel to see if it was the bearing grabed the iss and moved it arond, thats where all the play is its white on my truck
__________________
2003 chevy 2500 hd
4" MBRP
  #11
Old 07-29-2009, 07:46 PM
PhilsLB7's Avatar
Default
My 02 has been doing something similar and has been doing it since I got it in 02. Had the dealer look at it while it was still under warranty and I believe they replaced the steering shaft. However, I am not sure about the plastic bearing. Usually when I hit a bump it feels like something is loose in the steering but drives and steers fine. Is this similar to what you experienced?
Also, how much was the new bearing?
__________________
Phillip
Just stock
  #12
Old 07-30-2009, 09:15 AM
mmangels22's Avatar
mmangels22 mmangels22 is offline
Monty Python Rules.
Default
The clunking fix is not the long term fix, it fixes the problem temporarily. The noise could come back 5k or 30k it depends. GM has not found the appropriate fix yet. This is from my dealer, I asked them the same thing.
Its a screwy design but as long as it doesn't compromise my safety then I leave it alone.
__________________
Matt
2005 LLY
6 inch fabtech lift
PPE standard xcelerator
35 inch Toyo Open Country AT
17 inch BMF M80 Death Metal Black
I'm thinking of wiping my ass with it, then mailing it back. They should be able to determine everything they need to know by the poopstain. They see the stain, examine it closely, then check the tax records for the information they seek...[/QUOTE]
Good stuff
  #13
Old 07-30-2009, 02:02 PM
tomc983
Default
$45 for the bearing
__________________
2003 chevy 2500 hd
4" MBRP
  #14
Old 07-30-2009, 02:11 PM
T2CH's Avatar
Default
That seems high, they can do better. I paid $24.61 for mine on 4/16/09.
The new one should be green.
__________________
  #15
Old 07-30-2009, 06:32 PM
PhilsLB7's Avatar
Default
Thanks for the price info.
What's the difference between the white one and the green one?
__________________
Phillip
Just stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
