  #1
Old 07-12-2009, 08:26 PM
kws808's Avatar
kws808 kws808 is offline
Diesel Freak
Default Random Stalling
I am having trouble with my truck just randomly stalling.It happened about a month ago and then went away until today. It happened twice today i was driving along and all of a sudden the truck just dies and i get a service brake system message on the DIC. I pulled over to the side of the road and cycled the ignition twice and it started right back up.What do you guys think ? It did not set any codes..
__________________
04 Duramax LLY Built Engine,Mike L Xtreme Trans,C3 Snake oiler,EPR Triples...,ATS Dual Fuelers
04.5 Duramax LLY, MPI Twins,Suncoast lV Trans with Co Pilot,Caltrac trac bars,EFI live
06Duramax LBZ ,5" MBRP Exhaust,EFI Live
  #2
Old 07-12-2009, 08:45 PM
Darius6t9 Darius6t9 is offline
I'm the Floater. Lurking.
Default
The only thing I can think of that was told to me is it could be a bad ground. I have the same problem all the time. Happened before I put all my go fast goodies on so I know its not that stuff. Bad grounds seem to be a big problem for these trucks. I just don't have an idiots guide to find them. Pictures would be good if anyone has them.
  #3
Old 07-12-2009, 10:06 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Quote:
On the driverside below and behind the power steering pump is a ground that goes to the frame, There is also one on the driver side attached to the rear of the cyl head it is beheind and under neath the glow plug controle module and attaches to the body ( it is the silver flat ground strap).
Also it does that same thing when we flash a tune maybe something with the ECM or the FICM?
I dunno it is possible all the nice salt air is getting to the truck
Good luck Kioni
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #4
Old 07-13-2009, 09:10 PM
kws808's Avatar
Diesel Freak
Default
Thanks guys i will check that out in the morning.I will let you know how it goes...
__________________
  #5
Old 07-20-2009, 01:37 PM
kws808's Avatar
Diesel Freak
Default
Well i checked all the grounds and they all seem to be ok. I had it happen again this morning and i couldent get it to start for about ten minutes.That was quite an a experience i was pulling our 30' gooseneck when it died in traffic...I also got a U1016 code and when i clear it,it comes right back. So what do you guys think ?
__________________
  #6
Old 03-22-2010, 09:33 PM
racinmike77's Avatar
racinmike77 racinmike77 is offline
Default
I am having this issue as we speak, im scared to drive the truck because it stalls randomly and is not fun wrestling to a stop in a safe place with no power steering or brake assist.
Maybe you guys could shed some light on the situation?
__________________
2005 CHEVY LS LLY CCSB Charcoal Gray Metallic
2005 CHEVY LT LLY CCSB Victory Red
EFI Live, Airdog, Autometer, Pro Comp 6in, H2 Wheels.
  #7
Old 03-22-2010, 09:41 PM
Mike_S's Avatar
Mike_S Mike_S is offline
OOPS!
Default
shuts down like you turned the key off, or sputters and dies...? Check all of your main electrical connections...the ABS system tends to be the first thing to throw a fit when there is low system voltage...
give us as much info as possible...noises, shudders, anything you can think of.
__________________
Nancy:
2004 CC SB, LB7, 2500 HD, Borg Warner spinny thingy, Carillo tough stuff, Transgo/suncoast tranny stuff, DMP squirt guns, and a couple custom parts.
The General:
1994 EXT Cab, SB, 1500 HD, 350 SBC, Whole Buncha $hit And Its Still Not Fast.
(I do all my own work...and thats not always good)
Good, Fast, Cheap...You Can Only Have Two!
You only need 2 tools: duct tape and WD-40. Duct tape for when it moves and isnt supposed to, and WD-40 for when it don't move and should!
  #8
Old 03-22-2010, 09:45 PM
Default
Like the key shuts off, the motor dies and gauges go to 0. The only things that work would be the AC, Radio and the dic and dash are illluminated with ABS, parking brake, and service brake system lights.
__________________
  #9
Old 03-23-2010, 07:23 AM
rebel7777's Avatar
rebel7777 rebel7777 is offline
Diesel Head
Default
How many batteries are you running?
__________________
15 ZL1, 580 HP (Stock),
12 LML DPF & Urea Delete, stock, new tires and rims
08 LMM DPF Delete, and DSP-2
04.5 LLY To Many Upgrades (Sold)
  #10
Old 03-23-2010, 07:27 AM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
Default
so this may be a dumb question but its happend to me do you guys have lift pumps like a fass or air dog? if so check the connections if they lose power you lose fuel truck will just die and the abs lights an shit come....just an idea imo
__________________
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tune 3 11.61 @ 119 !!
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
  #11
Old 03-23-2010, 09:43 AM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kind of guy
Default
you have a short somewhere. whether its a bad/dead battery or external. i welded a + batt cable to the exhaust (it melted through the shielding and shorted and welded to the exhaust) BAD BAD BAD stuff happens. i was lucky that my truck did not have all the modules fried.
almost identical symptoms to mine.
__________________
-Fireman
  #12
Old 03-23-2010, 01:28 PM
rebel7777's Avatar
Diesel Head
Default
The reason I ask about the number of batteries, wondering if you only have one and it is getting low and drawing everything down.
__________________
  #13
Old 03-24-2010, 08:18 PM
Default
I have two batteries, i found some mouse poo in the fuse box, Its looking like a wild goose chase or a needle in the haystack kinda deal.
Maybe I need a whole new fuse box?
__________________
  #14
Old 03-25-2010, 05:33 AM
rebel7777's Avatar
Diesel Head
Default
Man that sucks, spend all that money on your truck to have rodents basically destroy it.Between squirrels and mice you people in the states sure have it rough.
__________________
  #15
Old 03-25-2010, 07:09 AM
jneal's Avatar
jneal jneal is offline
Default
This is very odd. I currently have 2 truck that do the exact same thing, One LBZ and one LB7. Exact same problems. I've checked wiring, Jumped all power and grounds directly to the battery, along with Key switch voltage. and still nothing. I've swapped Ecm's and athe FICM on the LB7 with test controllers and still nothing. I'm about to pull my hair out.
Two questions for everyone with this problem and it's a long shot. Have you had your motor out lately, and what it is tuned with, and if tuned with EFIlive, what version?
Just trying to see if there is a common denomintor. (sp?)
__________________
TOW RIG: 1996 Dodge club cab 12v
TOY: 2006 Reg cab LMZ/ally 4x4
FLEECE PERFORMANCE ENGINEERING
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
