  #1
Old 07-24-2009, 04:14 PM
8100 Power 8100 Power is offline
FNG
Default Kenwood DNX 9140
I received and installed my new head unit. I replaced my Alpine W505 with this. This is a excellent unit, I would recommend this to all:
__________________
Jeff
SOLD
06 LBZ
11 LML
  #2
Old 07-24-2009, 04:39 PM
Big Block 88's Avatar
Big Block 88 Big Block 88 is offline
Multiple choice muscle
Default
Wow that is really nice, did you need to do any trimming on the interior of the dash?
__________________
"SARGE" 1966 Jeep/Kieser M35a2 duece, whistler multi fuel engine 6x6 pure beast mode
"Maxine" 2007 Silverado CCSB LT3, LBZ/alli, CTS, PYO's and 265 Hankooks, EFI, MBRP, PPE stuff, bilstien 5100,
"Rusty Bullet" 2007 Classic CCSB, 1 LT, Greystone 4X4, Cognito, EFI, tuned by McRat/Neens, DSP by Mike Meyer, PPE stuff, Autometer, Trippin, Airdog, MBRP, Bilstein, Hankook, TransGo Jr SOLD 437 hp 1051tq STOCK TRANS
"Tow Pig" 2003 LB7/Alli EC/LB 2x4 4" straight, cts, EFI, SOLD
"Squirel" 2000 Chevy Silvy 1500 RC/SB 5 speed 4.8 little screamer back to stock, had polished 243's ls6 intake cam and valve train
"Great White Hope" 2013 silverado 1500 z71 CCSB loaded Corsa Exhaust, gmpp intake, leveled, 5.3 HO
"White Power"-2012 GMC Sierra, White on tan leather, CCLB Dually, 4x4 LML Alli, All stock
  #3
Old 07-24-2009, 05:56 PM
FNG
Default
Quote:
No.
When installing the dash kit, make sure to set it on the radio as low as possible so it will clear the lower trim under it. Kenwood also sent the piece that you see around the radio to cut to fit to give it that clean look.
__________________
Jeff
SOLD
06 LBZ
11 LML
  #4
Old 07-24-2009, 07:33 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
Sweet!!!! We just put the 8120 in motorhome a couple of months ago
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #5
Old 09-12-2009, 06:43 AM
Dammitanyway Dammitanyway is offline
FNG
Default 07 Sierra Classic Audio Install
Looking for help with audio purchase and install.
I was looking at purchasing a Kenwood DNX 9140 head unit now that I have seen your install I will definately be purchasing.
A couple questions though.
Were you able to keep all of your steering wheel functions? If so did you have to purchase other hardware for this?
Did you install aftermarket subs, amps, and speakers?
I have an 07 Sierra Classic 2500 HD Extended Cab W/O the Bose System.
Any input or advice is much appreciated
  #6
Old 09-12-2009, 10:39 AM
FNG
Default
For the steering wheels you will need the PAC SWI Jack. It plug into the back of the unit, and then you connect the wires under the steering wheel and program the unit. I haven't got around to doing this yet with mine, most say it's not hard. I like using the remote anyways.
I did have a 1800 W amp with a Kenwood Sub hooked up but I've taken it out as I needed the room in the backseat.
You will need the PAC OS2 wiring harness also, it takes your factory radio plugs and lets you wire up your aftermarket radio to the factory wires, etc.
Let me know if you have any questions.
__________________
Jeff
SOLD
06 LBZ
11 LML
  #7
Old 09-12-2009, 12:41 PM
Cornell's Avatar
Cornell Cornell is offline
LBZ for life
Default
Looks nice
I'm going with the Z110bt I think, I like the caller interface better than the 9140
Still a sweet headunit
edit Blink 182 = awesome
__________________
Daily Driver 2017 Sierra Denali 2500HD
Hot Rod 2007 Sierra 2500HD / Reg Cab Short Bed / Danville 68mm STG2R / DHD Cast Bridge and 3" Cold Pipe / MBRP Boost 3" Tube / SDP 3" Downpipe / Magnaflow 5"/ PPE Up Pipes and Manifolds / Airdog 150 / Trans by Mike L / Cognito 4-6" / Custom Pearl White / SLT Interior With Ipad Headunit
  #8
Old 09-12-2009, 12:47 PM
FNG
Default
Quote:
Originally Posted by Cornell View Post
Looks nice
That's the first song on my Ipod list, I haven't listen to that stuff in a long time...
__________________
Jeff
SOLD
06 LBZ
11 LML
  #9
PhilsLB7's Avatar
PhilsLB7 PhilsLB7 is offline
Way Better Than Facebook
Default
Is the 9140 a DIN and a half or double DIN unit?
__________________
Phillip
02 Chevy 2500HD CC/SB 4X4 LB7 w/Allison Trans
Just stock
  #10
Old 09-12-2009, 12:48 PM
FNG
Default
Quote:
Double Din.
__________________
Jeff
SOLD
06 LBZ
11 LML
  #11
Old 09-12-2009, 12:56 PM
PhilsLB7's Avatar
Default
My 02 currently has the DIN and a half opening. So what model year did GM change from the DIN and a half to double DIN? Is there any chance I could just change the outer dash trim to get the double DIN opening? I would prefer to have a double DIN if it's possible.
__________________
Phillip
Just stock
  #12
Old 09-12-2009, 01:39 PM
Default
03 they changed I beleive
__________________
  #13
Old 09-12-2009, 01:48 PM
MWDHAND's Avatar
MWDHAND MWDHAND is offline
Default
That looks awesome I might have to get one for me!!
__________________
2004.5 Silverado 2500HD CC 4X4 Charcol Gray
AFE 4" Stainless Exhaust (no kitty), AFE Stage II,XM Radio,EFI Live ,Autometer Phantom II Triple "A" Pillar Gauges (Redone by MPL Motorsports), All On Headlight Mod,NADP Race Trans w/ 1057 (w/ Transynd), EGR Blocked (Thanks MPL Motorsports), Bilstein 5100's All Around (Thanks Lambcooker and MPL Motorsports),AMS Oil Dual Filtration Bypass and AMS Oil in Everything but the Tranmission(Transynd), FRPV Shim and Ported Fuel Rail Fitting Installed (Thanks MPL Motorsports),Diamond Eye Downpipe (Thanks MPL Motorsports),Cognito Pitman and Idler Arm Braces (Thanks MPL Motorsports) Snow MPG MAX (Installed by MPL) Mitusa Pump (Thanks Opie) Belltech 3" drop shackles in rear and torsion bars levelled off (Thanks MPL) Yukon Locker (Thanks MPL) XD Monster 20X9 With Nitto 420's
  #14
Old 09-12-2009, 03:14 PM
Cornell's Avatar
LBZ for life
Default
Get an 03+ bezel and an 03+ radio basket. It's pretty easy to do from what I've seen.
__________________
  #15
Old 09-13-2009, 06:49 AM
PhilsLB7's Avatar
Default
Thanks! I'll look in to that.
Do you know if the AC unit below the radio on the 03+ is as tall as the AC unit on the 02s? That's one area I am concerned I may have a problem with.
__________________
Phillip
Just stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
